Problems compiling since v3.6039 on linux x86 Topic is solved
georgep
Domoticz version: Latest
Post by georgep » Friday 23 December 2016 12:42
I try to keep reasonably up-to-date with new versions and I last compiled v3.6039 with no problems.
Now when I try to pull the latest files and recompile I'm getting a lot of errors, most relating to Python (my system has version 2.7.3). Here's the full output:
Scanning dependencies of target domoticz
[ 22%] Building CXX object CMakeFiles/domoticz.dir/main/domoticz.cpp.o
[ 22%] Building CXX object CMakeFiles/domoticz.dir/hardware/OTGWBase.cpp.o
[ 22%] Building CXX object CMakeFiles/domoticz.dir/hardware/plugins/PluginManager.cpp.o
In file included from /usr/include/python2.7/Python.h:8:0,
                 from /home/george/domoticz/hardware/plugins/PluginManager.cpp:34:
/usr/include/python2.7/pyconfig.h:1161:0: warning: "_POSIX_C_SOURCE" redefined [enabled by default]
/usr/include/features.h:164:0: note: this is the location of the previous definition
/usr/include/python2.7/pyconfig.h:1183:0: warning: "_XOPEN_SOURCE" redefined [enabled by default]
/usr/include/features.h:166:0: note: this is the location of the previous definition
In file included from /home/george/domoticz/hardware/plugins/PluginManager.cpp:37:0:
/home/george/domoticz/hardware/plugins/DelayedLink.h:260:0: warning: "PyBytes_AsString" redefined [enabled by default]
/usr/include/python2.7/bytesobject.h:16:0: note: this is the location of the previous definition
/home/george/domoticz/hardware/plugins/PluginManager.cpp:496:28: error: variable ‘Plugins::PyModuleDef Plugins::DomoticzModuleDef’ has initializer but incomplete type
/home/george/domoticz/hardware/plugins/PluginManager.cpp:497:3: error: ‘PyModuleDef_HEAD_INIT’ was not declared in this scope
/home/george/domoticz/hardware/plugins/PluginManager.cpp: In function ‘PyObject* Plugins::CDevice_insert(Plugins::CDevice*, PyObject*)’:
/home/george/domoticz/hardware/plugins/PluginManager.cpp:663:96: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:673:60: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:677:127: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:703:151: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp: In function ‘PyObject* Plugins::CDevice_update(Plugins::CDevice*, PyObject*)’:
/home/george/domoticz/hardware/plugins/PluginManager.cpp:725:103: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:734:18: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:734:83: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:738:24: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:739:47: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp: In function ‘PyObject* Plugins::CDevice_seticon(Plugins::CDevice*, PyObject*)’:
/home/george/domoticz/hardware/plugins/PluginManager.cpp:764:96: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:771:73: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp: In function ‘PyObject* Plugins::CDevice_str(Plugins::CDevice*)’:
/home/george/domoticz/hardware/plugins/PluginManager.cpp:795:113: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp:795:157: error: ‘struct Plugins::SharedLibraryProxy’ has no member named ‘PyBytes_AsString’
/home/george/domoticz/hardware/plugins/PluginManager.cpp: At global scope:
/home/george/domoticz/hardware/plugins/PluginManager.cpp:851:21: error: variable ‘Plugins::PyModuleDef Plugins::CDevice_module’ has initializer but incomplete type
/home/george/domoticz/hardware/plugins/PluginManager.cpp:852:3: error: ‘PyModuleDef_HEAD_INIT’ was not declared in this scope
/home/george/domoticz/hardware/plugins/PluginManager.cpp: In function ‘void Plugins::PyInit_Domoticz()’:
/home/george/domoticz/hardware/plugins/PluginManager.cpp:868:11: error: return-statement with a value, in function returning 'void' [-fpermissive]
/home/george/domoticz/hardware/plugins/PluginManager.cpp:872:10: error: return-statement with a value, in function returning 'void' [-fpermissive]
/home/george/domoticz/hardware/plugins/PluginManager.cpp: In member function ‘bool Plugins::CPluginSystem::StartPluginSystem()’:
/home/george/domoticz/hardware/plugins/PluginManager.cpp:1965:54: error: invalid conversion from ‘void (*)()’ to ‘PyObject* (*)() {aka _object* (*)()}’ [-fpermissive]
make[2]: *** [CMakeFiles/domoticz.dir/hardware/plugins/PluginManager.cpp.o] Error 1
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
make: *** [all] Error 2
[email protected]:~/domoticz$
My server is a relatively old version of Ubuntu linux but it is kept up-to-date with updates from the usual repositories...
[email protected]:~/domoticz$ uname -a
Linux asusbox 3.2.0-118-generic #161-Ubuntu SMP Fri Dec 2 15:36:31 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Any clues would be much appreciated.
Thanks, and Happy Christmas everyone!
George
georgep
Post by georgep » Friday 23 December 2016 13:03
I just found a mention of Domoticz now requiring at least libpython3.2, which I've now installed.
I'll update again if/when it compiles OK.
georgep
Re: Problems compiling since v3.6039 on linux x86
Post by georgep » Friday 23 December 2016 14:16
No luck. My compile is still failing at 'PluginManager.cpp.o' :-(
I did 'make clean', 'cmake .' and 'make' and here are the results...
[email protected]:~/domoticz$ cmake .
-- Using builtin Mosquitto library
-- Python3 includes found at: /usr/include/python2.7
-- Compiling Revision #6231
-- Boost version: 1.59.0
-- Found the following Boost libraries:
--   thread
--   date_time
--   system
-- Linking against boost static libraries
-- ZLIB libraries found at: /usr/lib/x86_64-linux-gnu/libz.so
-- ZLIB includes found at: /usr/include
-- Curl libraries found at: /usr/lib/x86_64-linux-gnu/libcurl.so
-- Curl includes found at: /usr/include
-- LIBUSB found at: /usr/lib/x86_64-linux-gnu/libusb.so
-- ==== OpenZWave not found, support disabled!
-- ==== WiringPi include file (wiringPi.h) not found. GPIO support disabled.
-- ==== (Please follow http://wiringpi.com/download-and-install/ if you want to use GPIO.)
-- Not found telldus-core (telldus-core.h), not adding tellstick support
/usr/bin/c++  ;-O3;-DNDEBUG;-I/usr/include/python2.7;-I/home/george/domoticz/main;-I/usr/local/include;-I/usr/include;;-DBUILTIN_MQTT;-DUSE_PYTHON_PLUGINS;-DHAVE_EXECINFO_H;-DWITH_LIBUSB;-DWWW_ENABLE_SSL -x c++-header -o /home/george/domoticz/stdafx.h.gch/.c++ /home/george/domoticz/main/stdafx.h
-- Using static libgcc/libstdc++
-- Configuring done
-- Generating done
-- Build files have been written to: /home/george/domoticz
[ 77%] Building CXX object CMakeFiles/domoticz.dir/hardware/ZiBlueBase.cpp.o
[ 77%] Building CXX object CMakeFiles/domoticz.dir/hardware/ZiBlueSerial.cpp.o
[ 78%] Building CXX object CMakeFiles/domoticz.dir/hardware/ZiBlueTCP.cpp.o
[ 78%] Building CXX object CMakeFiles/domoticz.dir/hardware/ZWaveBase.cpp.o
[ 79%] Building CXX object CMakeFiles/domoticz.dir/hardware/Yeelight.cpp.o
[ 79%] Building CXX object CMakeFiles/domoticz.dir/hardware/XiaomiGateway.cpp.o
[ 79%] Building CXX object CMakeFiles/domoticz.dir/hardware/plugins/PluginManager.cpp.o
georgep
Post by georgep » Friday 23 December 2016 23:12
OK- I got it to compile by disabling Python ( -DUSE_PYTHON_PLUGINS=NO ) but with Python enabled the error persists.
I don't *need* Python enabled so I'll stick with this as a 'solution' for now.
Dnpwwo
Target OS: Raspberry Pi
Post by Dnpwwo » Saturday 24 December 2016 8:43
@georgep,
You only need libpython3.2 or (preferrably) greater if you are going to use python plugins (sounds like you are not) but to compile you do need to have
python3-dev
to get a clean compile.
I added this to the Linux page on the wiki a little while ago (http://www.domoticz.com/wiki/Linux#Inst ... _libraries). If you think it needs to be specified somewhere else let me know.
georgep
Post by georgep » Saturday 24 December 2016 14:24
OK it looks like I may have resolved this...
Despite having installed python3-dev and libpython3.2, cmake was still only finding the original versions
I had to manually edit CMakeFileCache.txt as follows:
//Path to a file.
PYTHON_INCLUDE_DIR:PATH=/usr/include/python3.2
//Path to a library.
PYTHON_LIBRARY:FILEPATH=/usr/lib/libpython3.2mu.so
Cmake now completes successfully with Python plugins enabled:
[email protected]:~/domoticz$ cmake . -DUSE_PYTHON_PLUGINS=YES
-- Python3 includes found at: /usr/include/python3.2
-- Compiling Revision #6235
--   thread
--   date_time
--   system
/usr/bin/c++  ;-O3;-DNDEBUG;-I/usr/include/python3.2;-I/home/george/domoticz/main;-I/usr/local/include;-I/usr/include;-I/usr/include;-I/usr/include;;-DBUILTIN_MQTT;-DUSE_PYTHON_PLUGINS;-DHAVE_EXECINFO_H;-DWITH_LIBUSB;-DWWW_ENABLE_SSL -x c++-header -o /home/george/domoticz/stdafx.h.gch/.c++ /home/george/domoticz/main/stdafx.h
-- Configuring done
-- Generating done
And hopefully it will now compile OK.. let's see ...
Dnpwwo
Post by Dnpwwo » Saturday 24 December 2016 14:34
@georgep,
Your cmake version is probably the issue here, try this: http://www.domoticz.com/wiki/Linux#CMake_version
georgep
Post by georgep » Saturday 24 December 2016 18:08
Thanks @Dnpwwo
I updated my cmake yesterday.
It all compiles fine now so the problem was definitely that cmake hadn't picked up the latest python library locations.
It could just be that my server is based on an old Ubuntu distribution; I quite often find that instructions based on newer versions don't work for me.
Hopefully the info here may be of use to someone; If I can figure out how to do it I'll update the title to show 'Fixed' :-)
George
Users browsing this forum: malp and 3 guests
