Communication problems between Domoticz and RFLink
433Mhz opensource Receiver & Transmitter.
Moderator: Stuntteam
aap007
Target OS: Raspberry Pi
Post by aap007 » Friday 10 November 2017 14:55
I am using Domoticz with RFLink for some time now, but I keep having some problems. I have 4 door sensors (Kerui D026) but around 50% of the time the signals aren't registered within Domoticz. Which is annoying as I use it mostly for security..
Equipment and software:
  • Raspberry Pi 2 Model B
  • Latest stable version of Domoticz (V3.8153)
  • RFLink kit (433.92 / Arduino / Dipole) from NODO shop
  • RFLink R48
When I look at the logging it seems that the RFlink notices the door switch but Domoticz doesn't, what is kinda weird..
I tried everything I can think of.. Restart Domoticz / Disconnect and reconnect RFLink / Reinstall RFLink / Replace batteries of the Kerui door sensors. None of which are helping, so all help is welcome.
Below I added the log, with debug enabled, when I open and close a door.
RFLink with minicom:
20;95;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,180,870,840,240,840,240,210,;
20;96;Eurodomest;ID=265be5;SWITCH=01;CMD=ON;
20;97;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,870,840,240,840,240,210,;
20;98;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,870,840,240,840,240,210,;
20;99;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,870,840,240,840,240,210,;
,210,870,840,240,210,870210,870,840,240,210,840,20;9E;DEBUG;Pu,240,210,870,210,;
20;A1;DEBUG;Pulses=50;Pulses(uSec)=900,210,210,870,210,870,840,240,840,240,210,;
20;A2;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,870,840,240,840,210,210,;
20;A3;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,840,840,240,840,210,210,;
20;A9;Eurodomest;ID=265be5;SWITCH=00;CMD=OFF;
20;AA;DEBUG;Pulses=50;Pulses(uSec)=900,210,210,870,210,870,840,240,840,240,210,;
20;AB;DEBUG;Pulses=50;Pulses(uSec)=930,210,210,870,210,870,840,240,840,240,210,;
20;AC;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,870,840,240,840,240,210,;
Domoticz log:
2017-11-10 13:16:13.862 RFLink: 20;9A;DEBUG;P0,240,210,870,210,870,840,210,840,240,210,870,840,240,210,870,210,870,840,240,210,870,210,870,21,240,840,240,210,870,840,240,210,870,840,240,840,210,840,240,210,870,210,6990;
2017-11-10 13:16:14.259 RFLink: 20;s(uSec)=900,210,210,870,210,870,840,240,840,240,210,870,840,240,210,870,210,870,840,240,210,870,210,870,210,870,210,870,210,870,840,240,840,240,840,240,840,210,840,240,210,840,210,6990;
2017-11-10 13:16:14.661 RFLink: 20;A4;DEBUG;Pulses=50;Pulses(uSec)=900,240,840,240,210,870,840,240,210,870,210,870,840,210,210,870,210,870,210,870,210,870,210,870,840,240,840,240,210,870,840,240,210,870,840,240,840,240,840,240,210,840,210,6990;
2017-11-10 13:16:14.898 RFLink: 20;A7;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,870,840,240,210,870,210,870,840,210,210,870,210,840,210,840,210,870,210,840,840,240,840,240,210,870,840,240,210,870,840,240,840,240,840,240,210,840,210,6990;
2017-11-10 13:16:27.846 RFLink: 20;AD;DEBUG;Pu,240,210,870,210,870,840,240,840,240,210,870,840,210,210,840,210,870,840,240,210,870,210,870,210,870,210,870,210,870,840,240,840,240,210,870,840,240,210,870,210,870,840,240,840,240,840,210,210,6990;
2017-11-10 13:16:28.084 RFLink: 20;B0;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,840,840,240,210,870,210,870,840,240,210,870,210,840,210,870,210,870,210,870,840,210,840,240,210,840,840,240,210,870,210,870,840,240,840,240,840,210,210,6990;
2017-11-10 13:16:28.243 RFLink: 20;B2;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,840,210,870,840,210,210,840,210,840,840,240,210,870,210,870,210,870,210,840,210,870,840,240,840,240,210,840,840,240,210,870,210,840,840,240,840,240,840,240,210,6990;
2017-11-10 13:16:28.404 RFLink: 20;B4;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,180,870,840,210,840,240,210,870,840,240,210,840,210,870,210,870,210,870,210,870,840,240,840,210,210,840,840,240,210,870,210,870,840,240,840,240,840,240,210,6990;
2017-11-10 13:16:28.563 RFLink: 20;B6;DEBUG;Pulses=50;Pulses(uSec)=900,240,210,870,210,870,840,210,840,240,210,870,840,240,210,870,210,870,210,870,210,870,210,870,840,240,840,240,210,870,840,240,210,870,210,870,840,210,840,240,840,240,210,6990;
Stuntteam
Re: Communication problems between Domoticz and RFLink
Post by Stuntteam » Saturday 11 November 2017 10:35
You should log without debug to see the detected data.
Make sure there is enough distance between the Pi and Arduino. The Pi is known to be a source of RF interference.
