FGS223 Timeouts
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
YcKe
Target OS: Raspberry Pi
Re: FGS223 Timeouts
Post by YcKe » Friday 10 February 2017 16:57
annegerben wrote:
YcKe wrote:Hi @annegerben,
can you post a screenshot of your Groups & Network overview screen. (Including associations)
Greetz YcKe
Hi YcKe
as requested
Hi annegerben,
is the solution of micha_pr solving your issue too?
Greetz YcKe
annegerben
Re: FGS223 Timeouts
Post by annegerben » Friday 10 February 2017 17:06
micha_pr wrote:Hi all,
the source of all FGS223 problems seems to be in a Fibaro firmware "issue".
Device is reporting that it is supporting "switch multilevel" - but it is not right,... it is a binary switch only.
In Fibaro FGS config XML was inserted that's why:
    <!-- COMMAND_CLASS_SWITCH_MULTILEVEL. This class is in the list reported by the device, but it does not respond to requests -->
    <CommandClass id="38" getsupported="false"/>
But it does not help in any case for Domoticz installation - depending on different things may happen
  • - Switch 1 does not response (in log you can see that want to use multilevel command class....)
    - timeouts
While here is not a final solution you can edit your ZWave config file zwcfg_0xxxxxxx.xml
For that:
1) stop domoticz service
2) make a copy of your current xml file
3) edit the XML
4) start domoticz at new.
in XML look for the right node number (<Node id="xxx">) from hardware settings.
Must look like this:
 <Node id="2" name="" location="" basic="4" generic="16" specific="1" roletype="5" devicetype="1792" nodetype="0" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud
      <Manufacturer id="10f" name="FIBARO System">
            <Product type="203" id="1000" name="FGS223 Double Relay" />
        </Manufacturer>
        <CommandClasses>
            <CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="5" mapping="37">
            </CommandClass>
            <CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" innif="true">
            </CommandClass>
            <CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="3" request_flags="5" after_mark="true" getsupported="false" innif="true">
                <Instance index="1" endpoint="1" />
                <Instance index="2" endpoint="2" />
                <Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="button" genre="user" instance="1" index="1" label="Bright" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="button" genre="user" instance="1" index="2" label="Dim" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="bool" genre="system" instance="1" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
                <Value type="byte" genre="system" instance="1" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="byte" genre="user" instance="2" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="button" genre="user" instance="2" index="1" label="Bright" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="button" genre="user" instance="2" index="2" label="Dim" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="bool" genre="system" instance="2" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
                <Value type="byte" genre="system" instance="2" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="byte" genre="system" instance="2" index="5" label="Dimming Duration" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255" />
                <Value type="byte" genre="user" instance="2" index="6" label="Step Size" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
                <Value type="button" genre="user" instance="2" index="7" label="Inc" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
                <Value type="button" genre="user" instance="2" index="8" label="Dec" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
            </CommandClass>
            <CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="5">
                <Instance index="1" />
REMOVE now all between
<CommandClass id="38" ... and next </CommandClass> - so all this wrong class.
Result should be like this:
        </Manufacturer>
        <CommandClasses>
            </CommandClass>
            </CommandClass>
After starting at new domoticz the FGS223 will work - at least at all our installations it was starting to work normal...
@gizmocuz: maybe we can pass this wrong command class in zwcfg file if the parameter " getsupported="false" " is inside?
It is inside the Fibaro config XML and - inside the zwcfg file.
Good luck!
I made the change suggested by micha_pr, I still see timeouts in the logs, but the switchs now seem to respond normally again.
maxtrash
Re: FGS223 Timeouts
Post by maxtrash » Friday 10 February 2017 18:46
I never had timeouts, but the switch did not respond to wireless signals.
Fortunately removing the commandclass solved my issue as well
skippy711
Domoticz version: V3.7929
Re: FGS223 Timeouts
Post by skippy711 » Saturday 11 February 2017 13:44
    - timeouts
For that:
3) edit the XML
        </Manufacturer>
        <CommandClasses>
            </CommandClass>
            </CommandClass>
            </CommandClass>
        </Manufacturer>
        <CommandClasses>
            </CommandClass>
            </CommandClass>
Good luck!
Hi Michael,
I am willing to give it a try in Windows. Where can I find the required files.
Grtz
micha_pr
Re: FGS223 Timeouts
Post by micha_pr » Saturday 11 February 2017 14:00
skippy711 wrote: I am willing to give it a try in Windows. Where can I find the required files.
in domoticz/Config/ directory
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome-BB.de (German only)
skippy711
Re: FGS223 Timeouts
Post by skippy711 » Saturday 11 February 2017 14:28
Don't see a Zwave.cnf or Zwave.00...,.xml. In the FIbaro folder I see the FGS223.xml, but rules are different: only Command class id 38 (which is empty) , id 112, id 96 and id 133.
Any suggestions? Would be nice if your solution als solves the windows problems ;)
Thx
micha_pr
Re: FGS223 Timeouts
Post by micha_pr » Saturday 11 February 2017 15:50
and no
zwcfg_0xxxxxxx.xml
as I wrote? ;)
Michael Pruefer
skippy711
Re: FGS223 Timeouts
Post by skippy711 » Saturday 11 February 2017 16:23
micha_pr wrote:and no
zwcfg_0xxxxxxx.xml
as I wrote? ;)
This is in the config folder:
Domosapiens
Domoticz version: V3.5981
Re: FGS223 Timeouts
Post by Domosapiens » Sunday 12 February 2017 0:27
Are your .xml files hidden ?
skippy711
Re: FGS223 Timeouts
Post by skippy711 » Sunday 12 February 2017 11:45
Nope nothing hidden there...
skippy711
Re: FGS223 Timeouts
Post by skippy711 » Sunday 12 February 2017 23:05
Hi Michael,
Rechecked and I found the mentioned file in my linux build domoticz, but not in windows. In linux I have no problems with the Fgs223 (nor with the Fgs213) but in windows no luck with these fibaro's. I'm not a programmer, but could it be possible that the absence of this specific xml file causes the problems in the windows build?
Like I wrote: I'm by no means a programmer, but I'm willing to help out by testing on windows. (and be a happy Linux user on the side...) :lol:
Grtz
Domosapiens
Re: FGS223 Timeouts
Post by Domosapiens » Thursday 16 February 2017 23:01
zwcfg_0xxxxxxx.xml is a cache file created by Domoticz at start-up
Could it be that you have a "protection rights" problem and Domoticz is not allowed to create that file?
Some suggestions:
- Look at the folder permissions of the Domoticz/Config folder
- look at UAC (User Account Control) settings -> Start, search for UAC
- Run Domoticz as administrator
rolandbreedveld
Domoticz version: stable
Re: FGS223 Timeouts
Post by rolandbreedveld » Friday 17 February 2017 19:17
Removed the <CommandClass id="38" section from the Fibaro 223 Node:
the number of timeouts (I still get them) is significant better.
It also looks like the switch from the fibaro is recognized faster by Domoticz.
:D :D :D
Raspberry Pi2+3 | P1 SmartMeter | Z-Wave Razberry 2.0 | 4 Greenwave devices | FIBARO FGS223 +FGRM222 | Aerotec MultiSensor 6 | 2 x Gembird Siver-Shield with sispmctl | Logitech Harmony Hub | FritzBox
Interface to 123Solar + PowerOne 3.0 and SMA SB1200
micha_pr
Re: FGS223 Timeouts
Post by micha_pr » Friday 17 February 2017 20:20
Seems to be solved by gizmocuz now (wrong section in config):
viewtopic.php?f=6&t=13209&start=120#p120185
gizmocuz wrote:this should not be needed (i hope) if you update to the latest beta version and exclude/include the node
i did not got an class 38 here...
Michael Pruefer
marin849
Domoticz version: 2.4xxx
Re: FGS223 Timeouts
Post by marin849 » Monday 10 April 2017 23:22
Interesting. I will try this update as well!
Is there any way to exclude/include a dimmer without having to reconfigure all ELEVEN devices that is created per dimmer?
Users browsing this forum: No registered users and 4 guests
