Incorrect reading from z-wave power socket
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Stefan
Target OS: Raspberry Pi
Domoticz version: 3.5877
Post by Stefan » Saturday 15 July 2017 18:14
I`m using a [url]z-wave.me usb stick[/url] on Raspberry Pi 3 to read the consumption from a Neo Coolcam power plug (the one from aliexpress).
Every now and then I get some strange readings, screwing up the entire graph and report:
The domoticz server and the power plug are about 3 meters away, with only a table (with metalic frame) in between them.
I also see some timeouts in the logs:
2017-07-15 17:50:20.357 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:50:20.480 (STF-Z-wave-USB) Current (Unknown)
2017-07-15 17:50:25.194 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:50:25.198 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:50:30.359 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:50:55.836 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:50:55.839 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:51:00.368 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:51:05.262 Incoming connection from: 192.168.1.220
2017-07-15 17:51:20.561 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:51:20.871 (STF-Z-wave-USB) Usage (Aquarium instant power usage)
2017-07-15 17:51:20.873 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:51:26.523 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:51:26.526 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:51:30.563 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:51:30.789 (STF-Z-wave-USB) General/Voltage (Voltage)
2017-07-15 17:51:40.566 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:51:40.869 (STF-Z-wave-USB) Current (Unknown)
2017-07-15 17:51:50.568 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:51:57.207 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:51:57.214 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:52:11.062 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:52:20.579 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:52:20.848 (STF-Z-wave-USB) Usage (Aquarium instant power usage)
2017-07-15 17:52:20.851 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:52:27.900 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:52:27.903 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:52:30.581 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:52:30.824 (STF-Z-wave-USB) General/Voltage (Voltage)
2017-07-15 17:52:40.584 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:52:40.899 (STF-Z-wave-USB) Current (Unknown)
2017-07-15 17:52:50.587 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:52:58.575 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:52:58.578 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:53:20.592 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:53:29.283 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:53:29.286 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:53:40.848 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:53:49.872 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:53:59.873 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:53:59.960 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:53:59.963 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:54:00.285 (STF-Z-wave-USB) General/Voltage (Voltage)
2017-07-15 17:54:00.453 (STF-Z-wave-USB) Current (Unknown)
2017-07-15 17:54:20.951 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:54:21.184 (STF-Z-wave-USB) Usage (Aquarium instant power usage)
2017-07-15 17:54:21.187 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:54:21.389 (STF-Z-wave-USB) General/Voltage (Voltage)
2017-07-15 17:54:21.595 (STF-Z-wave-USB) Current (Unknown)
2017-07-15 17:54:30.602 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:54:30.604 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:54:51.599 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:54:58.050 (Weather Amsterdam) Temp + Humidity + Baro (Weather Amsterdam)
2017-07-15 17:54:58.053 (Weather Amsterdam) Wind (Wind Speed and Direction)
2017-07-15 17:54:58.055 (Weather Amsterdam) UV (UV)
2017-07-15 17:54:58.056 (Weather Amsterdam) General/Visibility (Unknown)
2017-07-15 17:55:01.334 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:55:01.338 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:55:11.894 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:55:21.606 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:55:22.071 (STF-Z-wave-USB) Usage (Aquarium instant power usage)
2017-07-15 17:55:22.073 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:55:22.212 (STF-Z-wave-USB) General/Voltage (Voltage)
2017-07-15 17:55:31.976 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:55:31.978 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:55:32.214 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:55:52.619 (STF-Z-wave-USB) General/kWh (Aquarium kWh Meter)
2017-07-15 17:56:02.622 OpenZWave: Received timeout notification from HomeID: 4180938784, NodeID: 5 (0x05)
2017-07-15 17:56:02.649 (STF-Nest) Thermostat (Nest Thermostat Setpoint)
2017-07-15 17:56:02.652 (STF-Nest) Temp + Humidity (Nest Temp/Humidity)
2017-07-15 17:56:02.715 (STF-Z-wave-USB) General/Voltage (Voltage)
2017-07-15 17:56:02.841 (STF-Z-wave-USB) Current (Unknown)
2017-07-15 17:56:12.066 User: Admin initiated a switch command (40/All lights ON - White/Bright/On)
2017-07-15 17:56:12.100 (STF-Hue) Lighting Limitless/Applamp (All lights ON - White/Bright)
Is there something I could do, or it`s just the cheap chinese quality of the power plug? :cry:
Users browsing this forum: vukovic2018 and 7 guests
