Mi_light Ibox v6 (API) not working
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
poudenes
Domoticz version: 3.8993
Re: Mi_light Ibox v6 (API) not working
Post by poudenes » Tuesday 02 January 2018 9:16
After i turned off MQTT Hardware in Domoitcz and Homebridge config. The whole AppLamp Bridge error is gone !!!.
Domoitcz didn't crash or broken to use AmpLamp controller.
For me the problems is solved now. I gonna check if a different way of MQTT will work. Because the realtime button switch in Homekit is not working now. Not a issue, but fun to find out to let it work.
MQTT was now installed ny apt-get. I see also that MQTT can be installed in NPM.
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
PixelMagic
Domoticz version: 3.8796
Post by PixelMagic » Saturday 03 February 2018 18:34
poudenes wrote:
Saturday 18 November 2017 14:27
Hi All,
Sometimes is see those lines in log. Milights still working normal, but want know what this can be:
2017-11-17 18:47:05.682 Error: AppLamp: Error sending command to Bridge!...
2017-11-17 18:47:07.112 Error: AppLamp: Invalid command send to Bridge!...
2017-11-17 23:25:14.582 Error: AppLamp: Error sending command to Bridge!...
2017-11-18 09:25:01.681 Error: AppLamp: Error sending command to Bridge!...
2017-11-18 09:25:03.104 Error: AppLamp: Invalid command send to Bridge!...
I have the same thing, weird is that it seems to happen when Domoticz is running for a longer time without restart. The weird thing is that after the error the light is still switched, maybe because Domoticz tryes again. I notice it with multiple lights they get switched very slowly,
When I restart Domoticz the problem is gone for multiple days, cannot say how many exactly. The second way it dissaperes is when in the hardware tab the milight interface is disabled and saved and the enabled again.
Have this problem with the original V6 gateway with lamp and also with my ESP homemade gateways.
poudenes
Post by poudenes » Sunday 04 February 2018 0:22
I find out when I disable mqtt the errors are gone. After 2 weeks enable mqtt again and now I see the error appear again.
Hi All,
PixelMagic
Post by PixelMagic » Sunday 04 February 2018 0:35
Hi All,
I do not use mqtt, had it in the hardware list and deleted it just now. Cannot think that would be the problem, but who knows.
Mace
Domoticz version: 3.8153
Post by Mace » Friday 09 February 2018 9:15
Experience the same problem, not using MQTT.
reza
Target OS: Raspberry Pi
Domoticz version: 3.5877
Post by reza » Thursday 22 February 2018 22:02
i have problem with ibox2 :( what am i do ? :( :( :(
galinette
Post by galinette » Tuesday 17 April 2018 9:33
Dear all,
I have a new Milight iBox2 and my setup is made of newest Milight 5-in-1 LED strip controllers. These can be configured as W, CCT, RGB, RGBW, or RGBCCT controllers by pressing on a switch and connecting the strip accordingly
https://www.futlight.com/productdetails ... typeid=146
These controllers can be controlled by the 8-channel remotes only (FUT089) and not by the older 4-Channel RGBCCT remotes (FUT092). On the milight 3 app for the wifi controller, this is the same, only the virtual 8-channel remote can be linked, all the others do not work.
So basically, I am stuck as no setting combination in Domoticz appear to work. I suppose that the new 8-channel remote use different API codes (is this the v7?) and this is not supported by the Domoticz plugin. Do you confirm this or is there a chance to get them to work with the current plugin?
I am ready to invest some time in improving the Limitless/Milight support in Domoticz, but is there anywhere I can find documentation about the 8-channel remote codes?
denman091
Post by denman091 » Wednesday 19 September 2018 2:30
galinette wrote: So basically, I am stuck as no setting combination in Domoticz appear to work. I suppose that the new 8-channel remote use different API codes (is this the v7?) and this is not supported by the Domoticz plugin. Do you confirm this or is there a chance to get them to work with the current plugin?
Do you have this already working?
