update switch without action
poudenes
Domoticz version: 3.8993
Post by poudenes » Thursday 01 November 2018 12:36
Hi All,
Lost it... How can i update a switch or bulb without the actual actoin to turn it on or off?
Cheers,
Peter
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
Target OS: Raspberry Pi
Re: update switch without action
Post by waaren » Thursday 01 November 2018 13:56
Hi All,
Cheers,
Peter
viewtopic.php?f=4&t=24037&p=185345&hili ... ed#p185333
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
poudenes
Post by poudenes » Thursday 01 November 2018 15:22
waaren wrote:
Hi All,
Cheers,
Peter
You are the master! Thanks
Verzonden vanaf mijn iPhone met Tapatalk Pro
poudenes
Post by poudenes » Saturday 03 November 2018 10:01
Maybe a idea to implement this into dzvents?
Then it's easy to use instead of a http link
Cheers
Post by waaren » Saturday 03 November 2018 10:56
Maybe.., If you can describe the situation for what it would be used .
poudenes
Post by poudenes » Saturday 03 November 2018 12:11
In My situation: I turn on a group of bulbs (bulbAll) and 1 of the bulbs i turn into a different color. Faster then turn every bulb separate first and change color.
But when i change the color of 1 bulb the BulbAll device goes off ( have the BulbAll as slave in my other bulbs because when 1 of the bulbs in the group is go off then BulbAll must go off as well(not all bulbs are on)
So i want a action when BulbAll goes on, change 1 bulb inside the group then Turn on BulbAll device only without action.
I have some triggers based on BulbAll. Or i need to change the trigger and look to Bulb1 Bulb2 and Bulb3 is on or off.
Post by waaren » Saturday 03 November 2018 15:29
What happens if you add the option .silent() in the dzVents command that changes the color?
poudenes
Post by poudenes » Tuesday 06 November 2018 21:54
No is not working.
