ZWave broken in Version: 3.6325
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
gizmocuz
Target OS: Raspberry Pi
Re: ZWave broken in Version: 3.6325
Postby gizmocuz » Tuesday 10 January 2017 10:00
I am not sure if this is related to a possible problem in the configuration file...
But i updated the OZW library in the next beta version
tjoep
Postby tjoep » Tuesday 10 January 2017 13:59
I seem to have the same problem with a new installation. OpenZwave USB is not visible in the dropdown list on the hardware page on 3.6325 and also not in 3.6327. I have Domoticz on a Ubuntu system (16.04 LTS). And installed openzwave according to this manual: http://www.domoticz.com/wiki/Linux#Add_ ... for_Z-Wave
It also worked fine in older versions.
jannl
Domoticz version: Stable
Postby jannl » Tuesday 10 January 2017 16:04
hm, you only need to install openzwave if you compile Domoticz yourself. Nothing changed in the USB settings of the zwave device?
Egregius
Domoticz version: BetaRPi2
Postby Egregius » Tuesday 10 January 2017 17:06
@tjoep: You have a different issue, please search the forum or open another topic.
I do experience similar issues with 3.6327 on Syno:
2017-01-10 16:02:42.989 OpenZWave: Received timeout notification from HomeID: 25487143, NodeID: 5 (0x05)
2017-01-10 16:05:09.352 OpenZWave: Received timeout notification from HomeID: 25487143, NodeID: 5 (0x05)
One node constantly dropping timeouts, but even worse: none of the nodes react.
Let's go back to previous version...
Egregius
Postby Egregius » Tuesday 10 January 2017 17:34
Addition: apparently zwave hadn't queried all devices, even after 30 minutes.
Now back on v3.6312. Awake nodes queried in 4 minutes and no timeouts.
Domosapiens
Domoticz version: V3.5981
Postby Domosapiens » Tuesday 10 January 2017 22:20
Egregius
Postby Egregius » Tuesday 10 January 2017 23:46
I don't think so for my case. I don't have any of the devices in that list.
Also, when I go back to previous version with conservation of my XML the timeouts dissapear.
Return to “Bugs and Problems”
Users browsing this forum: No registered users and 5 guests
