Digoo DG-HOSA 433MHz Water sensor
iLLiac4
Post by iLLiac4 » Thursday 07 September 2017 7:52
Have got this sensor https://www.banggood.com/Digoo-DG-HOSA- ... 8532015010
It can communicate with Lightning4 and X10 protocol. Below you can see the logs from RFXmng.
Basically upper button sends Arm Away. Lower button sends Arm Home and is wired with water leakage sensor. So it is the same if you press lower button or shorten the wired sensor (simulates water leakage).
This sensor has also magnetic switch (like door sensors) and it sends the same signal as upper button.
When X10 protocol is enabled i can see the battery level but upper button always sends low voltage.
So basically this is it and it will help someone.
7. 09. 2017 07:42:58
Packettype = Security1
subtype = X10 security
Sequence nbr = 31
id1-3 = 0339C0 decimal:211392
status = Arm Home
battery level = OK
Signal level = 7 -64dBm
7. 09. 2017 07:43:07
Sequence nbr = 32
status = Arm Home
battery level = OK
Signal level = 6 -72dBm
7. 09. 2017 07:43:10
Sequence nbr = 33
status = Arm Away
battery level = Low
7. 09. 2017 07:43:24
Sequence nbr = 34
status = Arm Away
battery level = Low
nmaster
Domoticz version: 3.6304
Re: Digoo DG-HOSA 433MHz Water sensor
Post by nmaster » Wednesday 13 September 2017 12:22
Hi, it looks interesting.
I wonder if other digoo sensors / remotes would work the same way with RFXCOM ?
https://www.banggood.com/Digoo-DG-HOSA- ... ether-auto
FunFair
Target OS: Raspberry Pi
Post by FunFair » Saturday 09 December 2017 22:35
I just received the doorbell, but it doesn't seem to work. When press learn the rfxcom doesn't pick up anything.
FunFair
Post by FunFair » Sunday 11 March 2018 17:24
Hooked it up to the rfx manager and enabled lightning 4. It seems to be working. The IR sensor is working good. The doorbell is a bit of a hit and miss. It sometimes sends out a different code.
