DzVents updates
DomoArigato
DzVents updates
Post by DomoArigato » Tuesday 29 May 2018 22:27
Hi little helpers :)
Working on dzVents 2.4.1. on domoticz beta 3.9390.
Would it be possible to upgrade to dzVents latest version (think 2.4.6.) by just grabbing the files from github and copy them in my dzVents folder?
Or would I have to update to latest available domoticz beta?
Thanks a lot for some insights.
And might dzVents be with us ....:)
Target OS: Raspberry Pi
Re: DzVents updates
Post by waaren » Tuesday 29 May 2018 22:45
Please don't !
It might (and probably will) break stuff in places where you would least expect it (or if you expect that it will break stuff at most places you are probably right :D )
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
DomoArigato
Re: DzVents updates
Post by DomoArigato » Tuesday 29 May 2018 22:56
Ok ok.
Sounds like it was not my best idea.
So I better update only together with domoticz version. :?
Thanks for the quick warning. :D
dannybloe
Re: DzVents updates
Post by dannybloe » Wednesday 30 May 2018 8:13
Yes, more often than not, dzVents and Domoticz go hand in hand. For instance, dzVents 2.4.6 that has just been merged into the current beta uses a new property that is passed from Domoticz to dzVents. If you use 2.4.6 with an older version of Domoticz this property is not available and dzVents will break. Scrips won't run.
Reason: 2.4.7 should be 2.4.6
DomoArigato
Re: DzVents updates
Post by DomoArigato » Thursday 31 May 2018 23:41
Thanks a lot for the additional explanation.
And again a BIG thanks to you @dannybloe for this great scripting ‘engine’! VERY good work!
DzVents gives domoticz another highly competitive feature! With this combination you created something others do not have. I came from the Fibaro HC and that was already good in scripting flexibility but domoticz with dzVents is another level!
Well done. Good job!
