Can this script made smarter / better
Boredcat
Target OS: Raspberry Pi
Domoticz version: 3.9639
Post by Boredcat » Sunday 15 April 2018 16:03
If have created the following script, which flash 2 yeelights and the Xiaomo gateway. Also it plays a sound using the Xiaomi gateway.
It is triggered with the TEST SW (a dummy switch which is activated by several PIR's).
The script works, but I think that the scripts can be made smarter of shorter.
Any tips ?
		devices = {
			'TEST SW'
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
		domoticz.log('Executing alarm sound and light', domoticz.LOG_INFO)
		local light = domoticz.devices('XIAOMI LIVING ROOM')
		local alsw  = domoticz.devices('TEST SW')
		local light1 = domoticz.devices('Lamp bank links')
		local light2 = domoticz.devices('YeeLight LED Bank')
		local alarmsound = domoticz.devices('Xiaomi Doorbell')
		local alarmlevel = domoticz.devices('GW Xiaomi Volume')
		if device.state == 'On' then
		    -- Set alarm sound and level 100%
		    alarmlevel.dimTo(100)
		    -- alarmsound.switchSelector(50)
		    -- End set sound level
		    -- Start alarm lights
		    light.dimTo(100)
		    light.setRGB(255,0,0).afterSec(10)
		    light.setRGB(0,0,255).afterSec(9)
		    light.setRGB(255,0,0).afterSec(8)
		    light.setRGB(0,0,255).afterSec(7)
		    light.setRGB(255,0,0).afterSec(6)
		    light.setRGB(0,0,255).afterSec(5)
		    light.setRGB(255,0,0).afterSec(4)
		    light.setRGB(255,0,0).afterSec(3)
		    light.setRGB(0,0,255).afterSec(2)
		    light.setRGB(255,0,0).afterSec(1)
		    light1.dimTo(100)
		    light1.setRGB(255,0,0).afterSec(10)
		    light1.setRGB(0,0,255).afterSec(9)
		    light1.setRGB(255,0,0).afterSec(8)
		    light1.setRGB(0,0,255).afterSec(7)
		    light1.setRGB(255,0,0).afterSec(6)
		    light1.setRGB(0,0,255).afterSec(5)
		    light1.setRGB(255,0,0).afterSec(4)
		    light1.setRGB(255,0,0).afterSec(3)
		    light1.setRGB(0,0,255).afterSec(2)
		    light1.setRGB(255,0,0).afterSec(1)
		    light2.dimTo(100)
		    light2.setRGB(255,0,0).afterSec(10)
		    light2.setRGB(0,0,255).afterSec(9)
		    light2.setRGB(255,0,0).afterSec(8)
		    light2.setRGB(0,0,255).afterSec(7)
		    light2.setRGB(255,0,0).afterSec(6)
		    light2.setRGB(0,0,255).afterSec(5)
		    light2.setRGB(255,0,0).afterSec(4)
		    light2.setRGB(255,0,0).afterSec(3)
		    light2.setRGB(0,0,255).afterSec(2)
		    light2.setRGB(255,0,0).afterSec(1)
		    -- Switch off alarm sound and light after 11 seconds. Also switch off alarm switch (alsw). AlSW will be activated againif motion is detected
		    light.switchOff().afterSec(11)
		    light1.switchOff().afterSec(11)
		    light2.switchOff().afterSec(11)
		    alsw.switchOff().afterSec(11)
		    alarmsound.switchSelector(0).afterSec(11)
RFXCom(E) - Yeelight Lights - KaKu / Alexa HA Bridge
Windows 2012 / Windows 2012R2 / Xpenology/ Pi 3 / Milight / Home build ESP8266 / Sonoff
Re: Can this script made smarter / better
Post by waaren » Sunday 15 April 2018 21:15
Any tips ?
you can make it shorter (see attached).
		devices = {
			'TEST SW'
		    light.dimTo(100)
		    light1.dimTo(100)
		    light2.dimTo(100)
			for i = 10,1,-1 do
				if i % 2 == 0 then
					light.setRGB(255,0,0).afterSec(i)
					light1.setRGB(255,0,0).afterSec(i)
					light2.setRGB(255,0,0).afterSec(i)
					light1.setRGB(0,0,255).afterSec(i)
					light2.setRGB(0,0,255).afterSec(i)
					light3.setRGB(0,0,255).afterSec(i)
		    light0.setRGB(0,0,255)
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
Boredcat
Post by Boredcat » Monday 16 April 2018 16:34
@Waaren,
Thanks for you input
Had to lookup the Lua Operators for % (didn't know that one).
Ries
Post by Ries » Wednesday 13 June 2018 19:52
A lot of redunancy. all three lights undergo the same actions by the looks of it.
You could array the lights, instead of light, light1, light2 you could say light[0], light [1] and light[2], then create a loop like
i =0
repeat
— your code light[ i].switchOn()
i=i+1
Until i=2
Version 3.9639
Platform: Jessie lite
Hardware: Raspberry pi 3B; RFXCOM; Weather Underground; Dummy; OpenZwave USB; Fritzbox Callmonitor via LAN interface; System Alive Checker (Ping); Philips Hue Bridge; Atag One Thermostat
Boredcat
Post by Boredcat » Friday 22 June 2018 8:51
i =0
repeat
i=i+1
Until i=2
Making my script not smarter but more efficient. Thnx for the idea, never thought of the idea of creating an array. Will use this in more scripts.
