TP-Link smart plug HS100/HS110
ikek
Re: TP-Link smart plug HS100/HS110
Post by ikek » Friday 10 March 2017 12:52
MikeF wrote:I'm really at a loss to explain this. I just downloaded the python script again (on my Apple Mac), saved it with a different filename (HS110.py), and copied it across to my Raspberry Pi that runs Domoticz. I changed the 'on' and 'off' commands to pick up the new filename, clicked on the dummy switch icon in Domoticz, and turned it off and back on again (monitoring it via the Kasa app).
The permissions I have on the Pi are:
-rwxr-xr-x 1 pi pi 3062 Oct  6 22:21 HS110.py
The Domoticz command I have is:
script:///home/pi/devices/HS110.py -t 192.168.0.84 -c on
SOLVED!
I had the same problem. Rewrote the script for python 3.4 and created Domoticz environment on Windows 10 PC. That worked fine. So Raspberry interpreter has a bug. Therefore I won't use python scripts anymore in the switch On Action and Off Action. Instead I wrote a shell command On.sh and Off.sh with the corresponding python command in it. Put these in the scripts directory and made these executable with chmod. With the On.sh and Off.sh scripts (including full path) in the switch commands On Action and Off Action everything works fine!
MikeF
Target OS: Raspberry Pi
Domoticz version: V4.9700
Post by MikeF » Friday 17 March 2017 11:49
ikek wrote:So Raspberry interpreter has a bug. Therefore I won't use python scripts anymore in the switch On Action and Off Action.
This - and other python (2.7) - on / off script/s work fine for me on my RPi, so not clear what the 'Raspberry interpreter bug' is... :?
Hesmink
Post by Hesmink » Monday 08 May 2017 15:55
Thanks for the info, I got a HS110 to see if I can get a notification when my laundry is done.
I had to change the error handling at the end of the HS110.py script to:
# Send data to Domoticz
try:
    url = baseURL + "&idx=%s&svalue=%s;%s" % (HSIdx, power, total)
    domoticzrequest(url)
except urllib2.URLError, e:
    if hasattr(e, 'reason'): # <--
        print 'We failed to reach the Domoticz server.'
        print 'Reason: ', e.reason
    elif hasattr(e, 'code'): # <--
        print 'The Domoticz server couldn\'t fulfill the request.'
        print 'Error code: ', e.code
Apparently you can get both variants of this error, and only one of them has a value.
I got a trace dump that 'code' was unknown when I forgot to add the port to the Domoticz ip.
Hesmink
Post by Hesmink » Sunday 21 May 2017 20:21
I noticed the python script sometimes doesn't exit (I had 89 of them still running).
Anyone noticed this and has a fix available?
wube
Post by wube » Wednesday 18 October 2017 13:02
Hi Everyone,
I have following error while using .sh script. Anyone can help me out and tell me why?
OK, i got this over with, now i get this message:
"The nc programme for sending data over the network isn't in the path, communication with the plug will fail"
Anyone?
DannyElfman
Domoticz version: 3.8136
Post by DannyElfman » Wednesday 25 October 2017 10:33
You do not give enough info.
OS ?
Domoticz version ?
How to you send the order to the plug ? What is your command line ?
Debian Jessie VM on EsxI on a Gen 8 Proliant + RFXCom + AeonLabs Zwave+ + Fibaro eye + Fibaro Smoke + Fibaro FGS211 Philips Hue + Harmony Hub + Somfy RTS + Oregon Temp sensors + Xiaomi Gateway + Xiaomi sensors + Sonoff basic
Mace
Domoticz version: 3.8153
Re: TP-Link smart plug HS110 - send energy data to Domoticz
Post by Mace » Saturday 09 December 2017 12:53
MikeF wrote:
Monday 03 October 2016 11:58
I have now created a python script to send energy data from the TP-Link HS110 Smart Plug to Domoticz:
#!/usr/bin/env python
# TP-Link Wi-Fi Smart Plug Protocol Client
# For use with TP-Link HS110: energy monitor
# Gets current power (W) and cumulative energy (kWh)
# and sends to Domoticz
import socket
import argparse
import json
import urllib
import urllib2
# ip, port, and command for HS110
ip = '<IP of HS110>'
port = 9999
cmd = '{"emeter":{"get_realtime":{}}}'
# Domoticz command stub and IDx of HS110
baseURL = 'http://<Domoticz IP:port>/json.htm?type=command&param=udevice&nvalue=0'
HSIdx = <Domoticz IDx of HS110>
# Encryption and Decryption of TP-Link Smart Home Protocol
# XOR Autokey Cipher with starting key = 171
def encrypt(string):
	key = 171
	result = "\0\0\0\0"
	for i in string:
		a = key ^ ord(i)
		key = a
		result += chr(a)
	return result
def decrypt(string):
	key = 171
	result = ""
	for i in string:
		a = key ^ ord(i)
		key = ord(i)
		result += chr(a)
	return result
def domoticzrequest (url):
   request = urllib2.Request(url)
#   request.add_header("Authorization", "Basic %s" % base64string)
   response = urllib2.urlopen(request)
   return None;
# Send command and receive reply
try:
	sock_tcp = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
	sock_tcp.connect((ip, port))
	sock_tcp.send(encrypt(cmd))
	data = sock_tcp.recv(2048)
	sock_tcp.close()
#	print "Sent:     ", cmd
	result = decrypt(data[4:])
	jsonData = json.loads(result)
#	print "Received: "
#	print json.dumps(jsonData, indent=4, sort_keys=True)
	power = jsonData['emeter']['get_realtime']['power']
	total = jsonData['emeter']['get_realtime']['total'] * 1000
#	print power, total
except socket.error:
	quit("Cound not connect to host " + ip + ":" + str(port))
try:
	print e.code
Create a virtual sensor with sensor type 'Electric (Instant+Counter)', and insert its IDx and the IP addresses of your HS110 and Domoticz server in the script. Then set up a crontab entry to run the script every 5 or 10 minutes, as you prefer.
It will appear in the Utilities page - here's an example:
Can't get it to work. When I run ./tplink-smartplug-energy.py, I get the following back:
File "./tplink-smartplug-energy.py", line 72, in <module>
File "./tplink-smartplug-energy.py", line 47, in domoticzrequest
File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 429, in open
response = self._open(req, data)
File "/usr/lib/python2.7/urllib2.py", line 447, in _open
'_open', req)
File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 1228, in http_open
return self.do_open(httplib.HTTPConnection, req)
File "/usr/lib/python2.7/urllib2.py", line 1167, in do_open
h = http_class(host, timeout=req.timeout, **http_conn_args)
File "/usr/lib/python2.7/httplib.py", line 736, in __init__
(self.host, self.port) = self._get_hostport(host, port)
File "/usr/lib/python2.7/httplib.py", line 777, in _get_hostport
raise InvalidURL("nonnumeric port: '%s'" % host[i+1:])
httplib.InvalidURL: nonnumeric port: 'port>'
Any help would help
MikeF
Post by MikeF » Saturday 09 December 2017 16:56
Can you check your editing, where you substituted your values for text in <angle brackets> - the last line of the error message
suggests there is a spurious '>' somewhere.
Mace
Post by Mace » Saturday 09 December 2017 20:40
Thanks Mike! I didn't spot the following:
As soon as I changed the values to match my installation, it started working like a charm!
alicetharvey
Post by alicetharvey » Thursday 28 December 2017 6:42
I am using ELF Smart Plug, bought last month from equeshome. It controls plugged-in lights, devices and appliances from anywhere, through your home's WiFi via its free app. Are smart plugs available with HS100/HS110? How they works?
MikeF
Post by MikeF » Wednesday 03 January 2018 16:23
Hello Alice,
The Eques Elf is a different smart plug to the TP-Link HS100 / HS110 smart plugs. The script I developed was based on a website (see post near the beginning of this thread) where someone had worked out the specific commands which these smart plugs respond to. As such, I would expect that the Eques Elf uses different commands, and someone would need to work out how to link these switches to Domoticz.
I don't have any knowledge or experience of the Eques Elf, I'm afraid.
alicetharvey
Post by alicetharvey » Thursday 04 January 2018 9:26
Hi Mike
Thanks for your revert.
I am just looking to collect more information about home automation systems.
Thanks for your help :)
matzeb74
Domoticz version: newest
Post by matzeb74 » Tuesday 09 January 2018 1:34
I got an Error trying your meter Script.:
domoticz@fipbox:~/domoticz/scripts $ ./tplink-smartplug-energy.py
/usr/bin/python: can't find '__main__' module in 'python'
Where does the error come from?
Error solved, was just a typo.
thx for great script!!!
Olfer
Post by Olfer » Saturday 13 January 2018 11:51
Tried it out! Is working ootb like a charm! Just want to leave a huge thank you! I use the HS-110 to measure loads greater than 2,5kW.
Noob.
Domoticz on RPi3 with Aeontec Z-Stick gen5.
Devolo Thermostats and Room Control, Neo CoolCam Power Plug, Devolo Switch (not working), Fibaro Relays 2x3
matzeb74
Post by matzeb74 » Monday 22 January 2018 19:18
Can you please explain how to do this?
MikeF
Post by MikeF » Tuesday 23 January 2018 11:20
I don't know what your hardware setup is, but here's how to do it if you're running Domoticz on a Raspberry Pi:
Using the command line (Terminal from RPi desktop, or SSH via PuTTy in Windows / Terminal in macOS), enter
crontab -e
Then add the following line (for every 5 minutes):
*/5 * * * * sudo python /home/pi/devices/HS110.py >/dev/null 2>&1 &
or this (for every 10 minutes):
*/10 * * * * sudo python /home/pi/devices/HS110.py >/dev/null 2>&1 &
(assuming you have saved the script as /home/pi/devices/HS110.py - if not, change)
Then save and exit the text editor.
matzeb74
Post by matzeb74 » Tuesday 23 January 2018 11:56
crontab -e
Many many thanks. Thats it. I'll try after work.
Gesendet von meinem SM-G935F mit Tapatalk
MnM001
Post by MnM001 » Wednesday 31 January 2018 5:01
I am seeing some errors with the script.
I am running ubuntu with python 2.7:
path (tried from /home/domo same result)
/home/domo/domoticz/scripts
sudo ./H110.py
error
  File "./H110.py", line 60, in <module>
  File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
    raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
Hope someone can help me fix this so I can get power stats out of my HS110 unit.
Edit:
more information - when I run
python tplink-smartplug.py -t 192.168.0.151 -c time
I get this reply:
Sent:      {"time":{"get_time":{}}}
Received:
MikeF
Post by MikeF » Wednesday 31 January 2018 19:04
@MnM001,
Can you check that you've got the correct ip and port for your HS110 in lines 16 & 17 in the script (providing you've not changed it), and also that you've substituted the Domoticz parameters correctly in lines 21 & 22?
MnM001
Post by MnM001 » Thursday 01 February 2018 4:23
Thanks for looking
Below are my lines from the script:
ip = '192.168.0.151'
port = 9999
baseURL = 'http://192.168.0.183:8080/json.htm?type=command&param=udevice&nvalue=0'
HSIdx = 4
IP of the plug is correct and it responds to pings.
Port - I have no idea I thought it is the default port for the HS110?
Domoticz server IP and port are correct.
