RFLink and Venetian Blinds
433Mhz opensource Receiver & Transmitter.
Moderator: Stuntteam
Twinsen
Post by Twinsen » Saturday 24 December 2016 10:05
After the last updates the STOP command for Venetian blinds is not working.
I have the Domoticz v. 3.6231 and RFLink v. 45
For UP and DOWN commands everything is working perfect.
Please help me to solve this issue.
2016-12-24 09:55:19.688 User: lgr initiated a switch command (7/Stanga/Stop)
2016-12-24 09:55:19.689 Error: RFLink: trying to send unknown switch command: 17
2016-12-24 09:55:46.101 User: lgr initiated a switch command (7/Stanga/On)
2016-12-24 09:55:46.103 RFLink Sending: 10;BrelMotor;b808be;a1;DOWN
2016-12-24 09:55:47.210 (RFLink) Light/Switch (Stanga)
2016-12-24 09:55:49.170 User: lgr initiated a switch command (7/Stanga/Off)
2016-12-24 09:55:49.171 RFLink Sending: 10;BrelMotor;b808be;a1;UP
2016-12-24 09:55:50.315 (RFLink) Light/Switch (Stanga)
Twinsen
Re: RFLink and Venetian Blinds
Post by Twinsen » Monday 02 January 2017 18:09
I think that, the problem is generated in the last stable release...
How can be solved this issue ?
Twinsen
Post by Twinsen » Thursday 05 January 2017 21:50
Please, can someone help me ?
Stuntteam
Target OS: Raspberry Pi
Post by Stuntteam » Friday 06 January 2017 1:19
We will take a look asap.
Twinsen
Post by Twinsen » Friday 06 January 2017 23:05
Thank you for your answer.
I asked in general section and they told me that everything is ok and command is created correctly.
Twinsen
Post by Twinsen » Tuesday 10 January 2017 19:38
Can you help me with an update?
Stuntteam
Post by Stuntteam » Wednesday 11 January 2017 21:08
In some cases there was indeed something that did not work as planned.
A fix has been comitted..
Should be available in the next beta.
Twinsen
Post by Twinsen » Wednesday 11 January 2017 22:00
Thank you for your time and disponibility.
I will wait for next beta release to test it.
Twinsen
Post by Twinsen » Thursday 12 January 2017 7:33
Everything is OK now
Thanks.
jordantheripper
Domoticz version: 3.9208
Post by jordantheripper » Tuesday 20 March 2018 10:42
I there.
Can you please tell me the way you solved the problem?
I'm searching for solution fom my venetian blinds.
Thanks so much
