Call a JSON from Windows Command line
Evelen
Domoticz version: 2.4538
Post by Evelen » Tuesday 24 May 2016 18:59
Hei.
I want to turn on lights ect by calling the JSON with Windows command line.
Is this somthing I can do? and how?
bbqkees
Domoticz version: 3.8x
Re: Call a JSON from Windows Command line
Post by bbqkees » Tuesday 24 May 2016 20:13
Not sure if that is possible without additional software.
you can also just type it into the browser. That will work for sure.
Intel NUC-> Philips Hue, Aeon Zwave stick V2, Qubino, Fibaro, Everspring, Philio, RFXCom, X10, Harmony Hub, Xiaomi Flora + Gateway, BS440. And P1 / Resol VBus / Nefit EMS bus / DHT21 / DS18B20 / Sonoff / I2C display, all via Arduino/ESP8266.
robpow
Target OS: Raspberry Pi
Domoticz version: Beta :)
Post by robpow » Tuesday 24 May 2016 21:35
Here are two options
Download 'curl' for Windows here:
https://curl.haxx.se/dlwiz/?type=bin&os ... cpu=x86_64
Or try and run the Windows PowerShell command 'Invoke-WebRequest':
https://technet.microsoft.com/en-us/lib ... .620).aspx
rlschulz
Domoticz version: 3.5877
Post by rlschulz » Thursday 23 March 2017 17:44
I did this to send an off to a switch to make an actual momentary switch for a garage door opener.
x= IP
y=IDX number of device.
That works well.
