Domoticz & RFlink & temperature sensor
433Mhz opensource Receiver & Transmitter.
Moderator: Stuntteam
eSumo
Target OS: Raspberry Pi
Domoticz version: 3.5877
Post by eSumo » Tuesday 10 January 2017 10:38
Hello!
I have two systems:
Home System = among other RPi2 & Domoticz last stable 3.5877 & RFLink R42 ...
Test environment = Win10 & Domoticz last beta (currently 3.6325) & RFLink R45 ...
I have several external temperature sensors for WH6 weather station WH0204.
Domoticz 3.5877 & RFLink R42 detects:
Type: Temp + Humidity
Subtype: WRTG800
Dates: 22.1 C, 0%, Bat 100
(The sensor does not contain humidity, but the temperature is OK and work very well.)
Domoticz last beta & RFLink R43-R45, the sensor does not find ... :(
Debug output from R42, 43, 44 and 45 is exactly the same!
R42
20; 13; AlectoV3; ID = 002E; TEMP = 00d9; HUM = ff; BAT = OK;
20; 14; AlectoV3; ID = 00fc; TEMP = 00dc; HUM = ff; BAT = OK;
20; 15; AlectoV3; ID = 00da; TEMP = 00e2; HUM = ff; BAT = OK;
R45
20; 5C; AlectoV3; ID = 002E; TEMP = 00d9; HUM = ff; BAT = OK;
20; 5D; AlectoV3; ID = 00fc; TEMP = 00 db; HUM = ff; BAT = OK;
20; 5E; AlectoV3; ID = 00da; TEMP = 00e2; HUM = ff; BAT = OK;
I want to upgrade RFLink R45 (because Unitec work there), but I can not ... :(
When I upgraded to R44 or R45 to the home system, but a lot of things not work because it did not go Thermometers.
Existing inoperative and is not new.
Where is the problem??? Domoticz or RFlink ???
Help anyone?
Thanx!
Domoticz v3.5877 on RPi 2, RFLink 433 R42 with NODO, MySensors WiFi GW (NodeMCU) v2.0.0
...and 42x 433MHz devices + 7x MySensors...
Test: latest Domoticz beta on Win10, home made RFLink 433 R45 with NRF for MySensors...
