Help with some scripting with the P1
Derik
Target OS: Raspberry Pi
Post by Derik » Monday 13 November 2017 21:08
Dear all..
Is there some one that can make dzvent working for my P1 actual
I try to get a script for my P1, when i deliver back to to the net, with my solar panels.
With blockley i cannot go to minus..
So what i an looking for:
When time is between x and y
when p1 actual is -500 and dummy X is off, switch dummy X on.
when p1 actual is >500 and dummy X is on, switch dummy off
Only i do not understand the dzvents script..
So hope someone help me.
xxx
I get the first reaction from emme:
uhm.. let's try:
		timer = {
			'between x and y'
		devices = {
			'P1'
	execute = function(domoticz, devP1)
	    local dummy = domoticz.devices('dummy')
		if tonumber(devP1.rawData[1]) > 500 and dummy.state == 'Off' then
		    dummy.switchOn()
		elseif tonumber(devP1.rawData[1]) < -500 and dummy.state == 'On' then
		    dummy.switchOff()
I'm using rawData since I'm unsure what kind of device P1 is :P :P ciao M
P.S.
we can clean the code by not chasing the dummy switch state:
CODE:
if tonumber(devP1.rawData[1]) > 500 then
		    dummy.switchOn().checkFirst()
		elseif tonumber(devP1.rawData[1]) < -500  then
		    dummy.switchOff().checkFirst()
Derik
Re: Help with some scripting with the P1
Post by Derik » Monday 13 November 2017 21:39
Do have now:
https://drive.google.com/file/d/1PBCj8P ... sp=sharing
And this my P1:
https://drive.google.com/file/d/1sBuL6o ... sp=sharing
With the data of the P1:
https://drive.google.com/file/d/1i3LG5E ... sp=sharing
And the code i did change: [ Hope did this ok..:-) ]
		timer = {
			'between 08:00 and 22:00'
		devices = {
			'D.M. P1: Stroom'
	    local dummy = domoticz.devices('Dummy P1')
		    dummy.switchOn()
		    dummy.switchOff()
The code is not working:
https://drive.google.com/file/d/1q4WBKP ... sp=sharing
And the only thing in the log is:
https://drive.google.com/open?id=1X1THa ... AW-kiUM3ah
Hope you will help me.
emme
Domoticz version: latest
Post by emme » Monday 13 November 2017 22:11
ok.. the code is probably running and since there is no debug, neither error, it could be that the conditions are NOT invoked
that's probably because your D.M. P1: Strom is a combined device and rawData[1] returns ALL values string....
Since it is an Energy device... try to replace the .rawData[1] to .WhActual (that already return a Number value)
I'd also add some debug info....
		timer = {
		devices = {
			'D.M. P1: Stroom'
	    domoticz.log('Here is a useful info: whActual: '..devP1.WhActual..'W',domoticz.LOG_FORCE)
		if devP1.WhActual > 500 and dummy.state == 'Off' then
		    domoticz.log('Switching ON',domoticz.LOG_FORCE)
		elseif devP1.WhActual < -500 and dummy.state == 'On' then
		    domoticz.log('Switching OFF',domoticz.LOG_FORCE)
That's one small step for a programmer, one giant leap for me!
Raspberry Pi3 + AeonStick G5 + RFXCOMM433 + iRTrans Server + NodeJS
There's no stress in the mess!!
Derik
Post by Derik » Monday 13 November 2017 22:40
mmm
Looks it is working: GREAT.
Hope tomorrow when the sun i do his work.
The dummy is going off:
Only did see some errors:
2017-11-13 21:35:59.170 (D.M.: P1) P1 Smart Meter (D.M. P1: Stroom)
2017-11-13 21:35:59.437 dzVents: Info: Handling events for: "D.M. P1: Stroom", value: "8708725;9639761;2777208;6692124;960;0"
2017-11-13 21:35:59.437 dzVents: Info: ------ Start internal script: DZ: Teruglever: Device: "D.M. P1: Stroom (D.M.: P1)", Index: 3185
2017-11-13 21:35:59.439 dzVents: !Info: Teruglever dummy switch : whActual: 960W
2017-11-13 21:35:59.439 dzVents: Info: ------ Finished DZ: Teruglever
2017-11-13 21:36:00.397 (D.M.: Zwave) Usage (Z: Pellet Actueel)
2017-11-13 21:36:00.419 (D.M.: Zwave) General/kWh (Z: Pellet Totaal)
2017-11-13 21:36:00.457 dzVents: Info: ------ Start internal script: DZ: Teruglever:, trigger: between 08:00 and 22:00
2017-11-13 21:36:00.483 Error: dzVents: Error: An error occured when calling event handler DZ: Teruglever
2017-11-13 21:36:00.483 Error: dzVents: Error: ...icz/scripts/dzVents/generated_scripts/DZ: Teruglever.lua:12: attempt to index local 'devP1' (a nil value)
2017-11-13 21:36:00.483 dzVents: Info: ------ Finished DZ: Teruglever
2017-11-13 21:36:00.556 LUA: Winddelen naar P.V.O.
Nill? @ 21:36:00:483
And do i need set the device or time or variable active ? [ on the right side ]
emme
Post by emme » Tuesday 14 November 2017 9:09
mmmh... the timer activation does not provide the devP1 table....
ok.. let's try to redefine it in case of it...
		timer = {
		devices = {
			'D.M. P1: Stroom'
	execute = function(domoticz, devP1, triggerInfo)
		if triggerInfo.type = domoticz.EVENT_TYPE_TIMER then
			devP1 = domoticz.devices('D.M. P1: Stroom')
please note that the script will be fired once a minute between 8.00 and 22.00 and in case of value change of D.M. P1: Stroom device
to avoid it you can check time within the code:
		devices = {
			'D.M. P1: Stroom'
		local Time = require('Time')
		local currentTime = Time()
		if currentTime.hour >= 8 and currentTime.hour <= 22 then
Derik
Post by Derik » Tuesday 14 November 2017 22:31
buzzy with work...
When i do have time is est.
THANKS!!!
Derik
Post by Derik » Sunday 19 November 2017 14:17
Dear Emme,
Did use the latest script...
Only the switch is not going anywhere....
I have this:
And the P1 is in the -
only no active dummy
There is some error i think:
2017-11-19 13:15:21.219 dzVents: !Info: Here is a useful info: whActual: 0W
Because the actual value should be -...
Perhaps use the raw data??
emme
Post by emme » Monday 20 November 2017 9:00
mmmh... it depends on what kind of device is D.M. P1: Stroom...
I though it was a Electricity device, but the icon looks like a counter....
if so... use .counter instead of WhActual and try again
Derik
Post by Derik » Monday 20 November 2017 19:43
Sorry i am a noob in scripts...
Did change to:
Only now i get:
2017-11-20 18:39:59.199 (D.M.: Zwave) General/kWh (Z: Terras)
2017-11-20 18:39:59.513 dzVents: !Info: Here is a useful info: whActual: 18483.514W
2017-11-20 18:39:59.513 Error: dzVents: Error: An error occured when calling event handler DZ: Teruglever 2
2017-11-20 18:39:59.513 Error: dzVents: Error: ...z/scripts/dzVents/generated_scripts/DZ: Teruglever 2.lua:13: attempt to compare string with number
2017-11-20 18:39:59.665 (D.M.: Zwave) Current (Zter: Verwarming)
2017-11-20 18:40:00.481 LUA: D.M.: IP Port check
Where do i go wrong??
Perhaps was the raw data better?
Only i do not how..
emme
Post by emme » Monday 20 November 2017 21:17
you change it good, but I cannot figure out what device is that and how dzvents threat it.... and this is my fault, not yours, neither dzVents
Let's try another method...
instead of .counter try .usage (as a P1 Smart Meter)
this should return a number and would not rise the error on line 13, but in case you still have such error....
try to change:
devP1.usage --> tonumber(devP1.usage)
...well... even counter should return a number...
dannybloe
Post by dannybloe » Tuesday 21 November 2017 8:28
you can try to dump the device info to the logs using devP1.dump(). It shows you all its properties but also which device adapters are in place for that device. The adapters decide what properties and methods are available for that device and they are based on props like deviceType, subType etc.
Derik
Post by Derik » Wednesday 22 November 2017 8:12
mmm Cannot test....
There is no sun to try the switch...
xx
Derik
Post by Derik » Wednesday 17 January 2018 15:20
Guys...
Thanks for all..
This script is not working well:
		devices = {
			'D.M. P1: Stroom'
			domoticz.log('P1 Actuele status: '..devP1.WhActual..'W',domoticz.LOG_FORCE)
			if devP1.WhActual > -10 and dummy.state == 'Off' then
			elseif devP1.WhActual < -10 and dummy.state == 'On' then
It looks that : wHctual is not counting under 0:
Perhaps other rawdata
I can test again with this weather:-)
Solar panels are working
Post by waaren » Thursday 18 January 2018 22:45
Based on the information I see in the switches tab, dump of the P1 device and domoticz/dzVents/runtime/p1_smartmeter_device.lua , I assume that you have to look at usageDelivered which is >= 0
change
to
if devP1.usageDelivered > 10 and dummy.state == 'Off' then
Raspberry (debian stretch via berryboot) on Synology DS916+ , Domoticz 3.9, RFXtrx433e, P1, Youless, Harmony, Hue, HomeWizard, Zwave , dzVents 3.4, Bash, Python plugins, Amazon echo
Derik
Post by Derik » Sunday 21 January 2018 14:35
change
to
MMM
What i am looking for is a script that is switching between -1000 and -2000
So when the panels deliver back, i can set some devices on
when i do >10 then all my devices are flickering on and off when the panels are not deliver enough back.
edit:
Perhaps simpler when P1 is <-500 dummy on.
Otherwise dummy off
That should do the trick for me 2 :-0)
Is that perhaps a option??
I do not now how to change the script..:-(
Please
Post by waaren » Sunday 21 January 2018 17:29
I don't understand what you want to achieve here. P1 meter returns 6 values. 4 counters (KWh), usage (Watt) and delivery (Watt).
Either Watt usage or Watt delivery is 0 and the other one is positive (or both are 0).
