Lightning and Domoticz
EdwinK
Target OS: Raspberry Pi
Re: Lightning and Domoticz
Post by EdwinK » Monday 29 May 2017 19:23
Same problem as Assenzuid.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
tezzlicious
Post by tezzlicious » Monday 29 May 2017 21:39
assenzuid wrote:Just implementing this nice script.
But I have set it to use quit,
# time.sleep(120) # When use script in loop use this part.
quit(5) # when use script one's a time use this part.
But it runs continuous when start it from the command line with
python lightning.py
Found 0 matches -- Mon May 29 13:20:07 2017
0 old matches were ignored -- Mon May 29 13:20:07 2017
Found 0 matches -- Mon May 29 13:20:08 2017
0 old matches were ignored -- Mon May 29 13:20:08 2017
Be careful to get the indentation right. Take a close look at the while loop. Simply removing all the spaces causes to skip the sleep or quit.
assenzuid
Post by assenzuid » Monday 29 May 2017 22:03
Ok, I have play with it and it now works.
# Send info to domoticz
    requests.get(
    "%s:%d/json.htm?type=command&param=udevice&idx=%s&svalue=%d" %
    (server, port, deviceIdx, value))
and also configured with time.sleep
    requests.get(
    #quit(5) # when use script one's a time use this part.
Found 0 matches -- Mon May 29 22:02:36 2017
0 old matches were ignored -- Mon May 29 22:02:36 2017
Found 0 matches -- Mon May 29 22:04:38 2017
0 old matches were ignored -- Mon May 29 22:04:38 2017
assenzuid
Post by assenzuid » Monday 29 May 2017 22:11
What's the best way to get an notification by email, but not at every strike, but one time and if later the same day new lightning is detected again a notification.
assenzuid
Post by assenzuid » Monday 29 May 2017 22:12
EdKo66 wrote:Same problem as Assenzuid.
I Solved it to modify it so.
    requests.get(
    #time.sleep(120) # When use script in loop use this part.
EdwinK
Post by EdwinK » Monday 29 May 2017 22:15
Going to try this. Thanks.
EdwinK
Post by EdwinK » Monday 29 May 2017 23:12
Running this manually works, but when I want to run this through 'Task Scheduler' on the Synology, I get an 'interrupted (5)' error message.
This is what is in the box to execute.
python /var/scripts/blikseminslag.py
(edit)Nevermind. Got it working.
vanathi
Post by vanathi » Tuesday 30 May 2017 6:15
there anybody
phoenixblue
Domoticz version: 3.7392
Post by phoenixblue » Tuesday 30 May 2017 9:22
Little update, because there are an lot of issues with double lighting strikes and some memory issues because it's running in the memory.
It's now possible to run the script once an time (for example every 2 min) from an cronejob so the script is download the strike info and store the last value in an tmp file.
When you restart the script it will check first the tmp file for the last strike time and compare that with the new info.
So the script is not sending double strik info into Domoticz and you don't have to run the script in the python memory.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Following libraries in python are needed : json, yaml,math,time,requests
# This script will load an external json file that contact for europe the lightning information and will send it to Domoticz when it's
# insde the distance range
# Many thanks to Ignacio for helping ;-).
# How to use:
# 1) made an dummy counter inside Domoticz and set the idx into this script "deviceIdx"
# 2) You cen set the GPS location where to calculate with manual otherwise the script try to receive this info from the settings page inside Domoticz
# 3) Set the distance range in km where to calculate with.
# 4) Run this script on the way you like, as service or cronjob, etc.
# Accuracy is quite good and is sometimes lower than 1 kilometer. This is equal to commercial stroke detection companies. But you can not use this info for protection of life and property!
import math
import requests
import json
import os
from datetime import datetime
# Domoticz server settings
server = "http://localhost"
port = 8080
deviceIdx = "1"
# Location to import the lightning info
jsonUrl = "http://www.onweeractueel.nl/domoticz_bo.json"
# GPS location and distance to calculate
latHome = xx.xxxxxx
lngHome = xx.xxxxxx
distanceRange = 15  # Distance in km
# Try to get GPS location from domoticz
try:
    data = json.loads(
        requests.get(
            "%s:%d/json.htm?type=settings" %
            (server, port)).content)
    latHome = float(data['Location']['Latitude'])
    lngHome = float(data['Location']['Longitude'])
except:
    pass
# Location distance calculation
def distance(lat1, lng1, lat2, lng2):
    radius = 6371
    dLat = (lat2 - lat1) * math.pi / 180
    dLng = (lng2 - lng1) * math.pi / 180
    lat1 = lat1 * math.pi / 180
    lat2 = lat2 * math.pi / 180
    val = math.sin(dLat / 2) * math.sin(dLat / 2) + math.sin(dLng / 2) * \
        math.sin(dLng / 2) * math.cos(lat1) * math.cos(lat2)
    ang = 2 * math.atan2(math.sqrt(val), math.sqrt(1 - val))
    return radius * ang
last = 0
if os.path.exists("/tmp/last_lightning.txt"):
    f = open("/tmp/last_lightning.txt")
    last = int(f.read())
    f.close()
z = requests.get(jsonUrl)
data = json.loads(z.content)
value = 0
ignored = 0
for pos in data:
    time_, lat, lng = pos
    distanceBetween = distance(latHome, lngHome, lat, lng)
    if (distanceBetween <= distanceRange):
        if (time_ > last):
            value += 1
        else:
            ignored += 1
f = open("/tmp/last_lightning.txt", "w")
f.write(str(time_))
f.close()
print ("Found %d matches -- %s" %
       (value, datetime.strftime(datetime.now(), "%c")))
print ("%d old matches were ignored -- %s" %
       (ignored, datetime.strftime(datetime.now(), "%c")))
requests.get(
scripts on github: Link
mrfusion
Post by mrfusion » Friday 02 June 2017 23:58
Hi and thanks for this nice script however I'm facing some strange errors:
$ python lightning.py
File "lightning.py", line 73, in <module>
File "/usr/lib/python3.5/json/__init__.py", line 312, in loads
s.__class__.__name__))
TypeError: the JSON object must be str, not 'bytes'
I'm running Ubuntu 16.04.2 LTS and python 3.5.2
At first I thought it was a package issue but I have all needed ones.
Maybe you created it with older python/json version and some commands changes.
Any idea? (took last version you posted)
GJKNL
Post by GJKNL » Saturday 03 June 2017 11:14
GJKNL wrote:Wow, lot of lightning
I think I know why this was going wrong.
I also made a script with a radius of 50km, but I did not change the name of the tmp file. So both scripts used the same tmp file
phoenixblue
Post by phoenixblue » Saturday 03 June 2017 14:09
@mrfusion, strange error.
I will try it to run it on an same environment as you did.
mrfusion
Post by mrfusion » Saturday 03 June 2017 14:29
@phoenixblue:
Could be python version and the way of handling urls/requests.
It seems not so uncommon error from what I "googled"
It is like the output of json query is not received in the expected format.
mrfusion
Post by mrfusion » Saturday 03 June 2017 14:36
@ phoenix blue: found the trick:
I edited the line 73 this way and it is working:
data = json.loads(z.content.decode('utf-8'))
instead of
So I guess that on my system python was not expecting the good format by default.
phoenixblue
Post by phoenixblue » Monday 05 June 2017 21:11
@mrfusion, thanks for the feedback.
A pity that Python used more ways based on the different versions.
Small update from this side, because i'm migrating the server to an other url I have an new location for the json file.
[http://www.onweeractueel.nl/domoticz_bo.json]
I have already changed in the last script, so when you reed this updat change it in yours ;-)
The old one i will run it parallel for an few months.
Derik
Post by Derik » Tuesday 06 June 2017 8:40
Dear...
I did run th eold script.. [ sometimes hahah]
The new i did install... with a crontab
Only the script is not running.
Do i have the settings for this good?
Or where can i go wrong?
And i do have a new odtiod board..[ Xu4 fast fast fast ]
Do i need perhaps install some software?
freijn
Post by freijn » Tuesday 13 June 2017 8:29
Derik,
Are you able to run the onweer.py from the commandline ?
>python onweer.py
What is the output of that?
EdwinK
Post by EdwinK » Thursday 22 June 2017 17:07
Strange. I'm running this script, and it goes from 7 strikes to 1 strike, and then up again.
this is from the log:
2017-06-22 15:30:00 0
2017-06-22 15:35:00 1
2017-06-22 15:40:00 0
2017-06-22 15:45:00 0
2017-06-22 15:50:00 0
2017-06-22 15:55:00 0
2017-06-22 16:00:00 1
2017-06-22 16:05:00 0
2017-06-22 16:10:00 0
2017-06-22 16:15:00 0
2017-06-22 16:20:00 0
2017-06-22 16:25:00 0
2017-06-22 16:30:00 0
2017-06-22 16:35:00 0
2017-06-22 16:40:00 0
2017-06-22 16:45:00 1
2017-06-22 16:50:00 0
2017-06-22 16:55:00 4
2017-06-22 17:00:00 0
2017-06-22 17:05:00 3
Not that I;m going to loose any sleep over it, just wondering.
PeteC
Domoticz version: 3.5877
Post by PeteC » Saturday 15 July 2017 14:57
Curiosity question....
Here I am located near Chicago and have been testing the AS3935 Lightning sensor break out board on one RPi using Python. It works well.
I am also using custom mapping from lightning dot org except there are no real local stations here.
Concurrently also revisiting old Hobby Boards 1-wire lightning sensor which is just a dual 1-wire counter. The 1-wire network is connected via a USB-Serial 9097 hub. Next also testing an EMP sensor which is just a pulse detection sensor on a GPIO pin on the RPi.
Is it possible to combine both to one Python script so generate lightning sensor variables?
Concurrently testing this lightning sensor counting pulses on GPIO pin for local lightning counts
and old Hobby boards dual wire sensor for distant lightning counts
Automator
Hardware: ARM, Intel, AMD based Linux boxes
OS: now all Linux (and a bit of Wintel)
Automation: X10, Inteon, UPB, Zigbee and ZWave - HAI Leviton OmniPro 2 panel (security and automation)
freijn
Post by freijn » Saturday 15 July 2017 23:53
Pete,
Not quite sure I do understand the question, but if you do get the both sensors connected to the Raspberry you can ( or coures) write a script to read them.
From your post I just do not understand what you would like to combine?
Just a graph ? or like to make calculations ?
Combining both imputs to Domoticz ???
Sorry,
Frank
