Broadlink plugin
Terence
Target OS: Raspberry Pi
Broadlink plugin
Post by Terence » Wednesday 25 April 2018 0:26
I have managed to get it working, but when I run ./plugin_http.sh
I get the following in the no hap.out file
File "/home/terence/domoticz/plugins/BroadlinkRM2/plugin_http.py", line 319, in <module>
os.chdir(PATH)
FileNotFoundError: [Errno 2] No such file or directory: 'c:/BroadlinkRM2'
os.chdir(PATH)
os.chdir(PATH)
os.chdir(PATH)
Can anybody help.
It looks like the C:/Broadlink is wrong I am on a Debian system, but do not know where to change that location
CaesarPL
Re: Broadlink plugin
Post by CaesarPL » Wednesday 25 April 2018 14:37
Put any folder name if you want to store it under your home directory
cardy
Post by cardy » Tuesday 15 May 2018 13:30
Looking at the version of the script I have the http_plugin.py script accepts 3 parameters.
Hostname port-number path
if len(sys.argv) > 3:
    HOST_NAME = sys.argv[1]
    PORT_NUMBER = int(sys.argv[2])
    PATH = sys.argv[3]
else:
    PATH="c:/BroadlinkRM2"
    HOST_NAME = ""
    PORT_NUMBER = 9000
If these are not specified it defaults to one values after the if statement above which is where your "c:\BroadlinkRM2" is coming from. I am guessing that when the script is called by the plugin all 3 values are passed to it.
If you wish to specify just a new directory you could use something like.
./http_plugin.py '' 9000 '/home/pi/broadlinkrm2'
to run the script.
Users browsing this forum: No registered users and 4 guests
