Sonoff and restore state after power cycle
Everything about esp8266 and more.
kluczus
Target OS: Raspberry Pi
Post by kluczus » Wednesday 20 September 2017 23:10
Maybe someone can explain me step by step how to configure Sonoff S20 (with easyesp R147) to have always the same switch status on sonoff and domoticz, even after power cycle? I was fighting a few hours without luck :cry: Now when i reconnect sonoff, domoticz has switch set to on, but sonoff has switch set to off :-( I was using this tutorial https://smartdomsite.wordpress.com/2017 ... f-esp8266/
RPi2 + sonoff + 433MHz + Xiaomi Gateway + EQ-3 MAX!
Lebo2d9
Domoticz version: L stab
Re: Sonoff and restore state after power cycle
Post by Lebo2d9 » Thursday 21 September 2017 7:24
Maybe you can create a dummy switch on sonoff that is controlling the output and send on regular base the status of that switch to your domoticz (dummy on domoticz). You need Then you check the state the dummy that is updated by the sonoff and when the state is not equal yiu send a toggle command to you dummy on the sonoff
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
kluczus
Post by kluczus » Friday 22 September 2017 14:49
I was trying to do that but after every power cycle dummy switch reverts state to 0 :-(
But finnaly I have solved by installing a different firmware. It is not that powerfull like easyesp but working out of the box :-)
http://smart-house.adrian.czabanowski.c ... re-sonoff/
