Electric (instant+counter) - Domoticz doesn't compute Energy
jake
Target OS: Raspberry Pi
Post by jake » Friday 09 February 2018 9:45
I'm feeding an 'Electric (instant + counter)' device only with the (generated) power.
device.updateElectricity(power in watts)
I would like Domoticz to do the calculation of energy. Although showing/tracking the power value during the day, the Energy counter stays 0, day after day.
I know it can work, because my micro-inverters of the solar panels update themselves (power only) through a json command to the same type of virtual device and there the Domoticz computing of Energy is very reliable.
I tried it to feed the device like this:
device.updateElectricity(power in watts, 0)
but this doesn't help. Or
device.updateElectricity(power in watts, '')
but that gives an error.
dannybloe
Re: Electric (instant+counter) - Domoticz doesn't compute Energy
Post by dannybloe » Friday 09 February 2018 18:28
I suspect this is a Domoticz problem. I'm only setting the commandArray and send that back to Domoticz.
jake
Post by jake » Friday 16 March 2018 23:00
In this topic a possible solution was given to let the electrical device compute energy properly, by feeding the device through json.
To test this I used 2 virtual 'Electrical (counter + incremental)' sensors. The 1st one is fed by this dzVents command:
local currentpower = (inv1.WhActual + inv2.WhActual + inv3.WhActual + inv4.WhActual + inv5.WhActual)
totSolar.updateElectricity (currentpower,0)
The 2nd one is fed by this json command in dzVents:
local solarUrl = 'http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=295&nvalue=0&svalue='..currentpower..';0'
		domoticz.openURL({
			url = solarUrl,
			method = 'GET'
the 2nd sensor is being updated by the json command and after sometime it starts to count/compute energy as well.
2 days later I started updating the 1st sensor as well with the json command: within a short time the device started to compute energy.
Summarizing: something is going on with the LUA code to update the electrical device, while through json it works as expected.
McMelloW
Domoticz version: V3.beta
Post by McMelloW » Saturday 17 March 2018 1:44
If this is a Domoticz problem, who can we contact to look at it? There are several topics about it and an issue #2196 is openeded. But nothing so far.
Greetings McMelloW
jake
Post by jake » Friday 23 March 2018 21:29
The 1st sensor 'computed' energy for 2 days. Both days had exactly the same 'Energy' harvest. Ths is incorrect. On day 3 the sensor didn't compute anymore.
The 2nd sensor keeps computing correctly.
Something is completely screwed with counters. I have the same kind of problems with counting in m3 gas. I simply can't get my finger behind it, but values are not correct.
mraichura
Domoticz version: 3.8153
Post by mraichura » Friday 22 June 2018 12:20
Hello All,
I'm receiving total current load via MySensors and voltage from a Sonoff POW. I then created a dummy sensor as follows
Idx: 46
Sensor Type: Electric (Instant + Counter)
Type: Usage
Energy Read: Computed
The power wattage is calculated in Node-Red and sent to Idx: 46 via MQTT. The payload is as follows.
    "idx": 46,
    "nvalue": 0,
    "svalue": "5191;0.000"
It was working fine from June 6 until a couple of hours ago. Now, the sensor value in Watts is visible but computed Energy usage (Total & Today) show nan.
Any help?
1 x RASPBERRY PI 1 MODEL B+ running Domoticz since June 2016
1 x RASPBERRY PI 3 MODEL B running Domtoicz since August 2017
gajotnt
Domoticz version: V4.9700
Post by gajotnt » Tuesday 04 September 2018 13:44
Hello, is there any news on this?
I also have a dummy that doesnt compute the energy usage right. Using a lua script to update the counter.
Dont know how to use the comands posted above :(
