Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
IDANIT
Target OS: Raspberry Pi
Re: Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
Post by IDANIT » Wednesday 17 January 2018 9:33
joostnl wrote:
Sunday 14 January 2018 8:37
The present Xiaomi Gateway does not handle Bluetooth so it is not possible. The reason you see the Flower sensors in the Xiaomi app is because your phone or pad has a direct connection to it (try turning off BT and you will find out).
However I heard there was a new Xiaomi Gateway coming supporting BT so maybe with that one.
Well I have Yeelight Ceiling Light wich after last firmware update become BlueTooth bridge. Same thing with Xiaomi Yeelight Bedside Lamp v2.
My problem with Flower Sensors is more complex. I've got RPi3 with RaZberry Daughter card. So if I switch on BT on Raspberry my Z-wave network stops working, if I want to use z-wave devices I have to switch off BT on RPi (well known problem), so no more Flower Care support.
Maybe this is the way to add BT devices to Domoticz.
Torin42
Post by Torin42 » Sunday 18 February 2018 11:35
Hey all,
I have create an Android app that helps you register your Chinese Flower Care Monitor worldwide. The app adds the device to your account through a Chinese proxy, so that afterwards you can use it with the official Flower Care app. Check out the app on Google Play: https://play.google.com/store/apps/deta ... reregister
Here is how it works:
Mediacj
Post by Mediacj » Sunday 18 February 2018 11:59
Hey all,
Thanks this works perfect!
pavelbor
Domoticz version: LastBeta
Post by pavelbor » Tuesday 27 February 2018 14:29
cant login to proxy
Torin42
Post by Torin42 » Tuesday 27 February 2018 18:19
cant login to proxy
That's might be because proxies sometimes are not working correctly. Can you retry a few times, as it will get a random proxy on each trial?
molnaratti
Post by molnaratti » Thursday 01 March 2018 22:21
EBOOZ wrote:
Monday 25 December 2017 9:56
I got my first Mi Flora yesterday and thanks to the Wiki, installation went (almost) flaweless!
My dummy sensor for logging moisture didn't update to the correct value (was always 0), and when I looked in the domoticz.py script, I noticed the URL was formatted incorrect. I modified the script so it also supports changing the status to Normal, Dry or Wet. Reading through the previous pages I assumed 20 is the right trigger for setting the status to Dry.
Original code:
    # Update moisture
    val_moist = "{}".format(poller.parameter_value(MI_MOISTURE))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_moist + "&svalue=" + val_moist + "&battery=" + val_bat)
Modified to (where svalue 3 is Wet and svalue 2 is Dry):
    # Update moisture
    if int(val_moist) >= 60:
        domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_moist + "&nvalue=" + val_moist + "&svalue=3")
    elif int(val_moist) <= 20:
        domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_moist + "&nvalue=" + val_moist + "&svalue=2")
    else:
        domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_moist + "&nvalue=" + val_moist + "&svalue=0")
Thank you, I was wrong with you too, your solution was good. !
reisub
Post by reisub » Saturday 21 April 2018 22:53
Hi everybody
Hi have received a new flower care device.
I can't pair in any way the device, the only moment when it communicate is when I put on the battery
I tried the app by Torin42 (thanks) , putting on the battery when the app is searching let me register the device, so I can see it in the flower care app, but there is now way to sync data with it...
It's the device faulty?
bramski
Post by bramski » Saturday 12 May 2018 12:42
I have 6 Mi Flora sensors right now, and I wanted to get notified when they need water. Otherwise I still have dead plants ;-). I can share a dzVents scripts with you which makes this a breeze: https://github.com/domoticz/domoticz/pull/2385/files. Have fun!
manjh
Domoticz version: 3.8153
Post by manjh » Saturday 28 July 2018 14:01
IDANIT wrote:
Monday 09 October 2017 19:16
RaspberryPi 3, Raspbian Stretch.
I follow the wiki, all installation, coping, making etc went fine, but I stuck on "Finding the sensor's Bluetooth Address". Got this error messages:
pi@raspberrypi:~/bluez-5.44 $ sudo tools/btmgmt le on
Set Low Energy for hci0 failed with status 0x11 (Invalid Index)
Can anyone help me please?
I have the exact same problem. Checked everything twice but made no mistakes.
Is there a simple solution to this?
Hans
manjh
Post by manjh » Sunday 29 July 2018 12:31
I'm lost. Tried everything, no progress.
Although this is not really a Domoticz problem, chances are there are people here that know what is wrong.
In trying to get the Mi Flora plugin working, I can't get Bluetooth to work on my Pi-3 (yes, I am sure it is a model 3).
Tried Bluetoothctl, but on "scan on" it comes back with "no default controller available".
I searched the web and tried a number of suggested solutions, nothing helps.
Is there someone here that has the golden hint?
Hans
manjh
Post by manjh » Monday 13 August 2018 18:42
Anyone? Please...? :?
Hans
terrorsource
Post by terrorsource » Sunday 26 August 2018 13:23
Does anyone have this miflora python working with domoticz right now?
https://github.com/Tristan79/miflora hasn't been updated in 2yrs.
running it now causes connecton errors between my pi 3b+ and the miflora sensor.
Tried downloading the latest MiFlora 0.4 frm https://github.com/open-homeautomation/miflora and used the domoticz.py from the Tristan79 github page.
Edited the script a bit with the info from the MiFlora github but it is still not working.
gropi
Domoticz version: 3.9269
Post by gropi » Sunday 09 September 2018 8:26
Few weeks back the scripts were working fine, unfortunately last days there was no chance. I got both with the module of Domoticz as well as with the python script errors.
Now i updated bluez, some other python modules and placed my raspi closer (4 meters) to the MiFlora sensor.
Right now everything is working.
Domoticz Version: 3.9269
Platform: Openmediavault 4; Docker 4.0.1; HP Microserver Gen8
Plugin/Hardware: MySensors Gateway; Philips HUE Bridge;
terrorsource
Post by terrorsource » Sunday 09 September 2018 10:26
Can you explain what you did?
I found my issue. The script is not working on a raspberry pi 3b+.
My other pi. A 3b is on the 2nd floor and the sensor on ground floor. Works great.
gropi
Post by gropi » Friday 28 September 2018 21:14
That are good news. unfortunately my is not working stable.
terrorsource
Post by terrorsource » Friday 28 September 2018 22:33
Well, not anymore. Stopped working now also. Same issues. Really don’t know what the issue is.
Does anyone has this plugin working right now?
