Review of small HLK-PM01 powersupply, ideal for MySensors
ThinkPad
Post by ThinkPad » Tuesday 01 September 2015 14:51
On the MySensors forum they were discussing a cheap and very small power supply module, the HLK-PM01
The website 'lygte-info.dk' has made a review of the 5V DC version of this module, which can be found here: http://lygte-info.dk/review/Power%20Mai ... %20UK.html
Don't go the route of buying a cheap iPhone wallcharger and modifying that, this module seems like a better and way more safe idea.
Be warned of the notes that the reviewer mentions though:
Electronic wears down faster when warm, especially capacitors, i.e. keep it as cool as possible for long lifetime.
I would place a fuse or fusible resistor before the converter, the fuse is not supposed to be replaceable, when it blows it is time to replace the converter.
A MOV accross the mains input would probably also be a good idea.
Read the whole discussion about this HLK-PM01 module @ http://forum.mysensors.org/topic/1607/s ... ansformers (advice on fuse & MOV is also mentioned there).
P.S. Also see the other reviews at http://lygte-info.dk/ the guy has a lot of useful information on his website.
ThinkTheme - theme for Domoticz
My (Dutch) blog: http://thinkpad.tweakblogs.net - My Domoticz scripts: Bitbucket
I'm not (very) active anymore on this forum as i don't use Domoticz anymore.
blackdog65
Target OS: Raspberry Pi
Re: Review of small HLK-PM01 powersupply, ideal for MySensor
Post by blackdog65 » Tuesday 01 September 2015 15:01
I've bought a few of these (as mentioned in other posts) and I've been very pleased with them.
Previously I'd been pulling wall warts apart and finding the most appalling electronics inside them.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
ThinkPad
Post by ThinkPad » Tuesday 01 September 2015 15:06
blackdog65 wrote:I've bought a few of these (as mentioned in other posts) and I've been very pleased with them.
Do you have a link where you bought them? I thought there also was a 3.3V type of it, but i can't seem to find it, maybe i made the 3.3V version up in my mind :mrgreen:
Are your modules 5V or 3.3V ? If 5V, how do you power your MySensors stuff (3.3V) with it? Trough the Arduino? (5V in, DC-DC converter on Arduino spits 3.3V out)
blackdog65
Post by blackdog65 » Tuesday 01 September 2015 15:24
Hi Thinkpad,
I got mine from ebay http://www.ebay.co.uk/itm/5-pcs-HLK-PM0 ... 3cff8e98bf
They are the 5v version, I haven't seen 3v.
I use the MYS PCB http://www.mysensors.org/hardware/mys quite a lot with a built in 3v3 regulator but if I make my own pcb I use an AMS1117 to supply the radio and keep everything else 5v.... having said that, I just picked up a bundle of 3v arduino pro minis at auction on ebay which I'll put in battery devices.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
BigDog
Domoticz version: V3.9269
Post by BigDog » Wednesday 09 September 2015 20:18
there is a 220V to 3.3V step down
http://nl.aliexpress.com/item/ac-dc-3-3 ... 5,201409_1
have ordered 2 of them i wil test them when they come in :)
1X Raspberry1B : Domoticz V3.8153 [Linux ver. 4.14.34+ #1110]
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3 Mysensors
3X Cresta Thermo-hygro sensor
6X ESP8266: easy firmware(Testing)
1X 8 Channel Relay Web Control Ethernet interface(Testing)
blackdog65
Post by blackdog65 » Wednesday 09 September 2015 22:42
YAY!
Thanks BigDog.. I found them on ebay now.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
alexsh1
Domoticz version: v3.8975
Post by alexsh1 » Monday 09 November 2015 13:29
This is another one I'd recommend (though more expensive)
http://www.maplin.co.uk/p/5w-33v-pcb-ac ... rter-a62qf
krizzz
Post by krizzz » Monday 09 November 2015 23:02
The more regular used step down converters I know how to attach to a project. Ik just solder the wires on directly to the board. Since I was looking for a more isolated version to use in a project. What is the best way to connect this to my Arduino nano. Solder the wires directly on the powersupply and use "krimpkous" (sorry i do not know the english word) to idolate the connection? Than on the other Side just connect the wire to the Arduino as normal? What do you all think?
SweetPants
Domoticz version: V4.10213
Re: Review of small HLK-PM01 powersupply, ideal for MySensors
Post by SweetPants » Monday 17 July 2017 19:29
I'm using these for over 2 years now and they still work fine: http://www.ebay.com/itm/AC-DC-5V-700mA- ... SwYlRZNUfb
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
