HowTo: monitor Synology NAS
EdwinK
Target OS: Raspberry Pi
Re: HowTo: monitor Synology NAS
Post by EdwinK » Saturday 21 October 2017 12:42
wizjos wrote:
Tuesday 30 May 2017 12:49
EdKo66 wrote:Would be nice to monitor my two D110j's (if I ever can find those Power supplies).
I'm not sure if I'm able to help you find them :mrgreen:
But if you need assistance with the script please tell me.
Regards,
Wizjos
Never found them :(
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
wizjos
Post by wizjos » Saturday 21 October 2017 13:44
Never found them :(
Err... Not sure what you mean... :?
marxkemp
Post by marxkemp » Saturday 21 October 2017 16:42
He never found the power adapters for thos NAS devices..
IDANIT
Post by IDANIT » Sunday 29 October 2017 10:49
ping: '''192.168.1.68''': Name or service not known
0
NAS OFF
 NASIP="'''192.168.1.68'''"             # NAS IP Address
 PASSWORD="'''mypassword'''"            # SNMP Password
 DOMO_IP="'''192.168.1.110'''"          # Domoticz IP Address
 DOMO_PORT="'''8080'''"                 # Domoticz Port
 NAS_IDX="'''1100'''"                   # Virtual switch NAS STATUS
 CPU_TEMP_IDX="'''1101'''"              # Virtual temerature sensor IDX$
 HD1_TEMP_IDX="'''1102'''"              # Virtual temerature sensor IDX$
 HD2_TEMP_IDX="'''1103'''"              # Virtual temerature sensor IDX$
 HD_REMAIN_IDX="'''1104'''"             # Virtual temerature sensor IDX HD REMA$
 DOMO_LOGIN="mylogin"
 DOMO_PASS="mypassword"
QNAP TS-251. What I did wrong? NAS is working of course... 24/7.
When I did
snmpget -v 2c -c mysnmppassword -O qv 192.168.1.68 1.3.6.1.4.1.24681.1.2.11.1.3.1
I get "40 C/104 F" so snmp is working.
IDANIT
Post by IDANIT » Wednesday 15 November 2017 9:23
0
NAS OFF
When I did
up
JacEngels
Post by JacEngels » Sunday 24 December 2017 16:04
I'm setting this up for my DS212j Synology NAS running on DSM 6.1.4-15217 Update 5.
Both temperature checks are working but the disk checks don't work: there is nothing to find for the OID! I used .41 and several others.
Which OID do I use to get the script working?
rudolfpi
Post by rudolfpi » Monday 19 March 2018 19:40
How to get the virtual sensors in Domoticz, and get them connected to the scripts that runned on the Synology (sorry I'm new in Domoticz)
schoutene
Post by schoutene » Thursday 19 April 2018 10:04
I had the same. I did some Internet searching and found that the OID needs to be .42 for DSM 6.1., which works on my Synology. I updated the script on the Domoticz wiki.
JacEngels
Post by JacEngels » Sunday 22 April 2018 19:46
Thank you for the update. I've figured that out some time ago but forgot to mention it here!
EdwinK
Post by EdwinK » Monday 23 April 2018 10:04
So, I think I'm almost there with this script. Still, I also think that there is something not quite right. This is the script I use. I only have 4 drives, so commented out where it looks for more drives.
#!/bin/bash
 # Settings
 NASIP="192.168.0.10"      # NAS IP Address
 PASSWORD="<<PASSWORD>>"        # SNMP Password
 DOMO_IP="192.168.0.11"    # Domoticz IP Address
 DOMO_PORT="8080"            # Domoticz Port
 NAS_IDX="160"                # NAS Switch IDX
 NAS_HD1_TEMP_IDX="161"       # NAS HD1 Temp IDX
 NAS_HD2_TEMP_IDX="162"       # NAS HD1 Temp IDX
 NAS_HD3_TEMP_IDX="163"       # NAS HD2 Temp IDX
 NAS_HD4_TEMP_IDX="164"       # NAS HD1 Temp IDX
 #NAS_HD5_TEMP_IDX="55"       # NAS HD1 Temp IDX
 #NAS_HD6_TEMP_IDX="56"       # NAS HD1 Temp IDX
 #NAS_HD7_TEMP_IDX="57"       # NAS HD1 Temp IDX
 #NAS_HD8_TEMP_IDX="58"       # NAS HD1 Temp IDX
 NAS_HD_SPACE_IDX="168"       # NAS HD Space IDX in Go
 #NAS_HD_SPACE_PERC_IDX="63"  # NAS HD Space IDX in %
 NAS_CPU_IDX="165"            # NAS CPU IDX
 NAS_MEM_IDX="166"            # NAS MEM IDX
 NAS_CPU_TEMP="169"		   # NAS CPU Temperature
 # Check if NAS in online
 PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
 echo $PINGTIME
 if expr "$PINGTIME" '>' 0
 then
   curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
       if [ $? -eq 0 ] ; then
        echo "NAS already ON"
        # Temperature CPU
        CPUtemp=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.1.2`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_CPU_TEMP&nvalue=0&svalue=$CPUtemp"
        # Temperature HD1
        HDtemp1=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.0`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
        # Temperature HD2
        HDtemp2=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.1`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
        # Temperature HD3
        HDtemp3=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.2`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD3_TEMP_IDX&nvalue=0&svalue=$HDtemp3"
        # Temperature HD4
        HDtemp4=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.3`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD4_TEMP_IDX&nvalue=0&svalue=$HDtemp4"
        # Temperature HD5
        HDtemp5=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.4`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD5_TEMP_IDX&nvalue=0&svalue=$HDtemp5"
        # Temperature HD6
        HDtemp6=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.5`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD6_TEMP_IDX&nvalue=0&svalue=$HDtemp6"
        # Temperature HD7
        HDtemp7=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.6`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD7_TEMP_IDX&nvalue=0&svalue=$HDtemp7"
        # Temperature HD8
        # HDtemp8=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.7`
        # Send data
        # curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD8_TEMP_IDX&nvalue=0&svalue=$HDtemp8"
        # Free space volume in Go
        HDUnit=`snmpwalk -v 2c -c $PASSWORD -O qvU $NASIP 1.3.6.1.2.1.25.2.3.1.4.52`  # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        HDTotal=`snmpwalk -v 2c -c $PASSWORD -O qvU $NASIP 1.3.6.1.2.1.25.2.3.1.5.52` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        HDUsed=`snmpwalk -v 2c -c $PASSWORD -O qvU $NASIP 1.3.6.1.2.1.25.2.3.1.6.52`  # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_IDX&nvalue=0&svalue=$HDFree"
        # Free space volume in percent
        HDTotal=`snmpwalk -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.52` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        HDUsed=`snmpwalk -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.52`  # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        HDFreePerc=$((($HDUsed * 100) / $HDTotal))
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_PERC_IDX&nvalue=0&svalue=$HDFreePerc"
	    # CPU utilisation
        CpuUser=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0`
	    CpuSystem=`snmpwalk -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0`
	    CpuUse=$(($CpuUser + $CpuSystem))
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
        # Free Memory Available in %
	    MemAvailable=`snmpwalk -v 2c -c $PASSWORD -O qvU $NASIP 1.3.6.1.4.1.2021.4.6.0`
        MemAvailableinMo=$(($MemAvailable / 1024))
	    MemUsepercent=$((($MemAvailableinMo * 100) / 1024))
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
        echo "NAS ON"
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=On"
        # Temperature CPU
        # Send data
        # Temperature HD1
        # Send data
        # Temperature HD2
        # Send data
        # Temperature HD3
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp3"
        # Temperature HD4
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp4"
        HDUnit=`snmpwalk -v 2c -c $PASSWORD -O qvU $NASIP 1.3.6.1.2.1.25.2.3.1.4.42`  # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        HDTotal=`snmpwalk -v 2c -c $PASSWORD -O qvU $NASIP 1.3.6.1.2.1.25.2.3.1.5.42` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        HDUsed=`snmpwalk -v 2c -c $PASSWORD -O qvU $NASIP 1.3.6.1.2.1.25.2.3.1.6.42`  # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .52 in my case
        # Send data
        # Send data
	    # CPU utilisation
        # Send data
        # Send data
      fi
        curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
                echo "NAS already OFF"
                exit
                echo "NAS OFF"
                # Send data
                curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=Off"
        fi
 fi
When I run this script manually, I see the following:
./nas.sh
0.345
1
NAS already ON
HTTP/1.1 200 OK
Content-Length: 53
Content-Type: application/json;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
Access-Control-Allow-Origin: *
"status" : "OK",
"title" : "Update Device"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
pi@domo-server:~/domoticz/scripts $ sudo nano nas.sh
pi@domo-server:~/domoticz/scripts $ ./nas.sh
0.376
1
NAS already ON
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 400 Bad Request
Content-Length: 89
Content-Type: text/html
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>HTTP/1.1 400 Bad Request
Content-Length: 89
Content-Length: 89
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>./nas.sh: line 86: (No Such Instance currently exists at this OID - No Such Instance currently exists at this OID) * No Such Instance currently exists at this OID / 1024 / 1024 / 1024: missing `)' (error token is "Such Instance currently exists at this OID - No Such Instance currently exists at this OID) * No Such Instance currently exists at this OID / 1024 / 1024 / 1024")
0.333
1
NAS already ON
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 24
Pragma: no-cache
"status" : "ERR"
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
"status" : "OK",
Screen Shot 2018-04-23 at 10.04.19.png (219.67 KiB) Viewed 660 times
DAVIZINHO
Post by DAVIZINHO » Monday 14 May 2018 13:06
hello,
Its posible to obtain de SNMP command to a USB disk??
thanks a lot!
