Domoticz does not open port 8080
Posted: Sunday 03 September 2017 20:17
by MasWetens
Dear Domoticz,
I installed Domoticz already several times using the following command:
"Sudo curl -L install.domoticz.com | (sudo) bash"
When I check the installation using:
"wget localhost"
Isn't the port 8080 showing up, but I set in de setting that popped up when I installed it at port 8080.
What can I do to solve this problem????
Re: Domoticz does not open port 8080
Posted: Sunday 03 September 2017 21:48
by pvm
wget localhost:8080
does not result in an index.html file?
Posted: Monday 04 September 2017 16:56
by MasWetens
When I do
wget localhost:8080
Get I a return as follows:
--2017-09-04 16:55:52--  http://localhost:8080/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:8080... failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:8080... failed: Connection refused.
Thank you for your reaction pvm.
Posted: Tuesday 12 September 2017 13:47
by Elvana
Hi, I had the same issue.
As a NOOB it took me some time to work this out... which is why I am sharing the following in boring detail.
On a new 16 GB SDcard I had installed Raspbian Stretch from https://www.raspberrypi.org/downloads/raspbian/
Upon starting the partition size was automically adjusted.
After opening a terminal window I ran sudo raspi-config and changed password, timezone, ssh access and screen resolution and overscan (last three under interfacing options).
Then rebooted in the terminal window by issuing
sudo reboot
I then installed Domoticz "The Easy Way" according to https://www.domoticz.com/wiki/Installin ... e_easy_way with
sudo curl -L install.domoticz.com | sudo bash
This ran successfully but yielded Domoticz inaccessible (with and without https enabled - no difference).
Like the topic starter - after a reboot I could not access Domoticz on either port 8080 or 443:
pi@domoticzR1:~ $ wget localhost:8080
--2017-09-12 11:10:09--  http://localhost:8080/
I found this topic as well as this other one viewtopic.php?t=18020 and my error message read:
sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
   Active: active (exited) since Tue 2017-09-12 11:08:28 CEST; 6min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 1100 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
  Process: 1110 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/domoticz.service
Sep 12 11:08:27 domoticzR1 systemd[1]: Starting LSB: Home Automation System...
Sep 12 11:08:28 domoticzR1 domoticz.sh[1110]: /home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file:
Sep 12 11:08:28 domoticzR1 systemd[1]: Started LSB: Home Automation System.
From a browser window on the raspberry I downloaded the armhf version of libssl.so.1.0.0 from https://packages.debian.org/jessie/libssl1.0.0
In a terminal window I installed the package:
pi@domoticzR1:~ $ cd Downloads
pi@domoticzR1:~/Downloads $ sudo dpkg -i libssl1.0.0*
Selecting previously unselected package libssl1.0.0:armhf.
(Reading database ... 122756 files and directories currently installed.)
Preparing to unpack libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb ...
Unpacking libssl1.0.0:armhf (1.0.1t-1+deb8u6) ...
Setting up libssl1.0.0:armhf (1.0.1t-1+deb8u6) ...
stopped and restarted Domoticz (a reboot should also work):
pi@domoticzR1:~/Downloads $ cd ..
pi@domoticzR1:~ $ sudo service domoticz.sh stop
pi@domoticzR1:~ $ sudo service domoticz.sh start
then checked availability of Domoticz on port 8080:
pi@domoticzR1:~ $ wget 127.0.0.1:8080
--2017-09-12 12:01:53--  http://127.0.0.1:8080/
Connecting to 127.0.0.1:8080... connected.
HTTP request sent, awaiting response... 200 OK
Length: 90327 (88K) [text/html]
Saving to: ‘index.html’
index.html          100%[===================>]  88.21K  --.-KB/s    in 0.002s
2017-09-12 12:01:53 (57.4 MB/s) - ‘index.html’ saved [90327/90327]
after this I could also access Domoticz from other devices.
Posted: Wednesday 13 September 2017 7:13
by wegen
hello,
sorry for this simple question...
how did you put libssl.so.1.0.0 in the download directory?
wich version of this lib did you use?
Many thanks for your answers
Posted: Wednesday 13 September 2017 7:27
by koowee
Posted: Wednesday 13 September 2017 17:15
by wegen
here is one way how you can do it
http://www.domoticz.com/forum/viewtopic ... 20#p150258
Many thanks for your help. I did it but I still become this page : Apache2 Debian Default Page
Any idea?
Posted: Wednesday 13 September 2017 19:20
by SweetPants
Many thanks for your help. I did it but I still become this page : Apache2 Debian Default Page Any idea?
Ehhh "Apache2 Debian Default page" suggests you have apache installed too. Domoticz has it's own web server (not apache). Does that run on 8080 too? Try starting domoticz manually with a different "-www port"
Posted: Wednesday 13 September 2017 20:56
by wegen
I really need your help. Could you contact me private?
Posted: Sunday 17 September 2017 22:29
by wegen
I still don't get it:
pi@raspberrypi:~/domoticz $ wget 192.168.1.112:8080
--2017-09-17 20:20:40--  http://192.168.1.112:8080/
Connecting to 192.168.1.112:8080... failed: Connection refused.
I followed those steps:
Install Raspbian desktop edition
activate ssh by creating ssh file in boot
connect via putty, user pi
run command
run command
cd domoticz
./updaterelease
wget http://mirrordirector.raspbian.org/raspbian/pool/main/o/openssl/libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
I cannot reach my roboticz at the adress: 192.168.1.112:8080
ping on 192.168.1.112 works
I use RPI3
Posted: Thursday 03 May 2018 17:53
by jandirkv
I have also a problem with remote access. Port 8080 is open and forwarded in my router to the Domoticz ip. But when I try to access I get routed to the login page of my router.
Posted: Monday 04 June 2018 20:35
by jandirkv
I finale have a solution. The problem was My router. I have a new one and all my problems are solved. Thanks for all the help
Posted: Monday 04 June 2018 23:02
by SweetPants
Please be aware this (HTTP) is highly insecure. Better switch to HTTPS (443) and use Certificates or a VPN connection.
Posted: Wednesday 01 August 2018 22:01
by Tonio16
Hello
I have two domoticz at home. One on a Pi B+ and a second on a Pi 3+.
Today, for less than 1 hour, I have the offline page on the Pi 3+. Just after I finaly set up the Synology monitoring: https://www.domoticz.com/wiki/NAS_Monitoring#Synology
I also made an apt-get update/upgrade this afternoon but it was working fine after though I made several reboots.
If i do the wget:
wget localhost:8080
--2018-08-01 21:45:53--  http://localhost:8080/
Résolution de localhost (localhost)… ::1, 127.0.0.1
Connexion à localhost (localhost)|::1|:8080… échec : Connexion refusée.
Connexion à localhost (localhost)|127.0.0.1|:8080… échec : Connexion refusée.
but the service is running
domoticz@raspberrypi:~ $ sudo /etc/init.d/domoticz.sh status
   Active: active (exited) since Wed 2018-08-01 21:25:14 CEST; 25min ago
  Process: 528 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
aoû 01 21:25:13 raspberrypi systemd[1]: Starting LSB: Home Automation System...
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: 2018-08-01 21:25:14.741  Stat…Cuz
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: 2018-08-01 21:25:14.754  Stat…:51
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: 2018-08-01 21:25:14.766  Stat…cz/
aoû 01 21:25:14 raspberrypi domoticz.sh[528]: domoticz: Domoticz is startin…...
aoû 01 21:25:14 raspberrypi domoticz[548]: Domoticz is starting up....
aoû 01 21:25:14 raspberrypi domoticz[588]: Domoticz running...
aoû 01 21:25:14 raspberrypi systemd[1]: Started LSB: Home Automation System.
Hint: Some lines were ellipsized, use -l to show in full.
Posted: Monday 27 August 2018 10:04
by Koensk
This looks the same with me. But from another pc I cannot connect. Hows that possible?
Posted: Monday 27 August 2018 17:21
by jornm
To make i easier for people to help you troubleshoot run the command:
sudo netstat -lpn
and paste the result.
This will show what process is listening on which port.
