OpenWebNet developing..?
dimk
Re: OpenWebNet developing..?
Post by dimk » Saturday 03 February 2018 12:43
@spugna85
Here a Screenshot of the log, not sure it this comes from the audio devices.
I have the mh202 as gateway.
MartinImage
Gesendet von meinem BLA-L29 mit Tapatalk
spugna85
Target OS: Raspberry Pi
Post by spugna85 » Saturday 03 February 2018 13:00
Ok but this does not help me.
I need the status messages received, for example:
received = *#18*51*5*126042##: MEASURE FRAME
In this example, 18 is the WHO related to energy.
I need messages containing 22 or 16:
22 is the WHO relating to sound diffusion
16 is the WHO related to audio system
dimk
Post by dimk » Saturday 03 February 2018 13:06
Sorry, here you are.
Thanks Image
dimk
Post by dimk » Friday 09 March 2018 15:12
Hello spugna85,
Do you work on integration of bticino audio system?
Only for information.
Martin
Gesendet von meinem ONEPLUS A5010 mit Tapatalk
spugna85
Post by spugna85 » Friday 09 March 2018 15:33
Hello spugna85,
Martin
Unfortunately I could not work on the integration of the audio system because I was very busy with other work.
I hope I can work on this soon.
PicciGabber
Post by PicciGabber » Thursday 15 March 2018 0:56
Is it possible to send openwebnet strings????
With that solution we could integrate all the automations.
Thanks :D
dimk
Post by dimk » Thursday 15 March 2018 7:04
I am not sure but on post 103 are the Strings? If not where can i find this?
Martin
spugna85
Post by spugna85 » Thursday 15 March 2018 8:06
Thanks :D
Try to see this:
http://easydomoticz.com/forum/viewtopic.php?t=1512
PicciGabber
Post by PicciGabber » Friday 16 March 2018 0:35
Thanks :D
Try to see this:
:cry: :cry: :cry: :cry:
SyntaxError: unexpected indent
python problema.JPG (99.23 KiB) Viewed 1242 times
spugna85
Post by spugna85 » Friday 16 March 2018 2:57
As indicated by the error, your problem is indentation.
You must delete the spaces at the beginning of the 3 lines:
data=s.recv(BufferSize)
I have tried the script and it works correctly.
PicciGabber
Post by PicciGabber » Friday 16 March 2018 7:31
spugna85
Post by spugna85 » Saturday 17 March 2018 11:41
I do not know how to help you, I tried the script on Windows with pyton 3.6.
it seems like the send function does not want a string parameter. maybe it depends on the version of pyton used? I do not know..
dimk
Post by dimk » Thursday 19 April 2018 7:13
Hello together,
How is the Status regarding bticino audio Implementation?
Martin
fmal
Problem with temperature setpoint
Post by fmal » Thursday 12 July 2018 21:08
I have two LN4691 (no central, they are setted as residential).
From domoticz I can read the temperatures, and now I discovered also two new devices, called thermostat setpoint. I tried to use them, I can see the actual temp, but if I change the setpoint, it does not apply to LN4691. Is it a bug or I have to do something more?
fmal
Post by fmal » Saturday 14 July 2018 9:53
In relation to previous question: is there a simple way to "monitor" the BUS? I mean, I'm able to write programs so I would like to have a way to read the bus and to write commands to it. I have tried several apps or programs, but no one gives the function to read/write the bus. Maybe I have lost it? Also the domoticz's log does not give me the complete bus traffic, because it does not read things coming from MHS1.
Any suggestion?
fmal
Post by fmal » Saturday 11 August 2018 13:26
Is OpenWebNet still supported? Maybe BTicino does no more support it? Please help me to decide if I should continue this way or think to something else... I still wait for them to release the MHS1 support, and after a year, still no answer. I would like to know your opinion.
TY in advance
