Service Domoticz don't start code=exited, status=217/USER
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
tich3012
Target OS: Raspberry Pi
Domoticz version: 3.7450
Post by tich3012 » Wednesday 17 May 2017 13:29
It's my first post on the forum.
Version : 3.7450
Platform : Raspbian Pixel
Hardware : Rapsberry pi 3
Everything work week on this config since on years.
And a few day ago my little daughters stop my raspberry and since this I have some trouble to run Domoticz.
First I have som trouve with Hardware Raspberry GPIO, when I insert this hardware the domoticz service start and stop automatically.
I succes this I don't how.
Now the problem is when I want to start the service I have this problem : code=exited, status=217/USER and the service don't start
The domoticz status
 sudo systemctl status domoticz.service
● domoticz.service - domoticz_service
   Loaded: loaded (/etc/systemd/system/domoticz.service; enabled)
   Active: failed (Result: exit-code) since mar. 2017-05-16 22:12:18 CEST; 14h ago
  Process: 2281 ExecStart=/home/pi/domoticz/domoticz -www 8080 -log /home/pi/domoticz.log -loglevel 0 (code=exited, status=217/USER)
 Main PID: 2281 (code=exited, status=217/USER)
mai 16 22:12:18 RaspPixel systemd[1]: Started domoticz_service.
mai 16 22:12:18 RaspPixel systemd[1]: domoticz.service: main process exited, code=exited, status=217/USER
mai 16 22:12:18 RaspPixel systemd[1]: Unit domoticz.service entered failed state.
Automatic start
When I start domoticz like this
 sudo /home/pi/domoticz/domoticz
It works Fine
Code in my domoticz.service
sudo nano /etc/systemd/system/domoticz.service
[Unit]
       Description=domoticz_service
[Service]
       User=domoticz
       Group=domoticz
       WorkingDirectory=/home/pi
       # Give the right to open priviliged ports. This allows you to run on a port <1024 without root permissions (user/group setting above)
       # The next line was previously working, so try this on older systems.
       # ExecStartPre=setcap 'cap_net_bind_service=+ep' /home/domoticz/domoticz/domoticz
       # The below works on ubuntu 16 LTS.
       #CapabilityBoundingSet=CAP_NET_BIND_SERVICE
       #Restart=on-failure
       #RestartSec=1m
       #StandardOutput=null
[Install]
       WantedBy=multi-user.target
File domoticz.sh in /etc/init.d/
sudo nano /etc/init.d/domoticz.sh
Result
#! /bin/sh
### BEGIN INIT INFO
# Provides:          domoticz
# Required-Start:    $network $remote_fs $syslog
# Required-Stop:     $network $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Home Automation System
# Description:       This daemon will start the Domoticz Home Automation System
### END INIT INFO
# Do NOT "set -e"
/usr/local/bin/gpio export 17 out
/usr/local/bin/gpio export 18 out
/usr/local/bin/gpio export 27 out
/usr/local/bin/gpio export 22 out
/usr/local/bin/gpio export 23 out
/usr/local/bin/gpio export 24 out
/usr/local/bin/gpio export 25 out
/usr/local/bin/gpio export 12 out
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Domoticz Home Automation System"
NAME=domoticz
USERNAME=pi
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
DAEMON=/home/$USERNAME/domoticz/$NAME
DAEMON_ARGS="-daemon"
DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
DAEMON_ARGS="$DAEMON_ARGS -syslog"
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.2-14) to ensure that this file is present
# and status_of_proc is working.
. /lib/lsb/init-functions
pidof_domoticz() {
    # if there is actually a domoticz process whose pid is in PIDFILE,
    # print it and return 0.
    if [ -e "$PIDFILE" ]; then
        if pidof domoticz | tr ' ' '\n' | grep -w $(cat $PIDFILE); then
            return 0
        fi
    fi
    return 1
# Function that starts the daemon/service
do_start()
        # Return
        #   0 if daemon has been started
        #   1 if daemon was already running
        #   2 if daemon could not be started
        start-stop-daemon --chuid $USERNAME --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
                || return 1
        start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
                $DAEMON_ARGS \
                || return 2
# Function that stops the daemon/service
do_stop()
        # Return
        #   0 if daemon has been stopped
        #   1 if daemon was already stopped
        #   2 if daemon could not be stopped
        #   other if a failure occurred
        start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME
        RETVAL="$?"
        [ "$RETVAL" = 2 ] && return 2
        # Wait for children to finish too if this is a daemon that forks
        # and if the daemon is only ever run from this initscript.
        # If the above conditions are not satisfied then add some other code
        # that waits for the process to drop all resources that could be
        # needed by services started subsequently.  A last resort is to
        # sleep for some time.
        start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON
        [ "$?" = 2 ] && return 2
        # Many daemons don't delete their pidfiles when they exit.
        rm -f $PIDFILE
        return "$RETVAL"
case "$1" in
  start)
        [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
        do_start
        case "$?" in
                0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
                2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
        esac
  stop)
        [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
        do_stop
        case "$?" in
        esac
  status)
        status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
  reload)
        log_daemon_msg "Reloading $DESC" "$NAME"
        PID=$(pidof_domoticz) || true
        if [ "${PID}" ]; then
                kill -HUP $PID
        fi
  restart)
        log_daemon_msg "Restarting $DESC" "$NAME"
        do_stop
        case "$?" in
          0|1)
                do_start
                case "$?" in
                        0) log_end_msg 0 ;;
                        1) log_end_msg 1 ;; # Old process is still running
                        *) log_end_msg 1 ;; # Failed to start
                esac
                # Failed to stop
                log_end_msg 1
        esac
        echo "Usage: $SCRIPTNAME {start|stop|status|restart}" >&2
        exit 3
esac
Fichier domoticz.sh /home/pi/domoticz/
 sudo nano /home/pi/domoticz/domoticz.sh
Result
#! /bin/sh
### BEGIN INIT INFO
### END INIT INFO
# Do NOT "set -e"
NAME=domoticz
USERNAME=pi
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
. /lib/init/vars.sh
pidof_domoticz() {
            return 0
        fi
    fi
    return 1
do_start()
        # Return
                || return 1
                $DAEMON_ARGS \
                || return 2
do_stop()
        # Return
        RETVAL="$?"
        rm -f $PIDFILE
        return "$RETVAL"
case "$1" in
  start)
        do_start
        case "$?" in
        esac
  stop)
        do_stop
        case "$?" in
        esac
  status)
  reload)
                kill -HUP $PID
        fi
  restart)
        do_stop
        case "$?" in
          0|1)
                do_start
                case "$?" in
                        0) log_end_msg 0 ;;
                esac
                # Failed to stop
                log_end_msg 1
        esac
        exit 3
esac
I don't know what I can do, I'm lost, so If you can help I appreciate
tich3012
Re: code=exited, status=217/USER
Post by tich3012 » Thursday 18 May 2017 9:11
Hello
Anybody have an idea for this? or a way to find and solve my problem?
tich3012
Re: Service Domoticz don't start code=exited, status=217/USER
Post by tich3012 » Friday 19 May 2017 21:02
Hello
Any pist to help me?
jvdz
Domoticz version: Stable
Post by jvdz » Friday 19 May 2017 21:41
Could it be the file security causing the issue?
Is the user Pi the owner of the files in the domoticz directory?
Jos
tich3012
Post by tich3012 » Saturday 20 May 2017 19:09
Hello thanks for you response
pi is the owner for Domoticz folder
tich3012
Post by tich3012 » Saturday 20 May 2017 21:16
I found
in my old file domoticz.service i have
[Unit]
[Service]
       User=domoticz
       Group=domoticz
       #Restart=on-failure
       #RestartSec=1m
[Install]
Change by this
[Service]
       User=pi
       Group=pi
Users browsing this forum: No registered users and 4 guests
