Cheap discrete ip cameras?
burton666
Target OS: Raspberry Pi
Post by burton666 » Wednesday 21 June 2017 10:35
I am planning to add alot of ipcameras to my home to be used as motion-detectors and hopefully some sort of more reliable human presence detection. But I am struggling to find any cameras which looks pretty descrete and are also so cheap that I can buy 8-10 cameras.
My demands are:
Cheap 20-30EUR
Discrete looking
Wifi: N standard
To be able to access from internet browser or similar.
Resolution is not important as I only need 320x240-640x320
I have found some small 360 camera that fills all my needs BUT is NOT accessible from anything other than Android/IOS. I don't know what kind of magic they use for the videostreams but it is very difficult to access them from http. http://www.ebay.com/itm/Mini-360-Degree ... SwLEtYmuGH
Also this Xiaomi camera looks pretty good but I cant understand if it is possible to use them any longer as they now claim that they can't be used in America/EU any longer. http://www.gearbest.com/ip-cameras/pp_487830.html
Does anyone have any better suggestions of other cameras or similar?
EdwinK
Re: Cheap discrete ip cameras?
Post by EdwinK » Wednesday 21 June 2017 10:58
Did you read this topic. Maybe it will work for this camera as well.
Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
burton666
Post by burton666 » Wednesday 21 June 2017 11:36
Yes, I started that thread, but I still can't find any way to access the camera from any other external device.
martgadget
Post by martgadget » Thursday 27 July 2017 10:43
I assume there is an android app for the camera you are trying to interface to?
if this is the case, try getting the android APK file and de-compiling it to see what the vendor is doing to get to the camera. I did this with the Salus IT500 thermostat app and it revealed everything i needed to know about talking to the device.
hope that helps
Mart.
martgadget
you can also de-compile .net apps for windows as well and get the source, so if they ship a .NET app then you could use that as well.
LouiS22
Post by LouiS22 » Friday 28 July 2017 14:08
burton666 wrote:I am planning to add alot of ipcameras to my home to be used as motion-detectors and hopefully some sort of more reliable human presence detection. But I am struggling to find any cameras which looks pretty descrete and are also so cheap that I can buy 8-10 cameras.
My demands are:
Cheap 20-30EUR
Discrete looking
Wifi: N standard
About the Xiaomi Camera (Xiaofang): there's a hack running from an SD card (called fang hacks) which solves the china mainland only issue. Downside: it also disables the xiaomi app, so you loose those functions as well. But it also enables RTSP which you can access from your internal network. Keep in mind: domoticz doesn't handle RTSP streams.
Gambit
Post by Gambit » Friday 28 July 2017 15:25
https://github.com/ccrisan/motioneye/wiki
Possible option to swap out the pi for the cheaper Orange Pi Zero and its basic camera.
borewicz
Post by borewicz » Monday 21 August 2017 10:41
There's new Xiaomi camera comming soon:
https://www.banggood.com/Xiaomi-MIjia-H ... 81323.html
steef84
Domoticz version: DS213+
Post by steef84 » Wednesday 23 August 2017 20:55
Interresting price: to buy or not to buy ...
- Stefan
Timmeh4
Post by Timmeh4 » Wednesday 16 May 2018 18:19
hope that helps
Mart.
I know it's and old post but i want to know how you did this because i have the same thermostat and want to control it with domoticz.
Timmeh4
heggink
Domoticz version: V4.9999
Post by heggink » Monday 25 June 2018 14:52
I never liked the ET phone home aspect of teh Chinese cameras so built my own using a cheap 5v power supply (AliExpress), raspberry pi zero w, my own 3d printed enclosure (https://www.thingiverse.com/thing:2807761) and an AliExpress ir cur lens (https://www.aliexpress.com/item/New-Ras ... 83732.html).
Not sure what the exact price tag was but probably around 20 bucks or so (mainly lens and pi).
On top, I run motioneye in fast network camera mode connected to a motioneye server installation on my NAS that does the motion detection.
Everything works really well and no unwanted connections to any other place than my home + fine integration with domoticz.
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
