Lag in Virtual Swtiches Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Description:
matv
Target OS: Raspberry Pi
Domoticz version: 3.5877
Postby matv » Wednesday 11 January 2017 16:38
Version: 3.5877
Platform: Raspberry Pi v 3
Description:
Hi there,
I was wondering if the lag I am experiencing is normal.
- When I SSH from my MacBook to my Pi and execute a script* to turn on/off my lights, it works instantaneously.
- When I execute the same script* from a Dummy Virtual Switch in Domoticz, the lag is about 1 second before my lights respond.
It doens't bother me so much but it would be nice if I could somehow decrease the lag.
P.S. I am using the word lag because delay is a setting for switches. Mine is set to 0.
*) Applies to both https://github.com/bwydoogh/domoticz-scripts and https://github.com/LumKitty/MiLight3 .
Egregius
Re: Lag in Virtual Swtiches
Postby Egregius » Wednesday 11 January 2017 16:46
That's indeed a known issue. On/Off actions take approx 850msec to execute.
That's why I created LUA pass2php. With that script the 'lag' is on my system 20 msec, wich is lightning fast :D
matv
Postby matv » Wednesday 11 January 2017 16:55
Thanks for your timely and accurate response, Egregius!
I will look into your script.
Hopefully one day the lag in the stable version will be somewhat shorter :)
Egregius
Postby Egregius » Wednesday 11 January 2017 16:58
Maybe one day, who knows... I know it's there for at least one year now... Numerous topics have been created about it but no fix yet.
Anyway, once you have pass2php running you'll never think again of on/off actions ;)
gizmocuz
Re: Lag in Virtual Swtiches  Topic is solved
Postby gizmocuz » Thursday 12 January 2017 10:44
Egregius wrote:Maybe one day, who knows... I know it's there for at least one year now... Numerous topics have been created about it but no fix yet.
It is by very accident that i am reading this topic, and seen this 'problem' for the first time...
Recently we have changed a lot of code to make it possible to minimize internal execution time...
Instead of working with scripts (we should try to 'keep it simple'), a quick look at the code would have revealed where the problem lies
specifically at the function:
bool CSQLHelper::HandleOnOffAction(const bool bIsOn, const std::string &OnAction, const std::string &OffAction)
In the next beta (#6334) i minimized the time from 1 second to 200ms, that should be sufficient.
Hope you guy's can test this to see if it's ok ?
matv
Postby matv » Saturday 14 January 2017 16:17
gizmocuz wrote:In the next beta (#6334) i minimized the time from 1 second to 200ms, that should be sufficient.
It's definitely better (running 3.6343 now).
If I understand you correctly the remainder of the lag (.3-.5 seconds now I estimate) is due to the line in the script that you quoted?
Do you think there is any way I can reduce it slightly more myself?
gizmocuz
Postby gizmocuz » Sunday 15 January 2017 10:54
As said, 200ms is fast enough right ?
Siewert308SW
Postby Siewert308SW » Sunday 15 January 2017 13:39
gizmocuz wrote:As said, 200ms is fast enough right ?
Couldn't find the cause but noticed that the speed increased.
Until i saw the commit it github.
Thx for decreasing the delay, it fast enough for me.
Hardware:
1x Raspi Pi 3 / PIco hv3.0A Stack Plus / RFXtrx433E
3x Foscam FI9803P
2x Youless Elec/Gas
4x KD101 smoke detectors
And a lot of KaKu/Coco devices like: switches,sensors,doorbell, dusk sensor ect
My Domoticz scripts: Bitbucket
Egregius
Postby Egregius » Sunday 15 January 2017 16:40
matv wrote:.3-.5 seconds now I estimate
How do you estimate that?
The logfile contains the only correct answer for that:
2017-01-15 15:39:43.514 (ZWAVE) Light/Switch (pirkeuken)
2017-01-15 15:39:43.534 User: Admin initiated a switch command (61/wasbak/On)
2017-01-15 15:39:43.534 OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
Siewert308SW
Postby Siewert308SW » Sunday 15 January 2017 16:50
2017-01-15 15:45:54.588 (RFXtrx433e) Lighting 2 (W.C Motion)
2017-01-15 15:45:54.590 (W.C Standby) Lighting 2 (W.C Standby)
2017-01-15 15:45:54.601 (RFXtrx433e) Lighting 2 (W.C Lamp)
Hardware:
3x Foscam FI9803P
2x Youless Elec/Gas
matv
Postby matv » Sunday 15 January 2017 16:53
Thanks, you are right. I am new and was not aware of that option.
Below you will find the timestamps of my commands.
I do not want to use LUA scripts to speed up the process.
I guess the only thing I can do to gain some speed is removing all the scripts that I don't use in the script folder? Or does that not make a difference?
@gizmocuz thanks for the new beta's, the speed is workable now! :) (as opposed to the 1s delay mentioned earlier)
2017-01-15 15:47:52.864 User: Admin initiated a switch command (6/Bureaulamp/Off)
2017-01-15 15:47:52.864 (Mi-Light-iBox) Lighting 1 (Bureaulamp)
2017-01-15 15:47:53.032 Executing script: /home/pi/domoticz/scripts/bwydoogh/milight-home.py
168 ms
2017-01-15 15:47:54.007 User: Admin initiated a switch command (6/Bureaulamp/On)
2017-01-15 15:47:54.007 (Mi-Light-iBox) Lighting 1 (Bureaulamp)
2017-01-15 15:47:54.194 Executing script: /home/pi/domoticz/scripts/bwydoogh/milight-home.py
187 ms
Return to “Bugs and Problems”
Users browsing this forum: No registered users and 4 guests
