Install Domoticz on Rasp 3B+
Knibor
Target OS: OS X
Post by Knibor » Monday 11 June 2018 23:35
Hi, i currently run Domoticz "Beta" on my Rasp 3B+. I can reach it from the browser 192.168.1.38:8080
But now I want run Domoticz "Stable" on my Rasp 3B+
When I want to run the Domoticz "stable" version, I can't reach it from the browser 192.168.1.38:8080
How to fix this problem?
Koensk
Re: Install Domoticz on Rasp 3B+
Post by Koensk » Monday 27 August 2018 9:22
Hi there,
I have the same problem and I can't find the solution.
How can I do a clean install that will actually work?
Thanks anyone for your help
jornm
Target OS: Raspberry Pi
Post by jornm » Monday 27 August 2018 13:40
Open a terminal and run:
sudo netstat -lpn | grep 8080
This should give this output:
tcp6       0      0 :::8080                 :::*                    LISTEN      3463/./domoticz
Note that the 3463 is process id and will change
If you do not get any output domoticz is not running/listening
