Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
RidingTheFlow
Target OS: Raspberry Pi
Re: Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
Postby RidingTheFlow » Sunday 20 March 2016 0:59
Not exactly £10, but I've found these on Amazon seller who sell them for £12, and postage is free if you buy 3 or more.
I can confirm that these are in fact Cresta-compatible, and incomparably better quality(and design) than any cheaper Chinese one you can get.
http://www.amazon.co.uk/gp/offer-listin ... dition=new
JohnBoy32
Postby JohnBoy32 » Wednesday 30 March 2016 10:10
Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
http://www.aliexpress.com/item/AOK-2011 ... 12106.html
I can confirm that these are working exactly as they should and also battery-life is fine. I do not have any complaints.
The only point I want to make is that it is old-fashioned to think that something bought on Amazon (or in a local shop) with a non-Chinese brand is made in Europe/US and therefore is better quality; most likely it is made in China and probably in the same factory.
Maybe the one with the nice English brand is made by child hands in People's Republic of Korea.
Please don’t fool yourself or others.
leecollings
Domoticz version: 3.5021
Postby leecollings » Tuesday 05 April 2016 17:17
JohnBoy32 wrote:Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
I've just been reading the reviews on this product, and there are loads of contradicting reviews from people saying it does work with Domoticz, and it doesn't. A lot of people seem to be using the RFXCOM 433E. So what's the official word?
Does it work or not?
johnvl
Postby johnvl » Tuesday 05 April 2016 20:38
For me it works with RFXCOM 433E, raspberryPi and Domoticz; the hardware = Rubicson/IW008T/TX95. :D :D
I can not speak for M***n W. from NL ..... but my guess it is not in the product itself :roll: 8-)
bengt
Postby bengt » Saturday 23 April 2016 21:51
Westcott wrote:I got one from Banggood - it worked straight away with RFXtrx
http://www.banggood.com/433MHz-Wireless ... 8820141020
AWESOME! Thanks for the tip, Westcott!
I have tried ordering several sensors from Aliexpress, but none of them have worked with RFXtrx, so this is a great tip.
Would you happen to know any cheap door sensors (magnet sensors) which also work? :)
planetf1
Postby planetf1 » Monday 09 May 2016 8:41
I ordered the above aliexpress sensor, unfortuinately it is not picked up in the *current* firmware builds -- it looks from https://www.domoticz.com/forum/viewtopi ... 423#p85423 as if this is a regression, so I've emailed support
I previously had the banggood one above which continues to work fine!
Finally I also have this one but not working Image
With domoticz I have undec on... But don't seem to see raw data in the logs... Should I if there are some (like the aliexpress sensor)?
bearded
Postby bearded » Tuesday 28 June 2016 17:25
Hey, thanks for the good advice. I purchased some of these and they have finally arrived but I'm struggling to get domoticz/rfx433e to recognise them. What protocol do you use?
Cheers
Crazy2
Postby Crazy2 » Friday 05 August 2016 12:22
What protocol is working with these?
Westcott
Postby Westcott » Monday 29 August 2016 13:12
Sorry to be so slow in replying - I think is was Rubicson, but I'm now using RFlink, it still works perfectly.
Zwave - Sigma Z+ stick, Fibaro 2x FGSD002, FGMS001, Horstmann - 2x HRT4, 2x C-stat-11,
4x ASR-ZW, Aeon Micro Switch, 2x TKB TZ68E
Max-EQ Cube, Valve
RFXtrx433E, RFlink - 1byone driveway, doorbell, Oregon and BangGood temp
Wifi - YeeLight RGB, Sonoff
b_weijenberg
Postby b_weijenberg » Monday 29 August 2016 13:40
Correct, enable Rubicson for the Banggood sensor. It will be displayed in Domoticz as a WS1700 sensor.
This is supported in the RFXtrx433E by Ext and Ext2 firmware, please see also chapter 2.2.2 in the RFXtrx User Guide
RFXtrx433, RFXtrx433E
Gusimelo
Postby Gusimelo » Tuesday 06 December 2016 18:20
b_weijenberg wrote:Correct, enable Rubicson for the Banggood sensor. It will be displayed in Domoticz as a WS1700 sensor.
How about the RFXtrx433? will it ever support these sensors? just got 3 because was under the impression they were supported, but on the RFXtrx433 I can't see them :(
b_weijenberg
Postby b_weijenberg » Tuesday 06 December 2016 18:48
The Banggood sensor is only supported by the RFXtrx433E and not by the RFXtrx433 as indicated in chapter 2.2.2.
An alternative sensor is probably the Proove TSS320/TSS330
https://www.m.nu/losa-sensorer/temperat ... mpatibel-2
http://www.lohelectronics.se/elektronik ... tion=false
sincze
Domoticz version: 3.6179
Postby sincze » Tuesday 06 December 2016 18:52
b_weijenberg wrote:The Banggood sensor is only supported by the RFXtrx433E and not by the RFXtrx433 as indicated in chapter 2.2.2.
100% True. I was the unlucky guy with the normal RFXtrx433 and did not read chapter 2.2.2
However... my RFLINK R42 deals with this sensor just fine :D
Gusimelo
Postby Gusimelo » Tuesday 06 December 2016 18:58
But will it ever support these sensors?... I already have 3, received them today...
Gusimelo
Postby Gusimelo » Tuesday 06 December 2016 19:01
sincze wrote:100% True. I was the unlucky guy with the normal RFXtrx433 and did not read chapter 2.2.2
Like me...
Are you using both the rfxtrx433 and the rflink?... Or just replaced the rfxtrx with the rflink?
sincze
Postby sincze » Tuesday 06 December 2016 19:14
Like me...
hehehe
A well we have RFXCOM for first and second floor with bigger ANTENNA directly connected via USB.
http://www.ebay.com/itm/433MHZ-10DB-SMA-High-Gain-Antenna-Sucker-Head-Copper-Signal-99-Good-/181634223889?hash=item2a4a3e4f11:g:IqYAAOSwAL9Ui6TX
And RFLINK for second and third floor (with slightly bigger ANTENNA) connected via RFLINK LAN :D
http://www.ebay.com/itm/GSM-GPRS-Antenna-433Mhz-3dbi-cable-SMA-male-Magnetic-base-for-Ham-1-5M-RG174-/330915811011?hash=item4d0c1e8ec3:g:xIoAAOxye3BRsANp
Just to cover the whole AREA :D
And for experimenting..... MYSENSORS Gateway now via LAN as well :)
zorglups
Postby zorglups » Thursday 05 January 2017 17:41
Hello JohnBoy32. Thanks for the tip.
How long last the batteries in this sensor?
How many channels are available?
How are the channels configured?
Thanks.
demandt
Postby demandt » Friday 13 January 2017 18:10
Edit:
Never mind! Got it!
http://domoticz.com/forum/viewtopic.php?p=60394#p60394
Hi All
How did you guys add this to domoticz? It doesn't register when pushing any button in de battery compartment.
Westcott
Postby Westcott » Friday 13 January 2017 18:20
Do you have an RFXtrx or RFlink?
Max-EQ Cube, Valve
b_weijenberg
Postby b_weijenberg » Friday 13 January 2017 19:07
Please check with RFXmngr and enable only the Rubicson/Alecto/Banggood protocol.
Return to “Rfxcom Transceiver”
