Lightning and Domoticz
freijn
Target OS: Raspberry Pi
Re: Lightning and Domoticz
Post by freijn » Wednesday 19 April 2017 13:08
If you start the script from putty , end it with an & enperant which makes it keep running in the background while exiting Putty.
python script.py &
Siewert308SW
Post by Siewert308SW » Thursday 20 April 2017 22:40
Maybe a dumb question or im in need of glasses. ;-)
The script works well and counter updates as it should be.
But my question is as i want the lighting strikes per hour, how do you guys retrieve the strikes per hour in python or bash so that the output can be used else where.
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
phoenixblue
Domoticz version: 3.7392
Post by phoenixblue » Thursday 20 April 2017 23:25
Just for my clearance, do you mean the info per hour inside Domoticz or do you mean the import file?
The import file itself is updated every 2 minutes server based from an central database.
scripts on github: Link
freijn
Post by freijn » Friday 21 April 2017 14:34
@Siewert
I see you have domoticz as well. Counting in a couter and then click on 'log' gives you a diagram per hr.
as per Phoenixblue please give us some details about your requirements
Siewert308SW
Post by Siewert308SW » Friday 21 April 2017 17:14
freijn wrote:@Siewert
Phoenixblue knows what i mean as he pm me to clear the sky in our own language ;-)
I know the counter shown you a per hour diagram, but the main question is how to retrieve that so i get a usable output to use somewhere else.
I know you can get daily and monthly by a json but hourly isn't possible, or am i missing something.
Setup:
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
tontze
Post by tontze » Sunday 23 April 2017 8:05
Hi !
I have script to make lightning.py to run as service.
You should copy this startup script to /etc/init.d folder named as "lightning"
copy lightning checker script lightning.py to /usr/local/bin
#! /bin/sh
# /etc/init.d/lightning
### BEGIN INIT INFO
# Provides:          lightning
# Required-Start:
# Required-Stop:
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: This daemon manages lightning detection : lightning
### END INIT INFO
# This next line determines what user the script runs as.
# Root generally not recommended but necessary if you are using the Raspberry Pi GPIO from Python.
DAEMON_USER=pi
PATH=/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/bin
DAEMON=/usr/local/bin/lightning.py
# The process ID of the script when it runs is stored here:
PIDFILE=/var/run/lightning/lightning.pid
NAME=lightning
test -x $DAEMON_OPTS || exit 0
. /lib/lsb/init-functions
do_start()
        # Return
        #   0 if daemon has been started
        #   1 if daemon was already running
        #   2 if daemon could not be started
        if pidofproc -p $PIDFILE "$DAEMON" > /dev/null 2>&1 ; then
                return 1
        fi
case "$1" in
  start)
     log_daemon_msg "Starting $NAME"
     do_start
     RET_STATUS=$?
     case "$RET_STATUS" in
        1)
           log_success_msg
           [ "$VERBOSE" != no ] && [ $RET_STATUS = 1 ] && log_warning_msg "Daemon was already running"
           start-stop-daemon --start  --background --oknodo --pidfile $PIDFILE --make-pidfile --user $DAEMON_USER --chuid $DAEMON_USER --exec $DAEMON  $DAEMON_OPTS
           log_end_msg $?
     esac
  stop)
     log_daemon_msg "Stopping $NAME"
     start-stop-daemon --stop --pidfile $PIDFILE --retry 10
     log_end_msg $?
  force-reload|restart)
     $0 stop
     $0 start
  status)
     status_of_proc -p $PIDFILE $DAEMON $NAME  && exit 0 || exit $?
   echo "Usage: /etc/init.d/lightning {start|stop|restart|force-reload|status}"
   exit 1
esac
exit 0
Do :
sudo chmod 755 /usr/local/bin/lightning.py
sudo chmod 755 /etc/init.d/lightning
And finally add it as service :
sudo update-rc.d lightning defaults
Try it out :
sudo /etc/init.d/lightning start
and
sudo /etc/init.d/lightning stop
Rpi 3 / Razberry 2
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
ESP82xx
phoenixblue
Post by phoenixblue » Monday 24 April 2017 20:57
Thanks for this solution!
small question, i get this error when i want to set it as server:
pi@Domoticz:~ $ sudo chmod 755 /usr/local/bin/lightning.py
pi@Domoticz:~ $ sudo chmod 755 /etc/init.d/lightning
pi@Domoticz:~ $ sudo update-rc.d lightning defaults
update-rc.d: error: initscript does not exist: /etc/init.d/lightning
pi@Domoticz:~ $
The file is inside the folder so that must be ok.
phoenixblue
Post by phoenixblue » Friday 28 April 2017 20:51
Small update, the script is now also able to check from the Domoticz settings page the GPS location so you don't have to insert it manual.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Following libraries in python are needed : json, yaml,math,time,requests
# This script will load an external json file that contact for europe the lightning information and will send it to Domoticz when it's
# insde the distance range
# Many thanks to Ignacio for helping ;-).
# How to use:
# 1) made an dummy counter inside Domoticz and set the idx into this script "deviceIdx"
# 2) You cen set the GPS location where to calculate with manual otherwise the script try to receive this info from the settings page inside Domoticz
# 3) Set the distance range in km where to calculate with.
# 4) Run this script on the way you like, as service or cronjob, etc.
# Accuracy is quite good and is sometimes lower than 1 kilometer. This is equal to commercial stroke detection companies. But you can not use this info for protection of life and property!
import math
import requests
import json
import time
from datetime import datetime
# Domoticz server settings
server = "http://localhost"
port = 8080
deviceIdx = "1"
#Location to import the lightning info
jsonUrl = "http://www.onweerdetectie.com/domoticz_bo.json"
# GPS location and distance to calculate
latHome = xx.xxxxxx
lngHome = xx.xxxxxx
distanceRange = 15  # Distance in km
# Try to get GPS location from domoticz
try:
    data = json.loads(
        requests.get(
            "%s:%d/json.htm?type=settings" %
            (server, port)).content)
    latHome = float(data['Location']['Latitude'])
    lngHome = float(data['Location']['Longitude'])
except:
    pass
# Location distance calculation
def distance(lat1, lng1, lat2, lng2):
    radius = 6371
    dLat = (lat2 - lat1) * math.pi / 180
    dLng = (lng2 - lng1) * math.pi / 180
    lat1 = lat1 * math.pi / 180
    lat2 = lat2 * math.pi / 180
    val = math.sin(dLat / 2) * math.sin(dLat / 2) + math.sin(dLng / 2) * \
        math.sin(dLng / 2) * math.cos(lat1) * math.cos(lat2)
    ang = 2 * math.atan2(math.sqrt(val), math.sqrt(1 - val))
    return radius * ang
last = 0
while True:
    z = requests.get(jsonUrl)
    data = json.loads(z.content)
    value = 0
    ignored = 0
    for pos in data:
        time_, lat, lng = pos
        distanceBetween = distance(latHome, lngHome, lat, lng)
        if (distanceBetween <= distanceRange):
            if (time_ > last):
                value += 1
            else:
                ignored += 1
    last = time_
# terminal print
    print ("Found %d matches -- %s" %
           (value, datetime.strftime(datetime.now(), "%c")))
    print ("%d old matches were ignored -- %s" %
           (ignored, datetime.strftime(datetime.now(), "%c")))
# Send info to domoticz
		   requests.get(
        "%s:%d/json.htm?type=command&param=udevice&idx=%s&svalue=%d" %
        (server, port, deviceIdx, value))
		# time.sleep(120) # When use script in loop use this part.
    quit(5) # when use script one's a time use this part.
tontze
Post by tontze » Tuesday 02 May 2017 21:07
With the new script :
@raspberrypi:~ $ python /usr/local/bin/lightning.py
  File "/usr/local/bin/lightning.py", line 90
    requests.get(
IndentationError: unexpected indent
Rpi 3 / Razberry 2
Mi Light
ESP82xx
tontze
Post by tontze » Tuesday 02 May 2017 21:30
phoenixblue wrote:Thanks for this solution!
pi@Domoticz:~ $
Im puzzled .. Should work if you really have file "/etc/init.d/lightning" And you have supplied code inside it
-T
Rpi 3 / Razberry 2
Mi Light
ESP82xx
tontze
Post by tontze » Tuesday 02 May 2017 21:42
tontze wrote:With the new script :
    requests.get(
Ok, too much white spaces at the end of the script before new lines :)
Rpi 3 / Razberry 2
Mi Light
ESP82xx
dennis70
Post by dennis70 » Friday 05 May 2017 16:02
i'm getting the next problem, see below.
pi@raspberrypi:~/domoticz/scripts/python $ python onweer.py
File "onweer.py", line 90
requests.get(
does anybody know what to do?
phoenixblue
Post by phoenixblue » Friday 05 May 2017 18:23
Looks at the same problem as tontze, when you delete those white spaces is the problem then solved?
I will update the message with the script.
tontze
Post by tontze » Friday 05 May 2017 18:33
phoenixblue wrote:Looks at the same problem as tontze, when you delete those white spaces is the problem then solved?
For me yes :)
Rpi 3 / Razberry 2
Mi Light
ESP82xx
zenit
Post by zenit » Sunday 28 May 2017 10:30
Hi All,
First of all ,thanks for this script phoenixblue/Freijn. Today in my surrounding we had/have lots of strikes this morning. So i decided to try this script.
Running this script in putty from cli worked well. The only thing was that updating my virtual counter in Domoticz didn't.
With some trial and error fiddling I removed de quotes from the device idx.
So i put ---> deviceIdx = 191 <---- instead of ---> deviceIdx = "191" <---- in the script.
I can't explain why but, This worked !!! :) and my sensor got updated in Domoticz. Maybe I helped some people with this info.
edit:typo,small addition.
GJKNL
Post by GJKNL » Sunday 28 May 2017 16:15
Wow, lot of lightning
phoenixblue
Post by phoenixblue » Sunday 28 May 2017 21:41
Do you use the last version of the script otherwise it's possible that it counts sometimes double ;-)
GJKNL
Post by GJKNL » Sunday 28 May 2017 21:49
phoenixblue wrote:Do you use the last version of the script otherwise it's possible that it counts sometimes double ;-)
Looks like not and it looks more than double :D
assenzuid
Post by assenzuid » Monday 29 May 2017 13:22
Just implementing this nice script.
But I have set it to use quit,
But it runs continuous when start it from the command line with
python lightning.py
Found 0 matches -- Mon May 29 13:20:07 2017
0 old matches were ignored -- Mon May 29 13:20:07 2017
Found 0 matches -- Mon May 29 13:20:08 2017
0 old matches were ignored -- Mon May 29 13:20:08 2017
vanathi
Post by vanathi » Monday 29 May 2017 14:13
Anybody s there...?
Users browsing this forum: D'rMorris and 4 guests
