Events at startup
candrea77
Target OS: Raspberry Pi
Domoticz version: 3.8153
Events at startup
Post by candrea77 » Friday 20 October 2017 10:53
Dear forum users,
I wonder if using dzVents we are able to trigger a script in order to get it run only 1 time at startup.
Thank you for your attention
Inviato dal mio SM-G920F utilizzando Tapatalk
Sorry for any spelling mistake, English is not my native language.
DomoticZ running on Raspberry PI 3 Model B , with Raspbian Jessie Lite ,Monit , Ramfs, and Persistent USB device
SweetPants
Domoticz version: V3.9639
Re: Events at startup
Post by SweetPants » Friday 20 October 2017 15:04
What are you trying to achieve?
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
dannybloe
Post by dannybloe » Saturday 21 October 2017 0:57
You can. You can use a timer script and a condition that checks the domoticz.startTime. Only run when startTime is less than two minutes ago.
dannybloe
Post by dannybloe » Saturday 21 October 2017 0:58
In the future I want to support system events.
candrea77
Post by candrea77 » Saturday 21 October 2017 20:13
Mmmm ... what is this "domoticz.startTime" ..... I'm using stable version ... is present here ?
dannybloe
Post by dannybloe » Saturday 21 October 2017 20:21
No. You need the beta.
candrea77
Post by candrea77 » Saturday 21 October 2017 22:22
dannybloe wrote:No. You need the beta.
Ok. Thank you
salvacalatayud
Domoticz version: 3.8072
Post by salvacalatayud » Wednesday 31 January 2018 15:34
This can be great, with this you can set milght to switch off after start up, as they turn on after plugged and this happens in case of a cut of electricity.
I have no idea of dzvents, if someone can give a light on code would be useful.
Enviado desde mi Redmi 4X mediante Tapatalk
Post by waaren » Thursday 01 February 2018 4:40
Please have a look at the script below. Maybe not the optimal solution but it does the job as expected.
	active when function returns true ( domoticz started less then 180 seconds ago )
	The defined tasks will only execute once after domoticz started.
	Please note that this is not a failsafe way of handling this.
	If domoticz crashes / is stopped after the first excution of this script and before 120 seconds after
	it started, the Executed value is not set back to 0 and the script needs to be reloaded to reset the persisitent data.
	If domoticz starts extremely slow, in theory it could be that this script will not be evaluated before the 180 seconds
	after startup has passed. On my test system (PI-3), first execution is well within that window. (somewhere between 13 and 60 seconds)
	active = function(domoticz)
			  return domoticz.startTime.secondsAgo < 180
			end,
    on 		= {  	timer 		= { 'every minute'  } },
	data 	= { 	Executed 	= { initial = 0 } },
    execute = function(domoticz)
		if domoticz.data.Executed == 0 then
			domoticz.data.Executed = domoticz.startTime.secondsAgo
			local minute=60
			local hour=60*minute
			local day=24*hour
			local seconds = domoticz.systemUptime
			local days = math.floor(seconds/day)
			seconds = seconds - days * day
			local hours = math.floor(seconds/hour)
			seconds = seconds - hours * hour
			local minutes = math.floor( seconds/minute )
			seconds = seconds - minutes * minute
			-- [DEFINE YOUR TASKS HERE]
			print ("System active time: " .. tostring (days) .. " days, " .. tostring(hours) .. " hours and " .. tostring(minutes) .. " minutes." )
			print ("Domoticz started " .. tostring (domoticz.startTime.secondsAgo) .. " seconds ago. I will do the startup tasks")
			print ("Älready executed; " .. tostring(domoticz.data.Executed) .. " seconds after domoticz started.")
			if domoticz.startTime.secondsAgo > 119 then
				domoticz.data.Executed = 0
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave , dzVents 2.4.n, Amazon echo
dannybloe
Post by dannybloe » Thursday 01 February 2018 9:03
I'm planning to have system events for a future version of dzVents like
    system = {'start', 'error'}
salvacalatayud
Post by salvacalatayud » Friday 02 February 2018 13:47
			end,
			local minute=60
			local day=24*hour
Thanks a lot, I'll try as soon as I can
