Add Aeotec Gen5 USB
Information about specific Z-Wave devices
bluedog
Add Aeotec Gen5 USB
Post by bluedog » Wednesday 02 August 2017 11:30
How do I add a Aeotec Gen5 USB controller to Domoticz?
I'm new to Domoticz and z-wave. I just received an Aeotec Gen5 USB controller. I also have an Aeotec dimmer, but I haven't wired that in yet.
bramski
Re: Add Aeotec Gen5 USB
Post by bramski » Wednesday 02 August 2017 11:33
Go to hardware tab and add "OpenZwave USB" than select the right USB port.
bluedog
Post by bluedog » Wednesday 02 August 2017 11:47
Then what? The USB device keeps flashing blue,yellow,red. I can't work out how to configure it.
Domoticz has picked up the model number correctly though, so it does seem to be working I guess. Also has green status tick.
pvm
Domoticz version: Stable
Post by pvm » Wednesday 02 August 2017 12:38
Did you add any z-wave devices?
These should show up in the domoticz interface ('setup' for the USB stick device)
Synology NAS, PI3, ZWave, Xiamo zigbee devices, BTLE plant sensor
bramski
Post by bramski » Wednesday 02 August 2017 12:43
Yes you need to pair some z-wave devices with your controller. Read the manual of your zwave device how to do that. Most of the time you must push a button. Also set the Zwave controller to include mode. Click on setup at the hardware tab for the Gen5 USB and then "Include device".
After succesfully paired more devices must show up in this listing.
Also the 3 color flashing is normal behaviour for the USB dongle. You can switch this off through configuration.
tlpeter
Target OS: Raspberry Pi
Post by tlpeter » Wednesday 02 August 2017 12:44
It can be a bit confusing.
Go to hardware -> openzwave -> setup
Select the stick and on the bottom you can turn the blinking off.
If you want to include a node (that is what your dimmer is) then select "node management" and include the dimmer (node)
If it is zwave+ then you can also include it secure.
bluedog
Post by bluedog » Sunday 06 August 2017 4:02
Thanks everyone. This is all working now. It seemed that by adding another device to the network things became more noticeably alive.
