RFLink and Venetian Blinds
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Twinsen
Post by Twinsen » Tuesday 03 January 2017 22:42
After the last updates the STOP command for Venetian blinds is not working.
I have the Domoticz v. 3.6231 and RFLink v. 45
For UP and DOWN commands everything is working perfect.
STOP command is ok, if I used directly in RFLink.
Please help me to solve this issue.
2016-12-24 09:55:19.688 User: lgr initiated a switch command (7/Stanga/Stop)
2016-12-24 09:55:19.689 Error: RFLink: trying to send unknown switch command: 17
2016-12-24 09:55:46.101 User: lgr initiated a switch command (7/Stanga/On)
2016-12-24 09:55:46.103 RFLink Sending: 10;BrelMotor;b808be;a1;DOWN
2016-12-24 09:55:47.210 (RFLink) Light/Switch (Stanga)
2016-12-24 09:55:49.170 User: lgr initiated a switch command (7/Stanga/Off)
2016-12-24 09:55:49.171 RFLink Sending: 10;BrelMotor;b808be;a1;UP
2016-12-24 09:55:50.315 (RFLink) Light/Switch (Stanga)
I think that, the problem is generated in the last stable release...
How can be solved this issue ?
Twinsen
Re: RFLink and Venetian Blinds
Post by Twinsen » Wednesday 04 January 2017 22:50
Can someone help me, please?
gizmocuz
Target OS: Raspberry Pi
Post by gizmocuz » Thursday 05 January 2017 9:08
Did this every work ?
What command do you send with RFLink to stop the blind ?
Twinsen
Post by Twinsen » Thursday 05 January 2017 11:39
This work till beginning of December.
The command is like the one below
2016-12-24 09:55:46.103 RFLink Sending: 10;BrelMotor;b808be;a1;STOP
Directly on RFLink is workink.
gizmocuz
Post by gizmocuz » Thursday 05 January 2017 13:11
I tested with a virtual rflink, it seems to create the correct command
best to debug if possible, maybe post this in the RFLink section?
Twinsen
Post by Twinsen » Thursday 05 January 2017 20:15
In log I have only this information:
2017-01-05 20:11:32.763  User: lgr initiated a switch command (7/Stanga/Stop)
2017-01-05 20:11:32.765  Error: RFLink: trying to send unknown switch command: 17
I post on RFLink section but without answer...
P.S. To activate debug is enough to start domoticz with "-verbose 1 -loglevel 0"
DAEMON_ARGS="$DAEMON_ARGS -www 80"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
DAEMON_ARGS="$DAEMON_ARGS -log /srv/domoticz/log/domoticz.log"
DAEMON_ARGS="$DAEMON_ARGS -verbose 1 -loglevel 0"
Twinsen
Post by Twinsen » Thursday 12 January 2017 7:35
The problem was solved by RFLink team.
Thank you for your support.
gizmocuz
Post by gizmocuz » Thursday 12 January 2017 13:12
could you be a bit more specific... is there a new firmware released or are there changes made in domoticz ?
People having the same issue would like to know what they have to do
Twinsen
Post by Twinsen » Thursday 12 January 2017 19:34
The problem was on domoticz integration, not on the RFLink firmware.
More details you can find here...
https://github.com/domoticz/domoticz/co ... 1ad7b94957
gizmocuz
Post by gizmocuz » Friday 13 January 2017 13:51
Thanks for the confirmation, hope all is working ok now
Users browsing this forum: No registered users and 5 guests
