Cant reach web interface (Raspberry PI) Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Douwe63
Re: Cant reach web interface (Raspberry PI)
Post by Douwe63 » Tuesday 22 August 2017 0:47
Got the same issues as described above and I can confirm that the 'fix' of D'rMorris seems to work (at least, the service starts without issues and I can connect to the UI via the browser).
darrepac
Target OS: Raspberry Pi
Post by darrepac » Tuesday 22 August 2017 8:41
Strange that it crashes domoticz on my side
gizmocuz
Post by gizmocuz » Tuesday 22 August 2017 8:48
Updating to the latest beta solves it too
cd domoticz
./updatebeta
darrepac
Post by darrepac » Tuesday 22 August 2017 8:55
cd domoticz
./updatebeta
Yep!
ulrikk
Post by ulrikk » Wednesday 23 August 2017 18:25
I have no success with Raspian Stretch version. it worked for a short while with the betaupgrade, but then the same error.
I downgraded to jessie, that works
Hoeven
Post by Hoeven » Thursday 24 August 2017 9:50
Hello all ,
I have a two rasp pi2 +b with domoticz , one works perfect for some years , but the other one i have frequently problems that i can not reach it .
So i took a new SD card started to install the latest noobs , it works fine , update and upgrade and then install the latest stable domoticz version . all run OK , no failures . But domoticz does not start or is able the connect. I use the pi with a RFXcom 433E
Any suggestions , how to solve this ?
Jacco
Domoticz version: V3.8153
Post by Jacco » Saturday 02 September 2017 16:59
I have added the row below to /etc/apt/sources.list
deb http://ftp.de.debian.org/debian jessie main
after that I try to install the lib and it worked for me
apt-get install libssl1.0.0
You get a warning from that source but i ignored that.
stop domoticz
sudo service domoticz.sh stop
start domoticz
sudo service domoticz.sh start
And it is working.
Rebooted to be sure it is still working.
arjanhulst
Post by arjanhulst » Tuesday 05 September 2017 20:46
Did a new install of Domoticz easy way on a raspberry pi3 with stretch. Ran into the problem of the libssl1.0.0 error and tryng to installing it via apt-get install did not work. So after some searching i found this link with a solution to reinstall libssl1.0.0 on Stretch.
https://diyprojects.io/domoticz-install ... a7rFshJYuU
Hope it helps.
Cheers.
AntoonvdOetelaar
Post by AntoonvdOetelaar » Wednesday 06 September 2017 13:22
Probably I'm not helping... But Yesterday after a fresh install I couldn't reach the webinterface of domoticz running on the same windows machine.
This was with Internet Explorer.
After installing firefox, it did work as expected...
Skorpion
Post by Skorpion » Sunday 24 September 2017 17:59
Hope it helps.
Cheers.
This fixed it for me. Thanks!
mox69
Post by mox69 » Sunday 24 September 2017 20:29
For those of you having issues on the Raspberry PI 1 (original model A/ model B), here is a version of libssl1.0.0 that I compiled myself on my Pi last night. I'm running the Raspbian OS, September 2017 (Raspbian GNU/Linux 9 )
Working for me.
http://moxmobile.com/libssl1.0.0_1.0.1t ... _armhf.deb
ZatarraNL
Post by ZatarraNL » Thursday 05 October 2017 15:33
Mox69, didn't work for me. Tried about everything in this post. Had a clean install earlier this day, but can't get it working.
First I got the "error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory"
After installing manually libssl, got an "Invalid" error.
After installing domoticz beta, no effect.
After manually downloading your version of libssl.so.1.0.0, Mox69, I got the "Trace/breakpoint trap" error.
Distro and packages are up-to-date.
I'm using Rpi1 with the latest Raspbian stretch lite.
Only thing left is to install 2017-07-05-raspbian-jessie-lite.
Riba
Post by Riba » Friday 06 October 2017 23:55
Thanks Rs3b !!!
I just get my pi3, and tried to install strech with a tutorial and at the end the connection was refused.
The only thing that worked for me was using Rs3b method.
Use Jessie 05.07.2017
Connect wifi with wpa_supplicant.conf file
set MAC adresse in the rooter
updated/upgraded
install last domoticz version
TheWoodenGamer
Post by TheWoodenGamer » Saturday 07 October 2017 20:59
D'rMorris wrote:
Sunday 20 August 2017 9:03
I had the same issue and I fixed it by downloading the libssl1.0.0 and manually installing it. In SSH do:
wget http://ftp.nl.debian.org/debian/pool/ma ... _armhf.deb
Then:
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
Thanks! That fixed it for me.
EveningStarNM
Post by EveningStarNM » Friday 20 October 2017 10:19
The problem here is that Domoticz has a hard-coded dependency on an obsolete, insecure, and already exploited version of OpenSSL, namely libssl1.0.0. Instead of calling external library routines dynamically, Domoticz hard-links to specific libraries that are no longer available in the current stable Debian repository because they are obsolete. The latest LTS version of OpenSSL for Debian-based operating systems is in libssl1.0.2 (version 1.0.2m), and the latest stable version is libssl1.1.0 (v1.1.0g). (More information about the vulnerabilities these versions address is given in CVE-2017-3735.)
The upshot is, if you're writing code that is dependent on other code that has a CVE, you're doing it wrong.
Unfortunately, Domoticz is not the only widely used IoT application to suffer from this fatal flaw. Eclipse's implementation of the MQTT protocol, named "Mosquitto", suffers from exactly the same vulnerabilities. (A known exploit is in the wild for Mosquitto 1.4.10, which comes pre-installed on Raspbian Stretch. The version that is supposed to fix it (v1.4.12) cannot be installed for the same reason that Domoticz can't be installed, and, even if it could be, it is still hard-coded to use the old, exploited version of OpenSSL.) While it is possible to download and install the obsolete version of OpenSSL, this serves more to convince the world not only that Domoticz and Mosquitto can't be trusted, but also that IoT developers, in general, cannot be trusted to produce secure software.
As time passes and these problems are ignored during development, the problem becomes harder to solve, leaving the only solution to be the nearly complete abandonment of existing code and a complete rewrite from scratch. In the end, it turns out to be cheaper to do it the right way from the beginning. It is hoped that Domoticz's (and Mosquitto's) developers will address these problems soon.
BIRD
Post by BIRD » Thursday 09 November 2017 19:43
I found a solution that works for me.
I'm working with RPi B+ under Raspbian Stretch Desktop + Domoticz v.3.8153.
My solution:
Add "Jessie" in file "sources.list".
sudo nano /etc/apt/sources.list
Add line:
deb http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
Then:
sudo apt-get update
sudo apt-get install libssl1.0.0
sudo /etc/init.d/domoticz.sh stop
sudo /etc/init.d/domoticz.sh start
sudo /etc/init.d/domoticz.sh status
I have then => active (running) :D
Hope it can help someone.
woody4165
Post by woody4165 » Friday 17 November 2017 14:35
Hi @BIRD
just testing a Domoticz installation for a friend on a RPi B+ and had issue described in this 3d.
Tested all the solutions described before your post, but none worked for me.
Removed the previously installed libssl1.0.0 and followed with success your suggestions.
PS: little OT, is it possible to have a second Domoticz on my network, just for test, that insists on the same devices (to test it, I would like to restore a previously backup from my main Domoticz)?
stanv
Post by stanv » Saturday 18 November 2017 23:27
a big +1 for BIRD.
this was the first solution that fully solved the issue.
nickous
Post by nickous » Sunday 19 November 2017 9:40
In fact gizmocusz gave the solution 6 months ago:
  1. fresh install domoticz on stretch with the easy way
  2. updatebeta
and nothing else to do, it's working perfectly for me!
That's so simple...that I missed that and try a lot of things...before I read this thread for almost the tenth time :idea:
So I started again from the beginning and you know now the issue 8-)
jannl
Post by jannl » Sunday 19 November 2017 10:05
The updatebeta is a rather recent solution, did not work a few months ago. And I am not sure about installing a jessie library on stretch.
