getAtTime('0:20:00')
MartinF
Target OS: Raspberry Pi
Post by MartinF » Wednesday 28 February 2018 9:35
Hi, I am a total newbie trying to get the historical temperature from a DS9490r 1-wire device. I've been fooling around with getAtTime('0:20:00') but no matter how I do it, I always arrive at errors with regard to nil values. I guess it's both a matter of syntax and variable scope. Some relevant sample code would be highly appreciated!
dannybloe
Re: getAtTime('0:20:00')
Post by dannybloe » Wednesday 28 February 2018 10:48
Well, for starters, post your code and the errors you get.
MartinF
Post by MartinF » Wednesday 28 February 2018 18:21
Ok, here is my last try, which resulted in "attempt to index global 'vedpanna_20' (a nil value)"
        timer = { 'every minute' }
	data = {
    vedpanna = { history = true, maxItems = 25, maxMinutes = 25 }
        vedpanna = domoticz.devices('Vedpanna')
        vedpanna_20 = domoticz.data.vedpanna.getAtTime('0:20:00')
        domoticz.log('vedpanna_temp: ' .. vedpanna.temperature)
        domoticz.log('vedpanna_20_temp: ' .. vedpanna_20.temperature)
dannybloe
Post by dannybloe » Thursday 01 March 2018 9:40
Ok, first of all, if you create a new variable always define it as local: local vedpanna = ... as you are polluting the global scope which may affect other scripts.
So, regarding your problem. As soon as you define the (historical) variable vedpanna its initial data is empty. So, when you do this for the first time
it will return nill. So vedpanna_20 is nill and when you try to do vedpanna_20.temperature Lua will tell you: "attempt to index global 'vedpanna_20' (a nil value)".
So, you will have to check if domoticz.data.vedpanna is empty (or .getAtTime() returns nil)) before you start doing something with it. In other words: fill it first before taking something out:
	data = {
		vedpanna = { history = true, maxMinutes = 25 }
		local currentTemp = domoticz.devices('Vedpanna').temperature
		-- add temperature to the history
		domoticz.data.vedpanna.add(currentTemp)
		local tempMinus20 = domoticz.data.vedpanna.getAtTime('0:20:00') -- returns the temperature
		domoticz.log('current temperature: ' .. currentTemp)
		domoticz.log('temperature 20mins ago: ' .. tempMinus20)
Note that I put the temperature in the history and not the entire device. That's way too much data to put in there. Just put in there what you need.
Also, note that getAtTime() only becomes relevant if there is enough data collected. So the first 20 minutes of logging will not give you the temperature at 20 minutes ago.
MartinF
Post by MartinF » Thursday 01 March 2018 19:30
What I didn't grasp was that I would have to log the data myself, it makes no sense that you can't access the historical data in the Domoticz database.
However, your suggested script has been running for way over 20 minutes now and all I get is currentTemp and "attempt to concatenate local 'tempMinus20' (a nil value)".
Post by waaren » Friday 02 March 2018 8:20
@MartinF, could you try this ?
Temptest
	on = {  timer = { 'every minute' } },
	data = { vedpanna = { history = true, maxMinutes = 25 } },
	execute = function(domoticz, _)
		local currentTemp  = domoticz.devices('Vedpanna').temperature or 'fail'
		local historyTemp   = domoticz.data.vedpanna
		local historyOldest  = historyTemp.getOldest().time.minutesAgo or 0
		local tempMinus2    = "Not in history yet"
		local tempMinus20  = "Not in history yet"
		if currentTemp ~= 'fail' then
			historyTemp.add(currentTemp)
			if historyOldest > 2 then
				tempMinus2 = historyTemp.getAtTime('0:02:00').data -- returns the temperature
				if historyOldest > 21 then
					tempMinus20 = historyTemp.getAtTime('0:20:00').data -- returns the temperature
			print ( 'Current temperature: ' .. currentTemp)
			print ( 'Temperature 2 minutes ago: ' .. tempMinus2)
			print ( 'Temperature 20 minutes ago: ' .. tempMinus20)
			print ( 'Average temperature: ' ..  historyTemp.avg())
			print ( 'Oldest temperature in history: ' ..  historyTemp.getOldest().data)
			print ( 'Oldest time stamp in history: ' ..  historyTemp.getOldest().time.getISO())
			print ( 'Minutes of data in history: ' .. historyOldest)
			print ( 'Last added temperature in history: ' ..  historyTemp.getLatest().data)
			print ( 'Number of entries in History: ' ..  historyTemp.size)
			print ( 'Skipped adding temperature to history (Wrong temperature reading) ' )
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
MartinF
Post by MartinF » Friday 02 March 2018 9:32
Thank you Waaren, works like a clock!
I now understand that the errors were not handled, script aborted and no data stored. And that getAtTime is a table with data in the .data variable.
I actually made a workaround without getAtTime. It notifies me when it's time to put more firewood in the boiler and how much it'l take without boiling:
local Time = require('Time')
local lastTime = Time('2017-12-31 00:00:01')
		timer = { 'every 5 minutes' }
	data = {
        local availableStorage = tonumber(domoticz.devices('Utrymme i tankarna').rawData[1])
        local Ready=1
        local now = Time()
		local tempMinus5, index = domoticz.data.vedpanna.get(1)
		local tempMinus20, index = domoticz.data.vedpanna.get(4)
		local number, index = domoticz.data.vedpanna.size
		domoticz.log('Last time: ' .. lastTime.hoursAgo..' hours ago' )
		domoticz.log('Number: ' .. number)
		domoticz.log('')
		domoticz.log('Current temperature: ' .. currentTemp)
		if tempMinus5 ~= nil then
		    domoticz.log('Temperature idx=1: '..tempMinus5.time.minutesAgo.. ' minutes ago: ' .. tempMinus5.data)
		    Ready=0
		if tempMinus20 ~= nil then
		    domoticz.log('Temperature idx=4: '..tempMinus20.time.minutesAgo.. ' minutes ago: ' .. tempMinus20.data)
		    Ready=0
		domoticz.log('Available storage '..availableStorage)
		if (Ready==1) then
		    if (    currentTemp < tempMinus20.data
		        and tempMinus20.data > tempMinus5.data
		        and currentTemp < tempMinus5.data
		        and currentTemp > 70
		        and currentTemp < 80
		        and availableStorage > 0.5)
		        and lastTime.hoursAgo >= 2 then
		    domoticz.notify('Fyll ' .. availableStorage ..' pannor med ved!')
		    lastTime=now
		domoticz.log('')
dannybloe
Post by dannybloe » Friday 02 March 2018 9:51
Yeah I forgot the .data attribute.. my bad :roll: Created it myself.. how could I forget...
MartinF
Post by MartinF » Friday 02 March 2018 10:57
:-) Thanks!
