Timer events start on the hour, every hour  [Solved]
Target OS: Raspberry Pi
Post by waaren » Tuesday 10 January 2017 15:43
I use dzVents on my Synology 916+ (DSM6.1) with Domoticz version 3.6312 for a number of scripts. It's working great and simplifies the coding efforts a lot.
Looking at Domoticz logfile, I noticed that all my time based dzVents scripts are executed on the hour every hour, including the scripts with a timer setting in minutes that should not run on the hour (or I at least I did not expect it to do so)
Is this as designed or do I overlook something ?
Dishwasher.lua: ['timer'] = 'every 16 minutes'
Washer.lua: ['timer'] = 'every 17 minutes'
Blinds.lua: ['timer'] = 'every 29 minutes'
2017-01-10 12:00:00.546 LUA: >>> Handler: Dishwasher
2017-01-10 12:00:00.546 LUA: >>> Handler: Washer
2017-01-10 12:00:00.547 LUA: >>> Handler: Blinds
2017-01-10 13:00:00.153 LUA: >>> Handler: Dishwasher
2017-01-10 13:00:00.154 LUA: >>> Handler: Washer
2017-01-10 13:00:00.155 LUA: >>> Handler: Blinds
and
2017-01-10 13:16:00.205 LUA: >>> Handler: Dishwasher
2017-01-10 13:32:00.149 LUA: >>> Handler: Dishwasher
2017-01-10 13:48:00.401 LUA: >>> Handler: Dishwasher
2017-01-10 14:00:00.089 LUA: >>> Handler: Dishwasher
2017-01-10 14:16:00.443 LUA: >>> Handler: Dishwasher
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave , dzVents 2.4.n, Amazon echo
Re: Timer events start on the hour, every hour
Post by waaren » Wednesday 11 January 2017 0:45
That is a very good summary indeed.
dannybloe
Post by dannybloe » Wednesday 11 January 2017 10:35
Indeed it was :mrgreen: Looking at the code:
	function self.isTriggerByMinute(m, testTime)
		local time = self.getNow(testTime)
		return (time.min / m == math.floor(time.min / m))
It sees if time.min can be devided by the interval (m). Of course that is bs :lol:
Ehm... now finding a solution that doesn't require state is kinda hard. So... if you have any ideas..
dannybloe
Post by dannybloe » Wednesday 11 January 2017 12:13
I could use the script storage solution that is being used by the persisted variables. Anyhow... in the coming days/weeks I don't think I have time to fix this (some house reconstruction work that needs to be finished first). But I will make a github ticket for this.
In the meantime I'd stick to intervals that do work given the current algorithm.
Post by waaren » Thursday 12 January 2017 1:02
Thx gordonb3 and dannybloe for looking into this. Much apreciated
dannybloe
Re: Timer events start on the hour, every hour  [Solved]
Post by dannybloe » Thursday 12 January 2017 16:11
dannybloe wrote:I could use the script storage solution that is being used by the persisted variables. Anyhow... in the coming days/weeks I don't think I have time to fix this (some house reconstruction work that needs to be finished first). But I will make a github ticket for this.
Or you create a s.tload of ['timer'] = 'at xx:xx' entries around the clock of course. Then it will only skip a beat at 00:00 probably.
Post by waaren » Friday 13 January 2017 16:29
@dannybloe Thanks. As a workaround I created some ['timer'] = 'at xx:xx' entries which, as a side effect, effectively lowered the number of calls to the scripts as I could narrow them to the hours I actually need.
Users browsing this forum: devros and 2 guests
