Could not install motion package
vgr2
Post by vgr2 » Thursday 22 December 2016 23:47
with sudo apt-get install Motion, i received the following result. How can I fix it Motion is not installed.....
[email protected]:~$ sudo apt-get install motion
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
libc6-dev : Depends: libc-dev-bin (= 2.19-18+deb8u3) but 2.19-18+deb8u6 is to be installed
motion : Depends: libavcodec56 (>= 6:11~beta1) but it is not going to be installed or
libavcodec-extra-56 (>= 6:11~beta1) but it is not going to be installed
Depends: libavformat56 (>= 6:11~beta1) but it is not going to be installed
Depends: libavutil54 (>= 6:11~beta1) but it is not going to be installed
Depends: libjpeg8 (>= 8c) but it is not going to be installed
Depends: libmysqlclient18 (>= 5.5.24+dfsg-1) but it is not going to be installed
Recommends: ffmpeg but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
pvm
Domoticz version: Stable
Re: Could not install motion package
Post by pvm » Thursday 22 December 2016 23:58
Is your system up to date?
sudo apt-get update
sudo apt-get upgrade
Synology NAS, PI3, ZWave, Xiamo zigbee devices, BTLE plant sensor
vgr2
Post by vgr2 » Friday 23 December 2016 0:07
yes, did it before..
vgr2
Post by vgr2 » Friday 23 December 2016 0:11
sorry, "sudo apt-get upgrade" install is also failed
[email protected]:~$ sudo apt-get upgrade
You might want to run 'apt-get -f install' to correct these.
libc6-dev : Depends: libc-dev-bin (= 2.19-18+deb8u3) but 2.19-18+deb8u6 is installed
E: Unmet dependencies. Try using -f.
pvm
Post by pvm » Friday 23 December 2016 15:01
What's the error report on the proposed command?
kubrik
Target OS: Raspberry Pi
Post by kubrik » Friday 23 December 2016 20:22
Have you tried only
apt-get -f install
