Milight - RFlink
433Mhz opensource Receiver & Transmitter.
Moderator: Stuntteam
poudenes
Domoticz version: 3.8993
Milight - RFlink
Post by poudenes » Saturday 27 January 2018 19:04
Hi All,
Using Milights with the Milight box. Now have the module to control them using RFLink.
Everything is working but i see some difference between de options:
1) Using Milight Box the lamps also have Kelvin options.
2) Using Milight and RFlink the Kelvin option is gone.
3) Sending command to the lamp to dim them in dzVents it won't work (Maybe because of the missing Kelvin)
4) The lamps are all in Switch Type Dimmer. You can change brightness in device thats working but not in dzVents
Have someone same issues?
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
domoticzag
Target OS: Raspberry Pi
Re: Milight - RFlink
Post by domoticzag » Thursday 01 February 2018 20:44
Hi All,
I have the exact same isseus, this way, rflink is not workable for RGB+CCT for me. Is there a solution to this?
I bought the NFR module to replace the Milight Ibox v3
Last edited by domoticzag on Thursday 01 February 2018 20:51, edited 1 time in total.
RPi 3
Domoticz Béta
RFLink Gateway dipool antenna
Many kaku devices
P1 smart meter
Custom made ESP8266 devices
Hue lights / Milight ligts and strips
Stuntteam
Post by Stuntteam » Thursday 01 February 2018 20:48
Whats dzVents or what can I do to get an idea of how Kelvin is used?
poudenes
Post by poudenes » Thursday 01 February 2018 21:31
dzVents is easy scripting same as LUA. See Wiki: http://www.domoticz.com/wiki/DzVents:_n ... _scripting
Here a example of my dzVents script:
behind the scenes the dzVents system have many action to activate the action within Domoticz and its devices.
(Danny correct me if i'm wrong)
local Version               = '18.01.24'
local MasterBedroomSwitch	= 90
local MasterBedroom		    = 7
    active = true,
        devices = {MasterBedroomSwitch},
    logging = {marker = 'SLAAPKAMER Switch ' ..Version..'......'},
    if
    domoticz.devices(MasterBedroomSwitch).state == 'On'
    then
        domoticz.devices(MasterBedroom).dimTo(100)
        domoticz.devices(MasterBedroom).setKelvin(5000)
        domoticz.log('--------------------------------------------------------------', domoticz.LOG_FORCE)
        domoticz.log('-------------------==<[ SLAAPKAMER AAN ]>==-------------------', domoticz.LOG_FORCE)
    elseif
    domoticz.devices(MasterBedroomSwitch).state == 'Off'
    then
        domoticz.devices(MasterBedroom).dimTo(5)
        domoticz.devices(MasterBedroom).switchOff().afterSec(1)
        domoticz.log('-------------------==<[ SLAAPKAMER UIT ]>==-------------------', domoticz.LOG_FORCE)
domoticzag
Post by domoticzag » Friday 02 February 2018 19:05
    active = true,
    if
    then
    elseif
    then
Your understanding us wrong i think.
I mean with original Milight Bridge I get this for RGB CCT lamps:
With the RFLINK I only get these options:
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
domoticzag
Post by domoticzag » Friday 02 February 2018 19:15
    active = true,
    if
    then
    elseif
    then
This is the result of the following script, any idea why kelvin isnt working?
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
poudenes
Post by poudenes » Friday 02 February 2018 20:42
Because i run latest beta with dzVents 2.4.0 version
    active = true,
    if
    then
    elseif
    then
poudenes
Post by poudenes » Friday 02 February 2018 20:43
Correct. I have same difference with the devices. The Kelvin is missing.
    active = true,
    if
    then
    elseif
    then
poudenes
Post by poudenes » Monday 05 February 2018 18:12
But can we look to this and do some tests? And see if we can solve this?
