LightWaveRF Dimming Percentage
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
jaminben
Postby jaminben » Monday 12 December 2016 23:39
Version: 3.5877
Build Hash: 15b013c
Compile Date: 2016-11-10 15:44:33
Platform: Windows 10
When setting the dimming level of my LightWaveRF devices via an RFX433 unit in percentages it appears that it sets the wrong value.... for instance if I set 10% it'll set 28% instead.
http://ipaddress/json.htm?type=command& ... =10percent
Many Thanks
Ben
gizmocuz
Target OS: Raspberry Pi
Re: LightWaveRF Dimming Percentage
Postby gizmocuz » Tuesday 13 December 2016 9:57
that could be, as it does not have 100 dim levels, i think 16, so it is rounded to the nearest level
You should see this when you move the slider in the web gui
jaminben
Postby jaminben » Tuesday 13 December 2016 13:48
gizmocuz wrote:that could be, as it does not have 100 dim levels, i think 16, so it is rounded to the nearest level
So the calculation Domoticz is doing is wrong?.. 16 \ 100 * 10 = 1.6 rounded to 2 should be 12.5% and not 28% if my math is correct which it may very well not be :?
gizmocuz
Postby gizmocuz » Tuesday 13 December 2016 18:50
Please, i said it could be 16, could also be 31, you can find this in the manual or looking through the source
jaminben
Postby jaminben » Tuesday 13 December 2016 19:21
gizmocuz wrote:Please, i said it could be 16, could also be 31, you can find this in the manual or looking through the source
Ok, I've looked through the manual and can't see any reference to a default value and I don't have the skills to look through the source.
Probably best to wait for a dev to make a comment rather than guessing.
gizmocuz
Postby gizmocuz » Tuesday 13 December 2016 20:52
hmmm, this is an open 'source' project
Found it... 32 steps
StanHD
Postby StanHD » Tuesday 13 December 2016 21:34
Within the HA Bridge you can use math replacement constructs like this: ${intensity.math(X/7)}
It's a crude work-around but gives an approximate correction over the range. (Apologies to Devs but I'm not a coder)
Domotica - Intel nuc Celeron, Domoticz - Windows, RFXTRX433E. 1-Wire USB. Lan Relay Boards, Aeon Z-Stick Gen 5, Evohome HGI80, Milight WiFi, MySensors Ethernet Gateway, Harmony Hub, Broadlink RM2, HA-Bridge with Amazon Echo / Alexa.
jaminben
Postby jaminben » Tuesday 13 December 2016 22:01
gizmocuz wrote:hmmm, this is an open 'source' project
Is it a bug or not?
StanHD wrote:Within the HA Bridge you can use math replacement constructs like this: ${intensity.math(X/7)}
Many thanks , I'll give that a shot :D
jaminben
Postby jaminben » Tuesday 13 December 2016 23:26
I've done more testing with a dummy dimmable LightWave device with the following results:
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=100percent
would equal 96%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=90percent
would equal 96%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=80percent
would equal 96%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=70percent
would equal 96%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=60percent
would equal 96%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=50percent
would equal 96%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=40percent
would equal 96%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=30percent
would equal 90%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=20percent
would equal 59%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=10percent
would equal 28%
http://ipaddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=5percent
would equal 12%
Where as using the same HTTP with a Hue device I get more or less the value I would expect (Set 40% = 39%, Set 60% = 59% etc.)
gizmocuz
Postby gizmocuz » Wednesday 14 December 2016 9:38
Thats because the hue (or zwave, and others) have 100 steps
gizmocuz
Postby gizmocuz » Wednesday 14 December 2016 9:44
Also the level should be between 0 and 31, and should also not include the word percent
When you debug json commands, 99% of the time they are already made/tested before in the web interface
In this case, you could add a dummy hardware, from the light/switches pages add a manual lightwaverf light as dimmer,
then open the 'chrome' developer console, goto the network tab, then operate the dimmer
now you see the json commands
jaminben
Postby jaminben » Wednesday 14 December 2016 10:19
Ok, so I see the command in chrome developer console is (set using 50% from the percentage scale):
json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=17
So it's not actually a percentage as I originally thought.
Am I correct in thinking then that I can't set a raw percentage but I've got to use StanHD's example of ${intensity.math(X/7)} and calculate it?
gizmocuz
Postby gizmocuz » Wednesday 14 December 2016 10:24
yes, it's not a percentage (it looks like a percentage for zwave dimmers because they go from 0-100)
if you query the light status via json, you also get the max. dim level steps (in this case 31 or 32)
so your value should be
(31/100.0f)*dimpercentage
jaminben
Postby jaminben » Wednesday 14 December 2016 10:40
gizmocuz wrote:yes, it's not a percentage (it looks like a percentage for zwave dimmers because they go from 0-100)
Cool, thank you for being patient with me... will try this when I get home tonight :D
jaminben
Postby jaminben » Wednesday 14 December 2016 19:00
Many Thanks to both gizmocuz and StanHD... it's working as expected now :)
http://IpAddress/json.htm?type=command&param=switchlight&idx=70&switchcmd=Set%20Level&level=${intensity.math(X/7.5)})
madrian
Postby madrian » Wednesday 11 January 2017 18:04
Maybe someone can help me there. I am trying to use LightWaveRF dimmer in "new frontpage.html skin", bu it is not implemented.
For minus button I used the following formula: var d = Math.round((level / 100.0) * 32); //where level is item["LevelInt"].
This works, but I have no idea about plus button (increase value), the original formula is:
var d = ((level + 10)/100 * 16) + 0.5;
..but this is for 1-16 dimmers.
//Dimmer, only works with 1-16 dimmer for now
function ChangeStatus(OpenDicht,level,idx,currentlevel)
   //When switched off return to previous level, no matter if plus or min pressed
   if (level == txt_off) {
      if (currentlevel == 1) {
         currentlevel++;
      //console.log("In uit",currentlevel);
      $.ajax({
      url: $.domoticzurl+"/json.htm?type=command&param=switchlight&idx=" + idx + "&switchcmd=Set Level&level=" + currentlevel,
      async: false,
      dataType: 'json',
      success: function(){
      console.log('SUCCES');
      error: function(){
      console.log('ERROR');
   else {
      level = level * 1;
      console.log(OpenDicht,level);
      if (OpenDicht == "plus")
            //not working
         console.log("in plus",d,level);
         if(d > 32) {
            d = 32;
         $.ajax({
         url: $.domoticzurl+"/json.htm?type=command&param=switchlight&idx=" + idx + "&switchcmd=Set Level&level=" + d,
         async: false,
         dataType: 'json',
         error: function(){
      else {
         console.log("in min",d,level);
         if( d < 0 ){
            d = 0;
         $.ajax({
         async: false,
         dataType: 'json',
         error: function(){
   RefreshData();
gizmocuz
Postby gizmocuz » Thursday 12 January 2017 8:53
i think it could be
d = (32/100)*level
Return to “Bugs and Problems”
