Persistent (global)data save Time()
Freemann
Target OS: Raspberry Pi
Domoticz version: >=Béta
Post by Freemann » Monday 18 June 2018 12:30
I'm struggeling a bit with the following case;
I want to have the last time a device is switch ON and in most case the last ON time is not equal to the lastUpdate property.
So I decided to save the Time() to an (global)data variable, but that isn't working.
Look like dzVents is not saving the Time() object when doing something like:
domoticz.globalData.BadkamerLastMotionOn = Time()
or
domoticz.data.BadkamerLastMotionOn = Time()
both variables are define in OR global_data.lua OR in the script itself.
Is this a known "bug" and/or has somebody an idea how to save the last ON time to persistent storage?
Domotica/graphs "freak" :)
Rpi3
Amazon Alexa (2 Echo Dots)
Aeotec Z-Stick S2(Gen5)
HarmonyElite
ETHRelayBoard
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
dannybloe
Re: Persistent (global)data save Time()
Post by dannybloe » Monday 18 June 2018 12:37
Don't save the Time object but just the raw value. If you use historical=true with persistence you automatic get a time stamp on your data. So, define your persistent variable with history = true and maxItems = 1 and simply store the state value in there. Then you can easily read the time stamp of the current value. Check the documentation about historical data.
Freemann
Post by Freemann » Monday 18 June 2018 13:25
So easy... (zo simple)
Hero (HELD)!!
Rpi3
HarmonyElite
ETHRelayBoard
IP-Cam
Post by waaren » Monday 18 June 2018 16:47
So I decided to save the Time() to an (global)data variable.
or
... has somebody an idea how to save the last ON time to persistent storage?
Just for completeness; dzVents is capable of storing the time object in persistent storage.
see example code and resulting datafile
-- timeTest.lua
    on      =   {    devices         =   { "timeTriggerDevice"}},
    data    =   {   currentTimeTable = { initial = "" },
                    nextTimeTable    = { initial = "" },
                    nextTimeValue    = { initial = "" }},
    execute = function(dz, trigger)
            dz.data.currentTimeTable = os.date('*t')   -- Now as table
            dz.data.nextTimeTable = os.date("*t",os.time(dz.data.currentTime)+3600)  -- now + 1 hour as table
            dz.data.nextTimeValue = os.date("%c",os.time(dz.data.currentTime))  -- now as string
__data_timeTest.lua
-- Persistent Data
local multiRefObjects = {
} -- multiRefObjects
local obj1 = {
        ["nextTimeValue"] = "Mon Jun 18 16:39:49 2018";
        ["nextTimeTable"] = {
                ["min"] = 39;
                ["hour"] = 17;
                ["sec"] = 49;
                ["day"] = 18;
                ["isdst"] = true;
                ["wday"] = 2;
                ["yday"] = 169;
                ["month"] = 6;
                ["year"] = 2018;
        ["currentTimeTable"] = {
                ["min"] = 39;
                ["hour"] = 16;
                ["sec"] = 49;
                ["day"] = 18;
                ["isdst"] = true;
                ["wday"] = 2;
                ["yday"] = 169;
                ["month"] = 6;
                ["year"] = 2018;
return obj1
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
dannybloe
Post by dannybloe » Monday 18 June 2018 18:20
Yes but it is not needed as I explained above. You can however extract the raw time string and store that and feed that back into Time() when you need it again.
Freemann
Post by Freemann » Sunday 08 July 2018 21:59
So to "reuse" this topic;
Trying to make my variables global available, but not getting there.
how should I use the global define variables for getting/setting in my scripts?
Tried some variations like;
for setting:
domoticz.globalData.motionVar.add('Foo')
domoticz.globalData.motionVar = 'On'
domoticz.data.motionVar.add('Foo')
domoticz.data.motionVar = 'On'
I'm not getting the __data_global_data.lua to show data...
and should I define the global_data vars in my "local" scripts again?
[SOLVED] and maybe it can help somebody
found it after some "testing/debugging";
global_data.lua looks like;
data = {
      LastMotionOn = { history = true, maxItems = 1}
normal dzvents script is doing for historical setting;
domoticz.globalData.LastMotionOn.add('On')
normal dzvents script is doing for historical getting;
domoticz.globalData.LastMotionOn.get(1).time.secondsAgo
Rpi3
HarmonyElite
ETHRelayBoard
IP-Cam
