Einhell BGT63 / HS434 Garagedoor opener / GaragenTor
bjacobse
Target OS: Raspberry Pi
Post by bjacobse » Sunday 30 July 2017 23:09
not sure where to ask, but I wonder if I'm the only one that would like to use my Einhell BGT63 that uses HS434 (434MHz) remotes to my garagedoor opener, and would like to receive/transmit from Rfxcom?
It seems that there is some protocol here, searching for
"21" => #Einhell Garagentor
https://github.com/RFD-FHEM/RFFHEM/blob ... ALduino.pm
How the BGT63 looks like and manual
https://www.einhelltools.co.uk/product- ... 34/pgnum=1
bjacobse
Re: Einhell BGT63 / HS434 Garagedoor opener / GaragenTor
Post by bjacobse » Monday 07 August 2017 19:46
To close this thread, I realised that there is a connector on the Einhell, thatI can short circuit, then the garagedoor will either open or close. I can then make an ESPEASY with Wemos D1 Mini Pro working as a relay
DutchHans
Post by DutchHans » Monday 07 August 2017 19:53
Hi, you dont have to.. the Einhell can speak with the rfxcom. It works brilliantly.. remotes still work too
bjacobse
Post by bjacobse » Tuesday 08 August 2017 21:55
How?
I tried in switch tab -> Learn Light/Switch
and get a Type: chime and Subtype: SelectPlus
Which receiver devices have you enabled in rfxcom?
DutchHans
Post by DutchHans » Wednesday 09 August 2017 6:40
The other way around, make a dummy switch and learn the Einhell Garage door. Lighting1 Elro AB400.
Hope this helps.
Gr,Hans
