Raspberry: Domoticz wont start after last beta update
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Justintime
Target OS: Raspberry Pi
Post by Justintime » Monday 14 November 2016 17:00
Version: latest beta
Platform: Pi2
Description:
I have updated to the latest beta and saw domoticz "offline" tried to start in the terminal and saw this code:
 sudo service domoticz.sh start
/home/pi/domoticz/domoticz: error while loading shared libraries: libudev.so.1:        cannot open shared object file: No such file or directory
Tried to update manually again but no luck.
I googled the error and saw some hits on spotify.... but doesnt dare to follow those solutions.
Last edited by Justintime on Monday 14 November 2016 17:20, edited 2 times in total.
PA3FAT
Re: Domoticz wont start after last update
Post by PA3FAT » Monday 14 November 2016 17:02
same here.
gdg16
Post by gdg16 » Monday 14 November 2016 17:08
same here
gizmocuz
Re: Domoticz wont start after last beta update
Post by gizmocuz » Monday 14 November 2016 17:30
Installed a new build system, guess libudev is not statically linked anymore
working on it...
abc1000
Post by abc1000 » Monday 14 November 2016 17:34
Indeed , i had a *.so issue..
Justintime
Re: RE: Re: Domoticz wont start after last beta update
Post by Justintime » Monday 14 November 2016 18:13
gizmocuz wrote:Installed a new build system, guess libudev is not statically linked anymore
working on it...
Thanks, guess you will update this thread when it's fixed?
gizmocuz
Post by gizmocuz » Monday 14 November 2016 18:17
Sure, but they don't make .a libs any more... i have to see if i can find one...
Keep you updated
gizmocuz
Post by gizmocuz » Monday 14 November 2016 18:35
Building at the moment, this can take 60 minutes... (then test)
jvbussel
Post by jvbussel » Monday 14 November 2016 18:36
Until static linking is solved you can mak a symbolic link if Libdev0 is installed:
Edit: removed, very bad advice to do this..
gizmocuz
Re: Raspberry: Domoticz wont start after last beta update
Post by gizmocuz » Monday 14 November 2016 18:37
Please dont do this...
(And wait...)
if you can not wait... then issue
sudo apt-get install libudev-dev
johnwulp
Domoticz version: 3.4834
Post by johnwulp » Monday 14 November 2016 18:51
gizmocuz wrote:Please dont do this...
(And wait...)
sudo apt-get install libusb-dev
I tried this, but still the same error. Will waiting on the new beta work eventually?
if it ain't broke don't fix it!
gizmocuz
Post by gizmocuz » Monday 14 November 2016 18:58
I had a typo, and it's corrected. But waiting would be better yes...
JuanUil
Domoticz version: 2.xx
Post by JuanUil » Monday 14 November 2016 19:41
Same problem here.
Any idea how long we have to wait because nothing is working here anymore
tried allready to updatebeta in linux but this is also giving a problem about the libdev
Jan
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Restarting Domoticz... (please standby...)
[....] Restarting Domoticz Home Automation System: domoticz/home/pi/domoticz/domoticz: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
failed!
a3vd
Post by a3vd » Monday 14 November 2016 19:50
Great Job , it is working again :)
Raspberry B / Raspberry B+ / Raspberry 2 / Raspberry 3 / Raspberry 3+
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12
Several Kaku switches/ Weather Underground / Razberry / 2 Everspring 142 dimmers
gizmocuz
Post by gizmocuz » Monday 14 November 2016 19:50
I said it took an our to compile... i have to do this for every beta/stable, please take this into account
There is a new beta (#5898)
you can update by doing logging in to your system with the pi user, and issue
cd domoticz
./updatebeta
73 Rob
PA3FAT
Post by PA3FAT » Monday 14 November 2016 20:02
working again.
Tnx !
Justintime
Post by Justintime » Monday 14 November 2016 20:11
Up and running again.
Thanks for the quick support.
JuanUil
Post by JuanUil » Monday 14 November 2016 20:11
Working again
Tnx for the great effort you make Gizmocuz!!!!
in dutch: HULDE!!!
Justintime
Re: RE: Re: Raspberry: Domoticz wont start after last beta update
Post by Justintime » Monday 14 November 2016 20:13
JuanUil wrote:Same problem here.
Jan
failed!
If you really needs to rely on your system you shouldn't be running beta.
Otherwise you need to patient before it is fixed.
gizmocuz
Post by gizmocuz » Monday 14 November 2016 20:20
Well... i find it strange that the library maintainer from libudev does not distribute static builds anymore, and also does not want to
The only reason we need this library is because there are some special/old/vintage zwave controllers
Users browsing this forum: No registered users and 4 guests
