Domoticz crashes when changing a property of a zwave sensor
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
geezerrr
Target OS: Raspberry Pi
Re: Domoticz crashes when changing a property of a zwave sensor [solved]
Postby geezerrr » Monday 19 December 2016 10:30
When I enable debug this is my domoticz log when it crashing while change the report state.
2016-12-18 20:38:33.686  (RaZberry 2.0) General/kWh (Buitenlamp Voor | kWh Meter)
2016-12-18 20:38:34.219  (RaZberry 2.0) General/kWh (Buitenlamp Voor | kWh Meter)
2016-12-18 20:38:34.627  (Nefit Easy) Thermostat (Nefit | Setpoint)
2016-12-18 20:38:34.683  (Nefit Easy) Temp (Nefit | Kamer Temp.)
2016-12-18 20:38:34.830  (Nefit Easy) Temp (Nefit | Flow Temp.)
2016-12-18 20:38:34.959  (RaZberry 2.0) Usage ($Buitenlamp Voor | Unknown)
2016-12-18 20:38:34.960  (RaZberry 2.0) General/kWh (Buitenlamp Voor | kWh Meter)
2016-12-18 20:38:35.216  (Nefit Easy) General/Pressure (Nefit | Druk)
2016-12-18 20:38:35.437  (Nefit Easy) Temp (Nefit | Buiten Temp.)
2016-12-18 20:38:40.080  Error: Domoticz received fatal signal 11 !...
2016-12-18 20:38:40.082  Error:   /home/pi/domoticz/domoticz() [0x1a7e7c]
2016-12-18 20:38:40.082  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1a7f34]
2016-12-18 20:38:40.083  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76adc180]
Hope this is helping?
Lectere
Postby Lectere » Monday 19 December 2016 13:02
gizmocuz wrote:You could use a vmware, if you have an debian (raspberry) machine with the real usb stick, you can also use ser2net, but the easiest is to plug the usb stick directly into the machine
There is a readme file in the repo explaining how to setup visual studio, it's the project file (in the msbuild folder), and the libraries you need to install there
I can't find any usefull information in the readme on how to setup with visual studio; https://github.com/domoticz/domoticz/bl ... /README.md
Searched for other readme's, can't find any...
Effictent and redundant two-factor authentication? http://www.smspassword.com
gizmocuz
Postby gizmocuz » Tuesday 20 December 2016 9:58
Sorry, try INSTALL.txt
geezerrr
Postby geezerrr » Saturday 24 December 2016 11:09
Lectere,
Did you got any further with this one? Can't use my aeon zw089 sensors right now. Does my log point in the right direction? The last lines are telling that something went wrong...
remb0
Postby remb0 » Thursday 29 December 2016 20:28
this is also a problem if you set binary in the ozwcontrol panel. I will send an issue to them.
geezerrr
Postby geezerrr » Thursday 29 December 2016 21:05
Yes it is!
FritzzJan
Postby FritzzJan » Thursday 29 December 2016 22:17
Why is this topic marked as [solved] ?
There are still problems, if you try to change the parameter of the Aeontec Siren Gen5, Domoticz still crashes!
http://www.domoticz.com/forum/viewtopic.php?f=24&t=12818&p=110717&hilit=siren+5#p110717
gizmocuz
Postby gizmocuz » Friday 30 December 2016 8:54
remb0 wrote:this is also a problem if you set binary in the ozwcontrol panel. I will send an issue to them.
What do you mean with 'set binary' ?
remb0
Postby remb0 » Friday 30 December 2016 9:41
The resessed door sensor form aeotec ZW089 only works when parameter 112 or 121 (can't see it right now) is set to report binary instead of basic report. (there is another thread about it).
But it's also with other devices where you can choose report type. and not only in domoticz but also in the openzwave control panel.
gizmocuz
Postby gizmocuz » Friday 30 December 2016 10:16
did you compile openzwave and the control panel tool, and test this ? (so without domoticz)
i do have this door sensor around... (Aeotec DSB54 Recessed Door Sensor)
Looks like a different one, but i changes some parameters without problems
you do enter normal decimal values i hope, or is it a dropdown ?
Maybe a screenshot would help
Do you also experience this under windows ?
BakSeeDaa
Postby BakSeeDaa » Friday 30 December 2016 17:44
I have the same problem in V3.6277. Domoticz crashes when changing a property of a zwave sensor. It happened a few times since yesterday. The xml file (fgwpfzw5.xml) is custom made so this post maybe is useless . I just mention it in case it can be of any help. I haven't done further testing.
Best wishes
// บักสีดา
gizmocuz
Postby gizmocuz » Friday 30 December 2016 18:02
Hmmm so it could be a configuration thing
remb0
Postby remb0 » Friday 30 December 2016 20:05
here is the screenshot from domoticz
2016-12-30 19_01_48-Domoticz.png (121.84 KiB) Viewed 339 times
another strange thing:
034 (0x22) Voordeur Aeotec ZW089 Recessed Door Sensor Gen5 Aeotec 0x0059 0x0002 2016-12-30 17:58:14 No Heal node
2016-12-30 17:58:14 is the time I opened the door.
But in the device screen:
2016-12-30 19_04_14-Domoticz.png (37.68 KiB) Viewed 339 times
I don't understand what the problem can be.
leoncornelissen
Postby leoncornelissen » Saturday 31 December 2016 19:13
I have the same problems over here,
I was able to add the door sensor but the status was always open. Even with the door closed.
I have excluded the node, included it in another zwave network and the same results. Now it is back included in the network were it should be but still no actual result and changes in config result in crashing domoticz
korniza
Domoticz version: V3.6028
Postby korniza » Sunday 01 January 2017 11:44
happy new year! :D
I am on the same situation on v3.6277. System keep crashing after the update.
There was no change before that on configurations. When I found that, I tired to update open-zwave with the latest version (1.4-2282-gc286b14-dirty) .
the last lines I see is the following:
2017-01-01 11:36:51.330 Info, Node037, Response RTT 82 Average Response RTT 87
2017-01-01 11:36:51.330 Info, Node037, Received SensorMultiLevel report from node 37, instance 1, Power: value=0.5W
2017-01-01 11:36:51.331 Detail, Node037, Refreshed Value: old value=0.5, new value=0.5, type=decimal
2017-01-01 11:36:51.331 Detail, Node037, Changes to this value are not verified
2017-01-01 11:36:51.331 Detail, Node037,   Expected reply and command class was received
2017-01-01 11:36:51.331 Detail, Node037,   Message transaction complete
2017-01-01 11:36:51.331 Detail, Node037, Removing current message
2017-01-01 11:36:51.331 Detail, Node037, Notification: ValueChanged
Node37 is a FIBARO System FGWPE Wall Plug. I have an Aeotec Z-Stick S2 as zwave interface.
Another safe conclusion is crashing has to do with zwave beacase on the slave system that there is no z-wave interface, latest version working stable.
>>>> Google Home <<<<<
remb0
Postby remb0 » Thursday 12 January 2017 12:06
finnaly it works! I pushed the button a few seconds so the sensor was not sleeping anymore. then I could change the parameter.
leoncornelissen
Postby leoncornelissen » Monday 23 January 2017 23:25
Ah Remb0,
Thanks for this suggestion, I pressed it several times a couple of seconds and now it is working!
thanks
Return to “Bugs and Problems”
