How to install Domoticz on a Synology NAS
jumbotroll
Re: How to install Domoticz on a Synology NAS
Post by jumbotroll » Thursday 24 May 2018 22:16
ksfmcgh wrote:
Thursday 24 May 2018 21:47
jumbotroll wrote:
Thursday 24 May 2018 14:35
ksfmcgh wrote:
Thursday 24 May 2018 12:04
I just new with Domoticz, very nice package from Jumbotroll for my NAS916+.
Works very well until the NAS made the update to the DSM 6.2.
It's seems there is no refresh now on the sensors.
Do you think you release your package for the DSM 6.2 for braswell ?
Thank you
Fabien
Braswell DSM 6.1 and DSM 6.2 use same toolchain and kernel, so domoticz for DSM 6.1 should work...
Take backup of domoticz.db and reinstall domoticz package and see if that helps.
So I tried to uninstall and reinstall but still not working.
I see in Hardware that the port is no longer recognized, I tried to installed the drivers for DSM 6.1 but nothing change.
If I connect on my NAS there is no port available on Domoticz, but on my computer my RFLink works great.
If you have any idea, I appreciate.
Thank you
Do not install the USBserialDriver package if you use domoticz!
All drivers are included in my packages!
I will try to download the toolchain and linux kernel for Braswell DSM 6.2 and build a new domoticz beta package for you.
You will find these under DSM 6.2 beta later tonight 8-)
Jumbotroll
http://www.jadahl.com
ksfmcgh
Post by ksfmcgh » Thursday 24 May 2018 22:19
Thank you
Thank you I test it tomorrow and I come back to you
ksfmcgh
Post by ksfmcgh » Friday 25 May 2018 8:34
Thank you
I just install this version and all works great. The RFLink is reconized on the USB port again, and my sensors are refreshed.
Thank you for your help and your quick responce.
ksfmcgh
Post by ksfmcgh » Sunday 27 May 2018 1:54
I have another problem, I don't know if I miss a step or not.
I program a store in the RFLink, and the line command works fine with the RFLink loader.
On Domoticz when I want add manually a switch, there is nothing on the hardware field. Normally I must have the RFLink listed on it ?
Thank you again
ksfmcgh
Post by ksfmcgh » Monday 28 May 2018 13:00
Thank you again
I saw you update the beta version to domoticz_braswell-6.2_3.0.9521-7.spk.
I tested with this new release but I have the same problem. When I add new switch manually in the hardware fiel there is an empty list and can't select the RFLink.
jumbotroll
Post by jumbotroll » Monday 28 May 2018 15:34
Thank you again
Very strange! Using same toolchain and kernel as before..
Try to log in to your NAS with Telnet and type: dmesg
Check for driver error output and copy/paste here.
Jumbotroll
ksfmcgh
Post by ksfmcgh » Monday 28 May 2018 18:43
Thank you again
It's work now. I was send a command with "Create RFLink Devices" in the "setup Hardware" and now The RFLink is showed on the Hardware line when I add a new switch manually.
Thank you for your help and sorry for the inconveniences.
Fabien
DomoArigato
Post by DomoArigato » Tuesday 29 May 2018 22:41
Hello @ll.
I hope this is not too much off topic...
Is there a way to see the change log of those betas jumbotroll is compiling for all of us (again BIG thanks for your efforts on this!!!)?
I am always asking myself if I should update or not on those betas available. But I do not find a change log pointing me to the changes of a certain beta.
I see the domoticz github part but the change log there is not version specific (at least as far as I found out so far... maybe I just looked in the wrong way...). It sums up all changes made to the current available beta.
But since beta versions we can use on Synology are behind (version wise) the the general available beta versions it would be great to see which changes are in which beta.
Well it is late here on my side .... hope you understand my words and my question make sense somehow :roll:
Thanks for any hints.
AllesVanZelf
Post by AllesVanZelf » Wednesday 30 May 2018 10:13
@Jumbotroll:
Thank you for all your work on domoticz on Synology Nas!
I do have an question.
I have a DS111, recently updates to DSM6.2. I installed domoticz_88f6281-6.1_3.0.9056-7.spk on DSM6.1 before. I believe this was a python version.
I do not see a version for this NAS on http://www.jadahl.com/domoticz_beta_6.2_python/
Is there a reason for this?
Or could I install: http://www.jadahl.com/domoticz_beta_6.1 ... 9390-7.spk
jumbotroll
Post by jumbotroll » Wednesday 30 May 2018 10:55
@Jumbotroll:
It's getting complicated to compile domoticz with and without python for this prosessor, as it uses an older gcc464 and an older kernel linux-2.6.32.
I have limited time to work with this and we will see in the future if I want to continue compiling domoticz for NAS using this processor.
If you can use the DSM6.1 version, I do not know so you have to test.
If it does not work, it's only to uninstall it again.
Jumbotroll
AllesVanZelf
Post by AllesVanZelf » Wednesday 30 May 2018 11:24
Okay, I'll try 6.1 python version. Thank you for this quick reply!
AllesVanZelf
Post by AllesVanZelf » Wednesday 30 May 2018 17:13
The DSM6.1 version with python is working well on synology nas ds111-DSM6.2.
jumbotroll
Post by jumbotroll » Wednesday 30 May 2018 23:15
Ok. Thanks for feedback.
Jumbotroll
HM31
Post by HM31 » Tuesday 05 June 2018 14:48
Seems to works fine also on DS211j with DSM 6.2, but I don't have any serial USB dongle on it (only use it with Python scripts, Virtual Network devices and embedded Motherboard devices)
I have an issue to send notification by e-mail (Domoticz seems unable to recognize destination e-mail addresses, marking them as ! in log file with an error sending e-mail) but haven't tried it before upgrade of DSM so I'm not quite sure that it's a Domoticz or DSM issue.
mikkelnl
Post by mikkelnl » Sunday 10 June 2018 9:01
Hi guys,
Been browsing this topic, and not sure if it's OK to update to DSM 6.2 at the moment? Can anyone advice?
I have a Synology DS716+II / INTEL Celeron N3160 with Domoticz installed via a package (Jadahl 3.0.8153-7).
jumbotroll
Post by jumbotroll » Sunday 10 June 2018 9:18
Hi guys,
You can update to DSM 6.2 then update my domoticz package for DSM 6.2.
Arch-braswell.
Beta:
http://www.jadahl.com/domoticz_beta_6.2/
or
With python plugin (Python3 from synology must be installed first)
Remember! Always take a backup of domoticz.db and scripts before update, just in case...
BTW! If you update from stable version to beta, the best solution is to do a clean install of domoticz package.
Jumbotroll
mikkelnl
Post by mikkelnl » Sunday 10 June 2018 9:32
Hi guys,
Arch-braswell.
Beta:
or
I just updated, and found that Domoticz seems to still be working...? Is that expected? :) I did not update your package yet...
jumbotroll
Post by jumbotroll » Sunday 10 June 2018 9:35
Yes, that was expected, but some USB drivers are different in DSM6.2 so if you get any problem with your USB devices, you can update to DSM 6.2 package.
Jumbotroll
mikkelnl
Post by mikkelnl » Sunday 10 June 2018 9:37
Thanks, i did notice some errors in the domoticz log with my rfxcom, so I updated your package and they are gone now. Thanks again.
mikkelnl
Post by mikkelnl » Saturday 16 June 2018 13:12
Since updating to the recent beta (because of dsm 6.2) my DSM now alerts me with this message:
"one or more abnormal users have been found in the autentication file"
I'm geussing this is linked to the beta of domoticz, cause this never happened before?
Any ideas?
https://imgur.com/96uiZLn
