How to update RFLink firmware
Moderator: Stuntteam
woody4165
Re: How to update RFLink firmware
Post by woody4165 » Thursday 31 March 2016 9:10
How can I check which fw is loaded into RFLink?
I just got one, I presume it's latest one, but os there a way to check it?
Stuntteam
Target OS: Raspberry Pi
Post by Stuntteam » Thursday 31 March 2016 10:11
- When Domoticz starts / connects to the RFLink, it will show the version number
- You can also use "RFLink Loader" to see the version number. It will tell you when it connects to the RFLink.
- Alternatively you can use any termninal program and send the command 10;VERSION; it will then tell you the installed version.
woody4165
Post by woody4165 » Friday 01 April 2016 12:22
Dlanor
Post by Dlanor » Thursday 09 June 2016 9:01
It seams firmware R42 is ready and build R43 has been started. I don't see the download link for R42. Hasn't it been released yet?
Domoticz | Dashticz V2 | Raspberry Pi | RFXCOM RFXtrx433E USB | RFlink 433Mhz | SONOFF
Stuntteam
Post by Stuntteam » Thursday 09 June 2016 9:17
not yet.. but soon..
bizziebis
Domoticz version: 3.8805
Post by bizziebis » Thursday 09 June 2016 11:52
Do you have the source anywhere hosted on svn or Git? I only seem te be able to find an old version cloned by someone.
piokuc
Domoticz version: 3.6328
Post by piokuc » Friday 22 July 2016 14:59
Good option will be add to Domoticz and RFLink option update firmware by using GUI Domoticz. As is in RFXCom. This will be very good option. Because some user has set box RFLink in very accessible place and must disconnect it from Raspberry and connect to PC.
Also good will be add option debug mode to domoticz to read code from RFLink example from new devices to send to developer to add support
Stuntteam
Post by Stuntteam » Friday 22 July 2016 16:07
Firmware updates within Domoticz might be added later. Adding new protocols has more priority at the moment.
Debug mode will not be added to Domoticz. Domoticz should be treated as normal operational platform.
If you want to experiment and debug, you either connect RFlink temporary to a PC or for less than 10 euros you could build yourself a second RFlink!
piokuc
Post by piokuc » Friday 22 July 2016 16:54
Ok thanks. But please think about add to domoticz update FW in future.
Wysłane z mojego Galaxy S6 za pomocą Tapatalk
bizziebis
Post by bizziebis » Friday 22 July 2016 17:26
With a shell script it's possible to flash it from the raspberry itself. It's not as easy as flashing from Domoticz, but it keeps you from removing your RFLink and plugging it into your pc.
piokuc
Post by piokuc » Friday 22 July 2016 17:30
But i postulate to also RFLink can be flash as RFXCom by using GUI Domoticz...by webbrowser
Stuntteam
Post by Stuntteam » Friday 22 July 2016 17:59
If you can organize that the duration of a day will go from 24 to 48 hours then we can get more done in a day :P
Otherwise just be patient..
piokuc
Post by piokuc » Friday 22 July 2016 18:02
georgesattali
Post by georgesattali » Friday 22 July 2016 20:29
@ bizziebis,
shell script !! nice !
Do you have an example or some hints ?
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig » Friday 22 July 2016 21:44
piokuc wrote:But i postulate to also RFLink can be flash as RFXCom by using GUI Domoticz...by webbrowser
Why don't you buy an RFXcom.
You be happy, and we have no more multiple posts from you on different forums.
So everybody happy!
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Stuntteam
Post by Stuntteam » Saturday 23 July 2016 0:29
I am pretty sure he would still cross post, just about a different device :P
bizziebis
Re: RE: Re: How to update RFLink firmware
Post by bizziebis » Saturday 23 July 2016 19:59
georgesattali wrote:@ bizziebis,
I made a small script which disables Monit, stops Domoticz and then executes the following command:
sudo avrdude -v -p atmega2560 -c stk500 -P /dev/ttyACM0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:i
If you don't have Avrdude installed you must first install it
sudo apt-get install Avrdude
georgesattali
Post by georgesattali » Saturday 23 July 2016 21:40
Thanks for the command ! I'll try it soon. :)
htca
Post by htca » Wednesday 19 October 2016 13:49
Is there a location where you could download the zip besides the google link? it seems impossible to download it from the CLI (I am on a distance, so easy plugging in a USB stick with the files is not an option).
marcels
Post by marcels » Sunday 30 October 2016 11:52
Guys, I'm having trouble updating the rflink firmware version to R44.
I used the instructions in the startpost. But although I think everything should be OK, the program button is greyed out..
The logging window shows the following information:
20;00;Nodo RadioFrequencyLink V1.1;
10;version;
20;01;VER=1.1;REV=28;BUILD=000;
10;status;
20;02;CMD UNKNOWN;
Any idea's?
