Visualize usuported Mysensors value into Domoticz
bilbolodz
Target OS: Raspberry Pi
Post by bilbolodz » Tuesday 30 May 2017 17:52
My sprinkling controller (own build Mysensors node) reports progress of watering sending V_PERCENTAGE message. Domoticz doesn't support S_SPRINKLER sensor types I've tried to set "watering switch" as Dimmer and reports progress to Domoticz but there are a lot od disadvantages....
Is it possible to create dummy "Percenage" devices (it's possible) and feed it with data send over Mysesnors network from my sprinkler controller? I'm using RPI GPIO Mysensors.
alexsh1
Domoticz version: v3.8975
Re: Visualize usuported Mysensors value into Domoticz
Post by alexsh1 » Thursday 01 June 2017 22:14
I do not think it is possible. If you were to use esp8266 and wifi then updating JSON would update your virtual switch, but this is not the case.
RidingTheFlow
Post by RidingTheFlow » Monday 05 June 2017 21:22
You can use either temperature/humidity or voltage. Voltage has advantage that its pretty high precision.
Temperature/humidity allows to graph combine two independent values on one chart. Humidity good for "percentage" values (0-100%).
Boots33
Post by Boots33 » Tuesday 20 June 2017 5:21
I have used S_DUST/V_LEVEL to display percentage. Have a look at https://forum.mysensors.org/topic/5157/ ... ant-volume
