i want save backup database file (.db) with other name Topic is solved
reza
Target OS: Raspberry Pi
Domoticz version: 3.5877
Post by reza » Friday 08 September 2017 19:09
hi guys.
i want save backup database with other name. now when i push backup database i have a file with name: domoticz.db
i want save with my name "reza.db" in my computer, which file in source i must change for save backup file with my name?
i dont want save with domoticz and after save rename this . i want save with reza.db.
can you halp me ?
thank you
SweetPants
Domoticz version: V4.9701
Re: i want save backup database file (.db) with other name
Post by SweetPants » Friday 08 September 2017 20:35
Why do you want this? If you change it in the source, it will be overwritten after the first update. Why not save it and rename it?
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
reza
Post by reza » Friday 08 September 2017 20:52
this is interesting for me that change . now i am change many icons and theme and language etc...
i like learn work with source. now i want learn how save database with this name :domoticz.db . if i want change this , what am i do and after this learning about more option... can you help me ?
reza.db is a example. i am tring to translate domoticz to my language.
SweetPants
Post by SweetPants » Saturday 09 September 2017 9:01
Why not write a language pack? http://www.domoticz.com/forum/viewforum.php?f=7
How do you want to keep up with changes in domoitcz, nobody is going to help you if you have your own 'special' version.
reza
Post by reza » Saturday 09 September 2017 9:29
if i dont update so keep up with changes in domoitcz? is this true ?
i am writing a language But it will take a while, some things can not wirte in language . for example backup name .
Please do not enter into marginal discussions . can you help me for found and change name of download backup database ? which file have name of save and download backup database? thank you
SweetPants
Post by SweetPants » Saturday 09 September 2017 9:35
Can't help you with that, you have to search in the source code for that
reza
Post by reza » Saturday 09 September 2017 9:41
i search but dont found this . ok thank you. any body can you help me for found this between source files?
SweetPants
Post by SweetPants » Saturday 09 September 2017 9:57
Then you did not search (well)
grep -r domoticz.db
Binary file domoticz matches
main/SQLHelper.cpp: SetDatabaseName("domoticz.db");
main/WebServer.cpp: reply::set_content_from_file(&rep, OutputFileName, "domoticz.db", true);
main/domoticz.cpp:"\t-dbase file_path (for example D:\\domoticz.db)\n"
main/domoticz.cpp:"\t-dbase file_path (for example /opt/domoticz/domoticz.db)\n"
main/domoticz.cpp: std::string dbasefile = szUserDataFolder + "domoticz.db";
main/domoticz.cpp: sPath += "\\domoticz.db";
main/domoticz.cpp: dbasefile = cmdLine.GetSafeArgument("-dbase", 0, "domoticz.db");
reza
Post by reza » Saturday 09 September 2017 10:31
i sse SGLHelper and domoticz in main , but i didnt found webserver in search. i think this is related to this file... thank you very much
