Digoo WiFi Ip cam Watherproof
Derik
Target OS: Raspberry Pi
Post by Derik » Monday 25 December 2017 13:54
Dear all,
A nice small Wifi Cam ...
Is there perhaps anybody that have this camera working Domoticz?
http://www.mydigoo.com/Digoo-DG-W02f-Cl ... -p-90.html
Can see this camera in the original app, only no webui or something...
kniazio
Re: Digoo WiFi Ip cam Watherproof
Post by kniazio » Monday 25 December 2017 15:57
EdwinK
Post by EdwinK » Monday 25 December 2017 22:58
Cheap one. But I see there is no power-supply with it. How do you like the quality?
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
Derik
Post by Derik » Tuesday 26 December 2017 12:33
Correct no power supply, nice quality...
@ kniazio thanks... [ for me a new project ] give this a try
EdwinK
Post by EdwinK » Tuesday 26 December 2017 15:10
Found out the settings?
EdwinK
Post by EdwinK » Tuesday 26 December 2017 15:20
Gone ahead and ordered one, just to try. If this works, then I might go and order more. If not... I will see what to do then
Derik
Post by Derik » Wednesday 27 December 2017 12:38
Mmm cannot see the cam in ispy.....
Think I do something wrong..
Ispy for dummy's ..... I need first I think..
EdwinK
Post by EdwinK » Friday 05 January 2018 18:45
Still no luck? Waiting for mine to arrive. Then I'll try it from Synology
Derik
Post by Derik » Saturday 06 January 2018 14:07
nope i try to use ispy etc..
Only i am not smart for this master software...
Ans i mis time to try it..
frostwork
Post by frostwork » Tuesday 09 January 2018 14:29
hi,
I have some digoo cameras as well (Digoo DG-M1X HD 960P).
nice quality for the price, but they send everything they see to some external servers!
atm I don't use them at all as the onvif protocol is almost not functional, but I my firewall doesn't allow them to go anywhere.
default username password is admin/20160404
and a basic rtsp stream can be received with f.e.
vlc rtsp://admin:20160404@CAMERAIP:554/onvif1
interesting urls for very similar cams:
http://adamwesterberg.se/blog/cheap-chi ... a-teardown
https://github.com/yuvadm/DG-M1Q
good luck and be careful!
Derik
Post by Derik » Tuesday 09 January 2018 23:47
mmm Thanks for the warning and info..
Could you please tell me how to block this camera to the firewall..[ and use it in Domoticz ? ]
And unfortunately the login does not work with this camera....
Is there perhaps no hack or something like a fanghack for the xiaomi ip camera...?
EdwinK
Post by EdwinK » Wednesday 10 January 2018 14:13
Synology did discover a ONVIF device on port 80, but needs a username and password.
frostwork
Post by frostwork » Wednesday 10 January 2018 18:41
if you have a firewall I'd simply block any wan traffic for the camera.
if not you could at least (very likely not enough, as probably some ips are hardcoded) redirect/block all dns requests of the camera f.e. by using pihole in your network (my digoos try to reach multiple p2p$NUMBER.cloud(-)links.(net|cn) servers)
often those cameras are just rebrands and have all the same codebase and similar socs,
but I don't know your cam so no idea if someone tried to hack it.
with some luck you have an open telnetport or can reopen it(?).
EdwinK
Post by EdwinK » Wednesday 10 January 2018 19:13
I've at least blocked some domains in pi-hole.
frostwork
Post by frostwork » Friday 12 January 2018 20:36
hi,
I have good news for you (hope so, can't test it obviously).
just found this video https://www.youtube.com/embed/QDHUVUvunEw
via https://forum.banggood.com/forum-topic-445249.html.
I didn't watch it completely and just shuttled to some textfield in the preview but it looks like
rtsp://admin:dg20160404@YOURIP/onvif1
is the valid default for your camera (digoo dg-w02f). good luck!
EdwinK
Post by EdwinK » Friday 12 January 2018 22:19
Going to try it. Thanks
edit: No luck so far. Will take a better look at it tomorrow.
Derik
Post by Derik » Friday 12 January 2018 23:19
Thanks for me to...only I stop with this camera.. I hate extern storage.
Are there people that use a small waterproof ip cam that is working great in domoticz??!😉
EdwinK
Post by EdwinK » Friday 12 January 2018 23:26
Screen Shot 2018-01-12 at 22.22.00.png (47.58 KiB) Viewed 1480 times
I have it working in another application, still no luck with Domoticz.
If you want to get rid of that cam, you can send it to me, and I'll try more.
EdwinK
Post by EdwinK » Monday 15 January 2018 12:58
Still no luck with Domoticz and this camera. Just now going to see if I can set-it up using a tablet.
frostwork
Post by frostwork » Monday 15 January 2018 17:48
damn, I was hoping above password does work.
did you already check which ports are open on the device?
maybe rtsp is somewhere else or you have some passwordless telnet root access.
you might also want to try "motioneye", which is a webgui for the motion. It works very fine, is easy to setup and also accepts rtsp urls.
works fine with my digoo cams.
Users browsing this forum: StanHD, willie-p and 3 guests
