idea for device within a timer
poudenes
Domoticz version: 3.8993
Post by poudenes » Thursday 22 February 2018 10:44
Hi All,
I have some scripts that triggered by follow
        timer = {'at nighttime'},
        devices = {SensorMasterBedroom},
Maybe its a idea to add the device into the timer. So that device will only triggered within the timer. This example when its nighttime
Now it triggered always on the Sensor but does't do his actions. I see lots of log lines that are unnecessary.
cheers,
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
dannybloe
Target OS: Raspberry Pi
Re: idea for device within a timer
Post by dannybloe » Thursday 22 February 2018 13:43
Check the docs: devices = { 'SensorMasterBedroom' = { 'at nighttime' } }
poudenes
Post by poudenes » Thursday 22 February 2018 13:47
Thanks, i was playing with that option but didn't find out the right way.
Thanks again for helping !!! :D
poudenes
Post by poudenes » Friday 23 February 2018 0:20
It is working but not the way how i expected. When sensor turn on it wait for when the time change 1 minute then it turn on the lights.
When sensor goes of it wait again to turn off the lights
dannybloe
Post by dannybloe » Friday 23 February 2018 9:18
I can say that, given the current state of how everything works, this is technically impossible. When the device gets an update it immediately triggers the event system and dzVents will check if the current time is matching the 'at nighttime' rule. If that's the case then the event script is called immediately. There is no code in dzVents that can put the event on hold until the start of the minute. As a matter of fact, I just tested it. So.. having said that I can only conclude that the event is only raised every minute. Perhaps your sensor only reports to Domoticz every minute or your trigger rules in your script are not correct.
Btw, the rule above should be like (with the square brackets) but your probably already knew that:
devices = {
   { ['SensorMasterBedroom'] = { 'at nighttime' } }
Maybe you can post the entire script here.
poudenes
Post by poudenes » Friday 23 February 2018 10:31
I tried lot of things and now it working.
devices = {[SensorMasterBedroom] = { 'at nighttime' }},
This was the line for me to let it work.
Here the full script
local Version               = '18.02.22'
local SensorMasterBedroom	= 529
local MasterBedroom		    = 7
local SwitchGoodnight   	= 65
    active = true,
    logging = {marker = 'SLAAPKAMER Sensor ' ..Version..'......'},
    if
    domoticz.devices(SensorMasterBedroom).active and
    domoticz.devices(SwitchGoodnight).state == 'Off'
    then
        domoticz.devices(MasterBedroom).dimTo(100)
        domoticz.devices(MasterBedroom).setKelvin(5000)
    elseif
    domoticz.devices(SensorMasterBedroom).toggleSwitch() and
    domoticz.devices(MasterBedroom).active and
    then
        domoticz.devices(MasterBedroom).dimTo(1)
        domoticz.devices(MasterBedroom).switchOff().afterSec(1)
dannybloe
Post by dannybloe » Friday 23 February 2018 10:57
	execute = function(domoticz, sensor)
		local goodnightSwitch = domoticz.devices(SwitchGoodnight)
		local light = domoticz.devices(MasterBedroom)
		if (sensor.active and not goodnightSwitch.active) then
			light.dimTo(100)
			light.setKelvin(5000)
		elseif (light.active and not goodnightSwitch.active) then
			light.dimTo(1)
			light.switchOff().afterSec(1)
You had a 'domoticz.devices(SensorMasterBedroom).toggleSwitch()' in your elseif statement and that is not correct as the function toggleSwitch() doesn't return anything (nil basically so your elseif will always fail).
Untested of course ;-)
poudenes
Post by poudenes » Friday 23 February 2018 11:07
Hmm... because its was working :).
Your script is working also. Look nicer :)
I have to learn a lot :) every time little bit more haha
If i understand it correct. execute = function(domoticz, sensor) refer to everything thats in devices = {[SensorMasterBedroom] = { 'at nighttime' }} ?
So if i put 2 devices in it then sensor.active will check if those devices are both active?
			light.dimTo(100)
			light.dimTo(1)
