Is it safe to update?..
DutchHans
Target OS: Raspberry Pi
Post by DutchHans » Friday 08 June 2018 14:20
Hello all...
I am running Domoticz for a few years now.. and I love it.. always thinking about new things to automate..
My version is very very stable v.3.8791Beta. Because its so stable I haven't updated for many months... I read the forum daily and found out that several things were not very stable eg. Python issues..Harmony issues etc
I thought.. Mine is working fine and I dont miss things.. but there have been sooo many updates now that I am thinking to update.. but am a little scared...
Regards, Hans
EdddieN
Domoticz version: 4.9700
Re: Is it safe to update?..
Post by EdddieN » Friday 08 June 2018 15:43
Hi Hans,
Just my personal feedback. In general I find Domoticz beta pretty stable. The things that usually could trip compatibility updates in your scripts when updating.
But if this is nothing cannot be fixed after.
The alternative, I use a second Pi for testing new things before updating my main system. My home runs on 2 Pis, it gives me a bit more room for potential pitfalls (mine)
Hope it helps!
Ed
11101101 - www.machinon.com
tontze
Post by tontze » Friday 08 June 2018 16:13
i would clone sd and use another one to test ..
Rpi 3 / Razberry 2
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
ESP82xx
Egregius
Post by Egregius » Friday 08 June 2018 16:59
You should always have a versioned backup, then it's no problem at all to update because you can go back to any date in the past that you want.
jake
Post by jake » Saturday 09 June 2018 11:13
Egregius wrote:You should always have a versioned backup, then it's no problem at all to update because you can go back to any date in the past that you want.
How to do that?
petersh
Post by petersh » Sunday 24 June 2018 12:18
I also think it is safe to update. Domoticz is stable, either with the update
If you can believe it, the mind can achieve it, Peter
Denny64
Domoticz version: 3.8153
Post by Denny64 » Sunday 24 June 2018 15:51
It's my opinion, but when you do not have anything really important to gain from an update and the system does well, it leaves everything as it is.
@ jake
To make SD image you can use dd command on Linux or Win32diskimager on Windows, but recently I discovered a script with which make a SD image on a USB pendrive inserted into RPI, via command shell and also with incremental backup.
This is the link. https://pimylifeup.com/backup-raspberry-pi/ Move to the end at "Backing up your Raspberry Pi to a USB Drive"
